335i Manual Transmission oil lube of choice?
11-16-2010, 09:44 AM | #1 |
146
Rep 942
What kind of lube is BMW putting in our 335i's? Non-AWD. Redline is saying to put ATF in it! Other say the 70/80 GL4, or MT-90. Any ideas? Looking to stick with OEM BMW fluid. I called the parts dept and he didn't even know. Even with the VIN.
'07 335i Sedan, base pkg, 6spd Manual, Procede 3 V5 w/NLS, Macht Schnell Downpipes, 18" Staggered 313's w/Conti DWS's, OS Giken TCD LSD, VAC Street Diff Cover, Dinan Oil Cooler, Dinan Intercooler, Akebono Euro Pads, CDV Removed, Black BMW Grilles, Interior & Exterior white LED lighting, LUX Angel Eyes, Debadged, Blend V1 mount, Llumar ATR Tint.
11-16-2010, 10:03 AM | #3 |
87
Rep 302
Drives: 2022 X3MC BSM/SO
I'm using Redline D4ATF in mine. I originally used Redline MTF, but it seemed to be too thick and caused some notchy shifting. The D4ATF seems to cause much smoother shifting - especially when it is cold outside.
11-16-2010, 09:27 PM | #4 |
106
Rep 935
11-17-2010, 06:47 AM | #5 |
146
Rep 942
I'm 99% sure/betting my car is spec'd for MTF-LT-3. 3rd revision lifetime manual trans fluid. which is basically ATF. I did read the Redline article saying to run the D4ATF. Have to wonder why the OEM BMW fluid is not good...
11-17-2010, 07:46 AM | #6 |
47
Rep 1,160
BMW dealers will charge about $20 a half a liter and I believe you need 3 quarts. You get redline or royal purple you'll spend half the price and get better results. I put redline atf in mine and works fine.
But most dealerships will want you to get under your car and get the model number off your tranny and if u can see the color of the sticker.
Monaco Blue 330xi - Terra Interior/6-MT/Sport/Premium/Cold/CSL's/M3 Spoiler Lip/Black Kidney's
11-17-2010, 09:49 AM | #7 |
146
Rep 942
^10-4 to that. They want me to give them the trans label. I'm probly going to run Redline ATF (assuming I check my trans and it does have the LT-3 sticker).
Looks like the Trans is requiring a Dexron VI syn ATF... So I could use Redline D6, or Mobil 1 ATF etc.
11-18-2010, 05:36 PM | #8 |
290
Rep 864
Yes Redline Atf
BUT if you have a CPO then I would go OEM as I did at 38K from Tishcer. Saving the left over 2.5 qts for anyone local who wants a super deal.
I would change the Redline every 50K. I have used MTL in a prior MT and it worked very well. |
02-15-2012, 11:34 AM | #12 |
290
Rep 864
Yea - Redline Trumps Bmw
I do understand and see that ATranny Fluid in MT has been reported to
eliminate knotchy shifts. . . This would go against BMW and even MMiller -- SO I chose OEM . . If out of warranty -- I have CPO -- so past 100k --- I may choose Redline --- but until then OEM. . . My shifts are very smooth -- I changed around 40k and will change again with OEM at 80k. . Warranty Claims -- dealer checks fluid. YOUR CHOICE. |
02-15-2012, 01:33 PM | #13 |
146
Rep 942
I'm ok with OEM fluid, but I'm not sure where to get it... the dealer keeps trying to sell me like a 55 gal drum of it.
02-15-2012, 06:13 PM | #14 |
290
Rep 864
OEM FLUID
Tischer / getbmwparts.com or bavauto.com
Make sure that you know the correct fluid off the sticker on the trans . . You should have enough for 2 changes --- so ge a buddy and split the cost. . . |
02-17-2012, 12:11 PM | #15 |
146
Rep 942
Nice. I have the newer thinner spec. I've already checked the trans label during an oil change.
