DIY: blackline taillight installation
09-19-2005, 09:23 PM | #1 |
1429
Rep 16,628
here is what is needed to do the installation.
30-45 minutes time 5/16 socket??? (it fit pretty good didnt have the metric size) 1/4 socket wrench 1/4 extension screw driver (flat) plug remover (no neccesary, but good to have) 1 can of squirt you can start with what ever, trunk or sides. i started with trunk. unplug all the plug with the flat screw driver. use your hand or the plug remover to remove the plugs. now you have access to the back of the taillight. unscrew the nut seen. theres only 1. remove taillight carefully. do not force, it should come out easy. now, replace it with the blackline taillight, make sure the side piece is hook around the side of the trunk, see picture the inside part hooks onto the panel inside, see in picture (poor shot) now tighten the nut. it should pull the taillight down. make sure you hand tight this piece. do not over tight, you might break something. for putting back the carpet piece. just reverse the previous steps. here is a picture of the black line taillight with the stock side. not bad!!! now for the side, remove the carpet cover. pull from the upper corner downwards, (this is for the driver side.) now the back of the side taillight is expose unscrew the 3 nuts. remove taillight. and replace with blackline taillight sorry no pictures, camera ran out of battery. for the passenger side, turn the black knob like, it should expose the battery of the car. this side is much easier. before putting things back, check all the bulbs to see if it works, so you have to take the panels out again ***you have to align the taillight center yourself. hand tighten the side and adjust to the way you like. then tighten with the socket.. hope this help someone. here is more of the finish job... sorry pictures a little blury. |
09-19-2005, 09:34 PM | #3 |
1429
Rep 16,628
thanks, actually they are not smoked, if you see the plastic in person its actually clear. the black color you see is the housing.
09-23-2005, 08:47 AM | #4 |
Rep 10
Clear Lenses.
Those tail light look great.
Do you know if these are available for the e91 model. If not are you able to let me know where to get them for e90. Regards, |
09-23-2005, 11:42 AM | #5 |
1429
Rep 16,628
where in the world is Leicestershire? i am in the US, i had a hard time looking for these. they where imported from germany, so if you are near there, a bmw dealer in germany should have them for you. i know nothing about the e91. we dont have that car here.
09-23-2005, 02:01 PM | #6 |
Rep 10
Lights.
Leicestershire in England.
Im a bit closer to Germany than you then ! Where you able to purchase them from an official bmw dealer ? E91 Touring only came out this week in England. |
09-23-2005, 02:50 PM | #7 |
1429
Rep 16,628
yes. i think in germany it cost 199 euro. there was a forum about it. someone bought he is from europe. not sure where exactly.
10-22-2005, 10:14 PM | #8 | |
guardian of ice and snow
67
Rep 424
Is installing the Blackline Taillights just simple "pop-in-and-pop-out" procedure? Or does it involve some wiring?
10-23-2005, 11:07 AM | #9 | |
1312
Rep 10,185
10-23-2005, 11:46 PM | #10 | ||
67
Rep 424
10-23-2005, 11:49 PM | #11 | |
Administrator
40807
Rep 21,240
No "wiring" as in splicing wires or anything that's difficult. |
10-24-2005, 12:11 AM | #12 | ||
67
Rep 424
11-23-2005, 01:36 AM | #15 | |
1312
Rep 10,185
Before ( though reverse lights already changed) After |
11-29-2005, 10:14 PM | #16 |
24
Rep 280
Drives: Z4 M coupe
blackline
Great write-up and details. they look good.
12-15-2005, 04:03 PM | #19 | |
48
Rep 292
2006- 530i
2006- 330i Vovlo XC90 V8 Sport - saved my life. 2004 Volvo V70R AWD- Sold |
12-15-2005, 05:25 PM | #20 | |
1429
Rep 16,628
01-26-2006, 06:45 PM | #22 |
34
Rep 776
Drives: 330i rec'd 2/17/06
looks like i gotta go get a can of squirt
JB | BBS CHs | Blacklines | HO40 | ACS Rep Roof Spoiler | H&R Sport | Hartge Rep Lip | OEM Strut Bar | M-Tech Rear
