Sticking Door Handles anyone?
02-04-2007, 12:25 AM | #1 |
7
Rep 433
I've been a member on this forum for over a year now and havent really heard any complaints about sticking door handles on the rear doors of the E90. Since the past summer I've noticed the door handles on both rear doors of my 2006 E90 stick when I open them...and dont return to their normal position (as if they arent properly lubricated). I rarely have any rear passengers and dont often open my rear doors. I went in for an oil change the other day and brought the issue up with the dealer and was informed a number of E90's have been in with the same problem. Needless to say they are ordering me new door handles covered under warranty. Anyone here come across this problem?
2006 330i Sparkling Graphite/Sport pkg/Comfort Access/Aluminum Pedals/35% LLumar tint/Blacklines/OEM Shortshift knob |
02-04-2007, 02:49 AM | #3 |
79
Rep 449
Mine too.. on all doors.
Frustratingly if you dont notice when you pull the door shut it bounce back to ajar as the locking mechanism is out also stuck out of the way. Strangely these seems to have come on all of a sudden and to all doors even the drivers which clearly is used most. |
02-04-2007, 03:11 AM | #5 |
9
Rep 105
try putting white lithium grease...better then wd-40....stays in place and helps lubricate.
2004 BMW M3 (my car)
2007 BMW 328i (dad's car) 2007 BMW X3 3.0i (mom's car) |
02-04-2007, 03:26 AM | #6 |
56
Rep 617
I had the exact same problem and another one also. My first issue was the locking mechanism would start to grind every time I would lock the car and it just got louder and louder as time went on. With the locking mechanism and sticking handle issue, it got to the point where I could no longer open the driver door from the inside. So I would definitely have the dealer fix it. Had the locking mechanism and handles replaced and now no problems what so ever.
02-04-2007, 05:26 AM | #7 |
571
Rep 7,519
Drives: 2009 E90 335i MT
Mine started sticking in November. When I took it in for a different problem I mentioned it to the SA and I haven't had a problem with it since. I wonder if they did anything to it.
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 |
02-04-2007, 06:17 AM | #8 |
8
Rep 241
One of my rears started doing it, so I lubricated it with Finish Line all weather mountain bike lube. Seems to have done the job.
320i Sport - AW, 397 alloys
02-04-2007, 08:09 AM | #10 |
418
Rep 12,276
It's off and on with mine on both cars, but more on the E90. Cold weather seems to make it worse. I think it's a pretty typical issue.
I think it is bad luck to be superstitious |
02-04-2007, 09:30 AM | #12 |
Rep 10
I've been having the same problem on my 06 E90... Seems to get worse with the cold weather. Occassionally get a grinding noise from the automatic unlock (in the rear doors) as well when it gets really cold. I'll mention it to the SA next time I'm in... The FTM alarm went off again - I'm sure it's related to sudden drops in temperature.
02-04-2007, 11:21 AM | #13 |
14
Rep 213
Drives: 2014 550. 2015 x328d
Garage List 1972 Mustang Mach 1 [0.00]
2012 Electra Glide ... [0.00] 2017 Premier [0.00] 2022 Genesis GV70 [0.00] 2014 BMW 550I [0.00] |
Door
I also started having the problem with my driver front door. I told the S/A when i took my car in for the first service, and the new tires .The dealer said the door handle was defective so they have ordered a new one. I am just waiting for it to arrive. The weather had no effect on it some times in closed and some times it did not.
02-04-2007, 12:18 PM | #14 |
341
Rep 16,407
02-04-2007, 12:57 PM | #16 |
45
Rep 1,738
I had all 4 handles replaced my car.
There is a TSB on this ---- 511406. As for dealer that recommended WD-40 It makes a great paint remover.
2006 325i - Sparkling Graphite
2000 S2000 - New Formula Red 2007 Chev Silverado crew cab Z71 |
02-04-2007, 01:21 PM | #17 |
26
Rep 1,138
do u have the tsb print out?
wd40 isnt strong enough to strip paint, unless you let it sit there for days. Ive used wd40 to degrease my painting motorcycle wheels for years and never had a problem. |
02-04-2007, 01:24 PM | #18 |
45
Rep 1,738
No, just the w/o from the dealer:
All outer door handles have been replaced with updated models as per serv. bulletin 511406. part nos. 51-21-7-162-445 L-handle, 51-21-7-162-446 R-handle.
02-04-2007, 01:27 PM | #19 |
45
Rep 1,738
Sure, but as you said, if it is left to sit (eg spray it into the handles where it could pool and sit) it certainly could lead to paint degredation and early wear. It's not like brake fluid, but I certainly wouldn't want it anywhere near the paint of my car. Do you use it as tar remover?
02-04-2007, 09:26 PM | #22 |
177
Rep 2,355
hmm, mine do the same.....odd.
2006 E46 M3 ZCP 6SPD-Interlagos Blue - 6SPD - SSK - AA Headers -AA Tune - Navigation w/ Splashscreen Mod - 3M Crystalline Series 60 - Carbon Splitters - Swissvax Treated - Bridgestone
2012 Yamaha FZ8 - Matte Black/Grey - Michelin Pilot Pure 2CT - Vortex Rear Sets - Yoshimura R-77D & Fender Delete - Spectro Race Oil - GP Reverse Shifting |
