Mobile 1 5w30 oil in your 335i
11-24-2010, 01:56 PM | #1 |
14
Rep 125
Has anyone use M1 5w30 in your 335i? If the BMW 5w30 works for the car, why cant M1 5w30 be compatible as well? I had used 5w30 on my 2000 328ci before and no issue.
11-24-2010, 02:45 PM | #2 |
3611
Rep 10,373
Nobody knows because most stick with an oil which has LL01 rating (M1 0w-40 for example) in order preserve their warranty after that some use whatever they want.
11-24-2010, 02:47 PM | #3 |
87
Rep 302
Drives: 2022 X3MC BSM/SO
Because there is a lot more to oil than viscosity. I wouldn't recommend using the Mobile 1 5W-30, as it is not LL01 rated. The LL01 rating on the oil is mandatory for BMW's gasoline powered US engines.
11-24-2010, 03:18 PM | #4 |
342
Rep 1,325
The 30 weight rating is a range is viscocities @ 100c. From what I understand, BMW branded 5w-30 is at the thick end of the 30 weight range, close to a 40 weight. Mobil 5w-30 is thinner on the 30 weight range and not thick enough for BMW's spec. Just use the proper 0w-40 Mobil to be safe. It's the same price as any other grade.
11-24-2010, 03:28 PM | #5 |
141
Rep 1,423
Drives: '07 N54 e90, '10 N54 e93, TBSS
Oil bmw cap says castrol syntec?
E90 - H&R Touring - M3 Front Arms - Work Genosis GS-1 19x9+30 x10+26 225f 265r stretch - AA FMIC - AR DP - Cobb E30 Map +160rwhp/+200rwtq
E93 - Style 95 - RB Turbo - AR DP - Evolution RW FMIC - PTF E50 +242rwhp/+234rwtq |
11-24-2010, 03:35 PM | #6 |
11
Rep 237
yes of course you can use another 5w30 oil and it doesnt have to actually be LL01.
BUT and i repeat BUT unless you know what exactly is in the oil and what LL01 requires (or your car requires) then just dont do it.
E92 6MT Saphire Blk l Blk Dakota l Grey Poplar l Premium l Sports l Comfort Access l Cold Weather l Nav+Idrive l Bluetooth l I-Pod & USB l PDC l Logic 7 l
City Car: 2005 Saab 9-3 TiD Retired: E60 530i |
11-24-2010, 04:50 PM | #8 |
11
Rep 237
and because castrol makes the "bmw" oil
11-24-2010, 10:03 PM | #11 |
90
Rep 2,707
5w30 is too thin. Don't do it. SAE ratings have numerical ranges, just because BMW's 5W30 oil is the right one doesn't mean that another vendor's 5W30 is the right one as well.
For M1, use 0w40 as others have said.
zhpregistry.net - ZHP stats and free classifieds.
11-24-2010, 10:10 PM | #12 |
159
Rep 5,689
Really, many have used as high as 10w-60 in high temp climates with out issue. What would be the problem with using a lower weight in a very cold climate. In the owners manual of my 911 it has a sliding scale of what weight you should use based on temperature.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(1addicts.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
11-25-2010, 10:43 AM | #13 | |
342
Rep 1,325
I've heard (on BobIsTheOilGuy.com) that 15w-40 (non-synthetic) is a very good choice for many German cars in warmer climates. The UOAs show excellent results, even in modern german cars. Its a very tough oil. Also, I think Porsche suggested 15w-40 for most of its cars up until not very long ago. Curious if yours suggests that? What year is yours? I wrote this on bimmerforums a while ago.... "The Mobil 1 and Castrol 5w-30 are technically the wrong oils, but I highly doubt there ever would be an issue, especially at the speeds US freeways run at. I think people get a little too wrapped up in using only BMW LL-01 oils. The BMW LL-01 specification is simply just an all-purpose, all-season, fuel economy minded, long-oil drain standard that BMW has come up with. It's there to make everything simple, not be a magical oil. It meets a value that makes it thick and robust enough for high-speed/high-temp driving (HTHS ≥3.5), but not too thick that it will hinder fuel economy too much. It's a synthetic which will help it meet the long oil drain intervals that BMW desires. And, it meets the specs of a 0w or 5w oil, eliminating the need to change to a different oil seasonally. That all makes it a geat choice for what exactly it's made for. Going the full drain interval your computer suggests AND starting your engine when it's -20F AND driving 140mph on the autobahn on a hot summer's day AND getting the fuel economy that BMW says it will achieve. I still think there is some smart discretion that can be used if one or more of these factor do not matter to the user." That being said, there's really no reason not to use a BMW LL-01 oil for probably 99% of people. Unless you're seriously racing and want something like a 10w-60 or 20w-50. Or, are looking to save money and use a non-synthetic such as 15w-40. Last edited by CirrusSR22; 11-25-2010 at 10:55 AM.. |
11-30-2010, 09:54 AM | #14 |
552
Rep 6,563
how about AMSoil 5W-40? Anyone use this for their beloved BMW?
http://www.amsoil.com/mygarage/Produ...006+BMW+330i+F BTW...My car is way out of warranty too. Any thoughts on this oil.
under construction! |
11-30-2010, 10:02 AM | #15 |
369
Rep 8,693
Drives: 06 330i
i have been using mobil 1 5w-30 for over 20000 miles in my e90 with no problems. ill be having my oil tested by blackstone to see what they really think of 5w-30
11-30-2010, 11:32 AM | #16 |
3611
Rep 10,373
12-08-2010, 11:20 PM | #17 |
14
Rep 125
12-09-2010, 07:08 AM | #19 | |
3611
Rep 10,373
Just an FYI on oil analysis from Blackstone. Their equipment, like most everyone else, can only detect wear metals within a certain size. Larger pieces will not show up on their results. |
12-09-2010, 07:44 AM | #20 | |
3611
Rep 10,373
Search VISOM and Mobil 1. In this day in age the additive packages have contribute as much to the performance of an oil as the base stocks. Not to mention that many synthetic's usually are a mixture of different base stocks. |
