Bumper Repair Question
02-04-2007, 12:43 PM | #1 |
35
Rep 521
What can I do about these bumps left by my front license plate holder install? They're from the screws that hold the front plate holder as they tightened it onto the bumper. The holes are TOO small to drill a larger hole to put plugs and to be honest the bumps are not that noticeable. But they'd be less noticeable if I could get the bumps smoothed out. Would heat help? Anyone work with the front plastic bumper before?
Here are some pics: |
02-04-2007, 12:49 PM | #2 |
160
Rep 5,271
Most here have either changed the bumper to either M-tech or other (I did Mstyle DTM bumper) others have done what you alluded to...drill bigger holes and get bumper plugs. I am sure someone has tried to fill and repaint...but I can't recall of anyone that has actually posted pics of results.
2006 330i | Black Sapphire Metallic | Step Auto | Navi with iDr | Sports Pkg |OEM Rear Spoiler | 3M CS35 Tint | H&R Sport Springs | Koni Yellows | Advan RS Racing Hypersilver: 19x9 et22 19x10 et20
02-04-2007, 12:54 PM | #3 |
571
Rep 7,519
Drives: 2009 E90 335i MT
Check out this thread: http://www.e90post.com/forums/showth...ight=DIY+holes
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 |
02-04-2007, 12:56 PM | #4 | |
35
Rep 521
When I picked my car up from the shop last week, there was a gouge in the bumper that happened at the shop. I showed them and they agreed to fix it. The repair job was quite good. I'm sure it required some sanding on the bumper and paint. These bumps are slightly SMALLER than that gouge. I'm hoping I might be able to DIY (or DIMyself) if possible. I used the smooth curved handle end of a screw driver to press the bump inward and it helped a bit and made the holes even smaller. Any other suggestions? |
02-04-2007, 12:59 PM | #5 | |
35
Rep 521
"3)Take a fairly blunt object (i used the phillips screwdriver) and 'tuck' the lips inward, trying to seal up the hole. Run your finger over it, make sure that it is now flush, or inverted, but should not be extroverted (i.e. no more "lips"). You can use slight force." His "lip" is my bump. I'm not sure why he describes a philips screwdriver as "blunt". I put a towel on the head of a flathead to use to push the bump inward but this is very dangerous. One slip and you can still get a nice scratch across the front bumper! Didn't work too well. |
02-04-2007, 01:15 PM | #6 | |
571
Rep 7,519
02-04-2007, 01:59 PM | #7 |
35
Rep 521
02-04-2007, 05:38 PM | #8 |
571
Rep 7,519
Spinning may not be the right word; try rotating slowly while applying the light pressure. The object of this exercise is to ease the distorted material back to its original position.
02-05-2007, 10:43 AM | #9 |
35
Rep 521
Hmmmm... it just seems like pushing anything into the holes will make them bigger. Massaging around the bump from the outside inward has made the holes a bit smaller but doesn't reduce the bump size enough.
02-05-2007, 12:12 PM | #10 |
STEVIL Empire
218
Rep 6,297
Try Clearasil....it worked to remove bumps when I was a teenager.
2007 E92 328i 6MT-Space Gray/Black Dakota/Gray Poplar w/heated seats-PCD 4/27/07 (SOLD)
2009 E90 328i xDrive 6AT-Space Gray/Oyster Dakota/Dark Burl Walnut w/ZPP,ZCW,Xenons-ED 4/17/09 - Redelivery 5/30/09 (SOLD) 2014 E84 xDrive28i 8AT-Alpine White/Black Nevada/Silver Matte w/ZMV,ZLP,494 - DD 3/14/14 (SOLD) |
02-05-2007, 01:14 PM | #11 |
196
Rep 2,485
I removed a ding in my lower valence with a hair dryer. I heated up the plastic valence and was able to get the rounded end of the handle of a screwdriver behind it and massaged the ding out.
I would think that you could heat up the bump and massage it in flush. Then use some kind of plug.
2006 E90 330i (retired)
2009 E90 335i (retired) 2012 E70 X5 50i M Sport (retired) 2016 F10 535i M Sport |
02-05-2007, 02:05 PM | #12 | |
35
Rep 521
