BMW M3 Forum (E90 E92)
BPM
      11-10-2010, 10:50 PM   #1
tha_good_life
tha_good_life's Avatar
376
Drives: 21 X6MC
2021 BMW X6MC  [10.00]
2010 BMW M3  [8.68]
Removing Headlight Bolts
This sounds like a dumb question but does anyone know how to remove these bolts including the bolts on top of the headlights? The bolts seems to have loctite on them which makes it impossible to remove without breaking the clip.
      11-10-2010, 11:00 PM   #2
sor
sor's Avatar
3102
Drives: 2023 iX M60 Oxide
2023 BMW iX M60  [0.00]
impact tool? I assume you're installing your orions?
      11-10-2010, 11:22 PM   #3
tha_good_life
376
Drives: 21 X6MC
2010 BMW M3  [8.68]
yes and I can't believe the easiest part is giving me the most problem!
      11-10-2010, 11:36 PM   #4
Leozap
Drives: AW E90 M3
Shouldn't be a problem if you just unscrew them? If you are using the star head screw driver (TX30?) and turn the screws, do they even turn?
11 335is, KW1, M3 bits and what not
08 M3 Sedan 6mt, loaded, modded to the bone
Old: 04 M3 SMG
      11-11-2010, 01:24 AM   #5
tha_good_life
376
Drives: 21 X6MC
2010 BMW M3  [8.68]
They turn until it gets stuck. Turning it more will snap the bracket which I broke 4 today. Each of the bolts on the headlights are sealed with Loctite which made it impossible to remove. I bought a mini torch to heat up the bolts to loosen the loctite in order to remove it.
Taking off the headlights alone took me 2+HRs to figure out how to do it.
      06-03-2011, 07:36 PM   #6
bimmernupe
bimmernupe's Avatar
Drives: 08 E92 335i
2008 E92 335i  [10.00]
I took those out with no issue using a torx. I was trying to replace my headlight assembly and thought by removing it would allow for easier access to the torx bolt under the assembly.
How did you mange to remove the bolt under the bottom of the assembly? the head faces toward the engine and radiator.
MY FAMOUS INDEPTH ED TRIP REPORTED Welt 27.10.07 l Drop-Off Bremerhaven 05.11.07 l Port NJ 26.11.07 l PCD 21.12.07
2008 E92 335i Barbera Red l Saddle Brown l Aluminum Trim l ZSP l ZCW l ZPP l CA l Nav l HD Radio l 6MT l PDC l 6FL
      06-04-2011, 12:49 AM   #7
JCtx
258
Drives: No BMW yet
Those bolts shouldn't be 'loctited' IMO. At least not with red one. Remember loctited bolts break loose MUCH easier with sudden impact than steady force. Just hit the ratchet with your (gloved) hand and it should easily give up. Those torx heads take some abuse. I wouldn't use an impact wrench, however. If not able to break them loose hitting ratchet with palm, then some heat is in order. Good luck.
      03-29-2012, 09:26 AM   #8
jvitas
10
Drives: 2009 M3 Coupe
I just removed mine and slow steady turning worked best. Didn't break one clip. Used a 1/4" ratchet.
BMW didn't use Loctite but it is something similar. More like hardened pipe dope. A little heat will definitely help. I'm sure they did this to keep the headlights from going out of alignment.
The bolt under the headlight is almost impossible to remove but it can be done using extensions and a universal. However you need to take off the support bracket that the bottom bolt is screwed to (4 more screws) in order to get the light assembly out and that will give you easy access to the bottom bolt.
      08-07-2012, 09:49 PM   #9
snowmants
snowmants's Avatar
Drives: '06S2K,'11EVO,'11Jeep,'13GL450
2008 BMW E90 M3  [10.00]
Anyone have pictures or description of where these other four screws are? I am assuming two of these are the ones pictured here? Where are the other 2 and are they standard hex or torx?
I am having a heck of a time getting to that last torx bolt under the headlight!
'06 Honda S2000 #555 TT5
'16 Porsche GT4
      08-08-2012, 10:46 AM   #10
snowmants
snowmants's Avatar
OK I found them. They are behind the headight in the wheel well and they are 2 more of the 30 Torx bolts like the ones pictured.
I got the first headlight out. That torx screw underneath the headlight took me 2 hours and 2 trips to sears to get out.... Once I had the right setup on my socket wrench I was able to slowly loosen it and finally remove it.
EDIT: I did the second headlight and instead of cramming a socket wrench in to undo the TX30 bolt directly under the headlight, I just removed the headlight bracket that the headlight sits on and headlight as one piece. It took like 10 minutes vs. 2 hours on the first headlight I did. I wish I had known this on the first headlight!
'16 Porsche GT4
m3post
