e92 335i - confessions of an ex RX8 owner. Warning: may offend some viewers!
02-02-2007, 07:33 AM | #1 |
11
Rep 199
Drives: E92 335i 6MT M/Blue, Jade Grey
I preface this thread by making the point that I love my 335i coupe to bits. I went into the purchase decision with my eyes wide open, and with previous BMW experience having owned a E46 325i sedan before I bought my Mazda RX8. After 7 weeks of "post RX8" E92 ownership I remain entirely happy with my choice, in the context of my current needs. I also recognise that all cars are compromises, and BMW's are no exception.
None of what follows diminishes my enthusiasm for E92 335i's truly wonderful engine, finish quality, yummy noise, practicality, exquisitely balanced handling on smooth roads etc etc. What it does, though, is signal that -in this class of car at least- BMW haven't quite reached perfection -yet. Please also bear in mind that my 335i is Aussie spec, which means standard 18" RFT's (RE050A), on sport suspension (FWIW I believe the RFT's have been a relatively minor contributor to my criticisms below). That's the background. Now here is the controversial bit: Although it's an incredibly accomplished all rounder, there are a number of important respects in which the stock e92 335i is plainly inferior as a driver's car to the more tightly focussed, but half price, RX8. 1. On truly demanding ( read very tight,twisty, bumpy and poorly cambered) roads, the E92 is quite a handful. The car bounces around both vertically and laterally, frequently losing contact with the road surface. Left in default mode, the traction control light flickers constantly, reflecting the car's inability to get power to the ground in these conditions. To achieve respectable progress engaging DTC is essential, to overcome the incessant electronic intervention. The short suspension travel also results in occasional bottoming. On these roads you never lose the impression that the car is carrying quite a lot of weight. In very tight corners there is some front end push, and in these circumstances turn in is not as sharp as it could be, especially if you are simultaneously working hard to wash off speed with the brakes. By contrast, the RX8 simply murders such roads. Its suspension compliance and suppleness is extraordinary. It sails over bumps and camber changes that confound my 335i. And it does this whilst preserving accurate turn in and maintaining a feeling of lightness and agility that appears to be more or less absent from the BMW lexicon. My suspicions: amongst other things ( the RX8's lower weight, lower centre of gravity etc) what we are seeing here are: - the limitations of BMW's front MacPherson struts vs RX8's well developed alloy double wishbones, AND - a development program that spends too much time on the lovely, cultivated, smooth roads of Northern Europe and not enough time on the truly demanding drivers' roads of, say, the UK ( did anyone say Wales??) or remoter parts of the US, or even insignificant, out of the way little Australia. 2. The 335i steering is good - certainly better than my E46 - but it lacks the precision of the RX8, which also manages to reduce its assistance as speeds rise in a beautifully controlled way. By comparison, the E92 steering is quite "glutinous" - it feels like all its linkages are embedded in thick grease. Unlike the RX8, it's heavyish at low speeds, but paradoxically no more weighty, nimble or confidence-inspiring at high speeds. 3. The 6MT 335i has an olde worlde, long throw gearshift which in my car (and some others', it would seem) is also occasionally obstructive for no apparent reason. I say this having owned manual cars exclusively for the past 28 years. As manual shifts go, E92's has a satisfyingly mechanical feel, and is certainly much better than average. But the RX8 shows it can be done far,far better. Subjectively its shift is half the length; its throws are correspondingly far shorter and its gate is better defined and incredibly slick. You can flick it with your little finger if you want to,and it will never,ever baulk. (You won't be surprised that procuring the BMW accessory short gearshift lever is high on my agenda.However, it doesn't seem to be available here in Australia so I'm still researching how I can conveniently get it!!!) 4. Although BMW likes to promote the throttle responsive nature of their cars, my experience does not completely confirm this. Throttle response on my early "drive by wire" E46 was plainly worse than on some - supposedly mundane - Hondas I've driven. The E92 is clearly better, but the RX8's drive by wire throttle is, quite simply, a precision instrument. Despite a 48KW power defecit and 180NM torque defecit (Aussie versions) the little Mazda manages to feel incredibly responsive, because each tiny fraction of accelerator pedal travel produces an immediate, enthusiastic response from the engine. By comparison E92's response is a little doughy (like the E46) and also sometimes unprogessive ( presumably due to turbo-related artifacts). So there you have it. Does any of this diminish my joy in driving/owning the E92? No, not at all. I've been nuts about Bimmers since I was 15, and I've spent half a lifetime getting to the stage where I could afford to buy a serious perfomance BMW, which costs the equivalent of US$94k here ( albeit standard with a lot of stuff that is optional in the US). Clearly E92 is a truly wonderful sports sedan ( coupe?). The bits that are good are very,very good. But that doesn't mean it is beyond reproach... I hope my excessively lengthy comments provoke thought, but not anger. If you are offended, try to remember I probably love this car as much as any of you..... Nick |
02-02-2007, 07:42 AM | #2 |
Shadow Warrior
139
Rep 2,095
Thanks for the write-up.
BTW for the uninformed, an RX8 is a Mazda (only caught one reference to it in the post so I was a little lost till I looked it up).
335i E90 / Arctic / Gray / Burl Walnut / Steptronic / ZPP / ZSP / Paddles / CA / Nav / PDC / OEM Spoiler
Mods: PIAA Angel Eyes, Rear Fog Switch, Escort X50 Blue hardwire, 30% Charcoal Llumar Installing soon: Rear Power Outlets (Happy Robot mod!) |
02-02-2007, 07:44 AM | #3 |
275
Rep 9,218
Excessive intervention of DSC and delayed throttle response have led to regular criticisms of the newer BMW's.
Switching to DTC will help with both (I believe throttle delay is occasionaly down to engine torque being damped by DSC). I think the gearbox WILL improve with time. Every BMW I have had (7 so far) has been very stiff and notchy to begin with. I've got 8000 miles on my car and the gearchange is only just starting to feel 'right'. My feeling is that the RX8 is just a bit more focused. The 335i leans slightly more toward refinement and in that it loses a little bit of 'edge'. |
02-02-2007, 07:49 AM | #4 |
11
Rep 199
02-02-2007, 07:49 AM | #5 |
18
Rep 220
Perhaps dumping the OEM run flat tyres would help the handling side? RE-050A even the normal version is not good, quite a disappointment, try PS2. OEM shocks I think they're by Sachs? Try Bilstein like ur previous Mazda am sure would help the ride side.
I am actually a proponent of strut front rather than double wishbone front, I find strut a lot more communicative. |
02-02-2007, 07:53 AM | #6 |
550
Rep 6,563
I actually read the whole thing (but not sure if I remember all the details). Overall, I did not get the impression that you hate the e92 or want to trade it in for something else. I have never driven the RX8 so I can only take your word for it. I cannot disagree on something I have not experienced before. Everyone has their own opinion about everything. Since you have owned both cars, it is only right that you feel the way you do. Good reading!
I still like my e90 alot.
under construction! |
02-02-2007, 07:54 AM | #7 | |
11
Rep 199
And you are spot on re the "focused" bit - hence the reference in my post.. |
02-02-2007, 07:58 AM | #8 |
125
Rep 4,172
There isn't a lot the OP is going to be able to do to make the 335i feel like an RX8 - I am not even sure he wants to; sometimes comparing cars with different objectives is fun, but it's always a grass is greener thing. I liked reading this; the RX8 is a great car in a completely different way than the 335i is a great car.
02-02-2007, 08:02 AM | #9 | |
11
Rep 199
02-02-2007, 08:05 AM | #10 |
252
Rep 6,664
Great writeup..
E90 325XI, MYSTIC BLUE ON BLACK/ALUM, STEP, NAV, PDC, CWP, XENON, SIRIUS, ALARM, MUD GUARDS, CLEARBRA, CHROME GRILLS AND TIPS, VALENTINE 1 (HARDWIRED), HO CERAMIC 40%, 161'S, REAR FOG MOD, LUX 4.0, BLACKLINES, OEM PEDALS, MTEC FOGS, GRUPPE-M REP INTAKE. 156'S AND RUBBER MATS FOR THE WINTER. |
02-02-2007, 08:11 AM | #11 |
7
Rep 128
well - the main problem is that the e92 is not a true sports car... I feel the same way about my S2000 as you feel about the RX-8. The handling on those cars is truly superior - but then again, they are in a different class.
325i Jet Black on Black interior, Alum trim, ZSP, NAV, Step, Xenons.
02-02-2007, 08:13 AM | #12 |
Completely obsessed with detailing
299
Rep 15,442
Drives: E90 SG 330i, white Scion tC
I like your comparison of the two. I guess this is a matter of what do you want in your car and are you willing to put up with it? I think it's a general assumption that rotary engines are awesome but will have some trouble with its reliability. The RX8 really DOES look great though.
To me, the E90 I drive feels great as a sports car. The other sports car i drove before the E90 was the GDC Impreza STi. It was the best driving experience of my young life! Then I started driving the E90 330i and I knew it wouldn't be the same. I still liked the E90 for its amazing handling ability. |
02-02-2007, 08:15 AM | #13 | |
11
Rep 199
I think the RFT's are 20% of the issue, the rest is short suspension travel, Macpherson struts, and dampers aligned to gorgeous Euro secondary roads. I'll predict right now the next gen 3 series will NOT run strut front suspension. |
02-02-2007, 08:32 AM | #14 | |
11
Rep 199
We should all celebrate the fact that eccentric tightly focused affordable cars like RX8, Lotus Elise, Mitsubishi EVO etc etc exist, because they help raise the standards in a few areas that are meaningful to enthusiasts on this and doubtless many other forums like it.... |
02-02-2007, 08:55 AM | #15 |
12
Rep 247
I really loved mazda,
The miata when it first came out was good, and the RX7s and 8s, I wish they just focused a little more on the power plant in ALL their cars... but as a 4 seater sedan or coupe with all the bells and whistles BMW is on top. ~fk |
02-02-2007, 08:57 AM | #16 |
18
Rep 220
Also forgot to mention one of the main culprits of the E92 335 is the 1,600kg weight! Versus the RX-8's 1,300 kg sets them 300kgs apart! I remember my E36 325 was abt 1,350 kg and I didn't think that car was light.
02-02-2007, 08:59 AM | #17 | |
11
Rep 199
Apart from RWD, the Bimmer is so incredibly different in design and execution. It's fun to have owned both extremes though.... |
02-02-2007, 09:10 AM | #18 | |
Rep 91
02-02-2007, 09:14 AM | #19 |
Private with no class
9
Rep 649
amazing what 300kg can do hey?
nice write-up!
02-02-2007, 09:15 AM | #20 | |
111
Rep 1,772
Why is this? My E90 323i does not make 300+ ft-lbs of torque across the entire rev range... the power band is more progressive and this makes the car easier to push to the limit. The 335i has so much torque that it can really unsettle the car if you push even a little bit too hard. The RX-8 has, and I am not being a jerk here, an anemic level of low end torque and a very top heavy power band which will automatically make it an EASIER car to drive to the limit. I think that you may be confusing easy to drive with "driver's car" a little bit. The Rx-8 is sexy looking and unique and a cool track car, I agree with you. The 335i is like a 1000cc sport bike... a bull in a china shop, so to speak and it requires almost a professional to extract its limits effectively |
02-02-2007, 09:17 AM | #21 | |
11
Rep 199
HOWEVER...here's a point that I doubt BMW will ever surpass (in 3 er class at least). If you open the engine bay of an RX8, you will see that the entire engine is behind the front axle. What's more, the engine casing ( rotary equivalent of engine block) is at about knee height. The implications are enormous: because of the low centre of gravity and polar inertia, RX8 can run relatively soft supension/damper/roll bar settings to cope with nasty, bumpy road conditions, while preserving outstanding handing/agility/turn in. How friggin' clever is that??? Should mainstream European manufacturers ignore this stuff? I don't think so. |
02-02-2007, 09:18 AM | #22 |
275
Rep 9,218
My gear levers fine - but I have the m-sport shortened version
