11-10-2010, 04:54 PM | #1 |
54
Rep 244
E-Brake Cable (Tighten)
Can anybody post a quick "how to" tighten the ebrake cable?
Mine is abit loose, car rolls back unless the ebrake is pulled up very high. |
11-10-2010, 05:33 PM | #2 |
///M Fan
366
Rep 2,159
Drives: '09 E92 M3 IB/'17 f85 X5M LBB
I think that if you pull the boot off, the adjusting nut will be right there.
'09 E92 ///M3 Interlagos Blue,6MT,Silver Novillo Leather,CF Trim,Premium Package,Technology Package,Cold Weather Package,Premium Sound,19"Wheels,Moonroof-Toy/'17 X5M, Long Beach Blue, Executive Package,Technology Package, Lighting Package, Driver Assist, Full Mughello Red Interior, 21" wheels-Toy/'14 535i with M Sport and 19" wheels-Daily
BlvckMagician0.00 |
11-20-2010, 07:36 AM | #3 |
Rep 8
Had a weak and unbalanced handbrake, and this is what i did:
Pry off the handbrake boot with a trim removal tool Under the lever, there's a spring loaded cable tensioner. Push this backwards with a large screwdriver or a steel rod until you hear a click and the tensioner is held back. Loosen one wheel bolt on each rear wheel. Put gearbox in neutral and raise both rear wheels. (You cannot do one wheel at a time because of the LSD.) Rotate road wheel until you see a small toothed adjusting wheel through the bolt hole. It's partly hidden by a spring. Use a flash light. It is located at one o'clock or eleven o'clock, can't remember which. Now you should flick the little wheel with a large flatbladed screwdriver to tension the brake. On the left side, you flick backwards and upwards. On the right hand side, you flick forwards and downwards. Tension until you cannot move wheel, then back off about 8 tooths. Make sure road wheel is free to spin. Lower car, tighten wheel bolts. Use the flat screwdriver to push the arresting hook on the tensioner to the right. It will then spring out. Did a vehicle inspection the other day where the hand brake was tested, and it looked great! |
jvictormp881.00 BlvckMagician0.00 |
12-07-2010, 01:46 AM | #5 |
258
Rep 5,012
I'm mechanically inclined and can't make any sense of that. Next time I have the wheels out for a brake bleeding will investigate. If we have a drum-in-disc parking brake system, we should be able to adjust it from the 'Y' or by the lever.
12-12-2010, 11:34 AM | #6 | |
96
Rep 545
I have attached the diagram from realoem.com The rear parking brake shoes have an “adjustment screw” (#3) at each rear wheel. You’re setting the parking brake shoe clearance at each wheel first then if needed adjust the brake cable. |
shimmy232348.50 |
12-12-2010, 06:13 PM | #7 |
686
Rep 6,845
Drives: 2018 Audi RS5 coupe
but all this is assuming both sides are not in sync, and i am trying to adjust them
assuming both sides are in sync and you just want to tighten the hand brake must i still do the whole pull off a wheel and adjust the hidden screw etc? |
12-13-2010, 06:03 PM | #9 |
96
Rep 545
12-13-2010, 06:20 PM | #10 | |
96
Rep 545
I have not done this adjustment on my M3 with only 15K miles. I only use the park brake lever when the vehicle is stopped (parked). If you go back and read the post by ph_gbg he said you can just remove one wheel bolt. Then you will see the adjustment screw through the lug hole. This will be the only way that you will know that "both sides are in sync". You are confirming that the shoe clearance is equal on both sides. It's important that when adjusting the parking brake it does not make either wheel drag when the parking brake is released......or it just kills the fuel mileage. and destroys the parking brake shoes. |
12-14-2010, 01:47 AM | #11 |
258
Rep 5,012
Thanks man. Drum-in-disc is the best parking brake system IMO, and that's what we have .
Hey Ken, I wonder if the parking brake can be adjusted by pulling the lever in reverse, like on some other cars. Looks like a ratchet-type adjuster to me, although it can also be turned with a screwdriver. Mine is perfect too with only 6K miles, but somebody might give it a try and report back . |
12-14-2010, 11:10 AM | #12 | |
96
Rep 545
12-15-2010, 10:56 AM | #13 |
686
Rep 6,845
so is there any way to tighten the handbrake WITHOUT doing the whole screw in the hub step?
can i just adjust it somehow from the hand brake lever? |
09-16-2011, 02:38 PM | #14 |
68
Rep 531
Bump. My girlfriend's 328 xi needs tightening on the hand brake.
Gone but not forgotten...2009 E90 Le Mans Blue M3 6MT De-Chromed, Rogue SSK, Brembo BBK, Eibach Pro Kit, Eisenmann Race Black, MS Filter. 1998.5 Titanium Silver E36 M3 Coupe NASA GTS2 Race Car.
09-25-2011, 01:28 AM | #15 |
chris
278
Rep 12,144
wished there was an easier way to tighten the ebrake... someone should make a DIY with pictures for the steps above.
Current: 2013 F10 M5 & 2016 Mini JCW 2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone) |
10-23-2011, 09:04 AM | #16 |
34
Rep 715
I just adjusted the handbrake by turning adjustment screws thru hole for wheel bolt , but I didnt do the whatever thing with handbrake lever. I saw the spring with special washer on it , but it didnt budge , and I didnt want to use more force or time and energy on it. The handbrake is now working again.
But I have to go all the way up with the lever to make it hold properly. Is there any way of getting it to hold earlier? That got to do with loosening the spring? |
05-26-2012, 08:50 AM | #17 |
34
Rep 715
Bump
Vargas S2 turbos|VAC S3 Cylinder head|RR DPs|RR MPs|Supersprint X pipe|Remus Quad Sport mufflers|aFe Stage 2 Si with scoops|Forge DVs|ER CP|BMS meth elbow|Aquamist HFS-4|Walbro 450 E85 LPFP|AA FMIC|BMS OCC|MHD|P3 Boost Gauge|Ohlins Road & Track + camberplates|M3 sways F/R+ Ground control endlinks|Vorsteiner v303 19"|Michelin PS2 sport|Quaife LSD|Vorsteiner V35 CF hood|CF CLS trunk|Duke Dynamics quad diffusor
06-23-2012, 12:20 AM | #18 |
96
Rep 473
Does anyone know if it's safe to reuse Macht Schnell's stud conversion kit with this? (I'll reapply loctite of course)
2011 e92 JzB 6MT
Akrapovic Evolution, ESS Tune, KW V3 |
03-01-2019, 03:35 PM | #19 |
592
Rep 769
I'm having the opposite issue where I disconnected my ebrake to take my rear subframe out and then after reinstalling, the ebrake won't fully disengage and is lightly scraping while driving. Would this potentially be caused by the same imbalance between the top side of the cable and the wheel side? When I disconnected the cable, I did *not* touch anything related to the handle inside the cabin - was I supposed to? Also I have studs installed, so I guess I'll have to just remove the rotor. Any help is appreciated.
03-07-2019, 10:29 AM | #20 | |
503
Rep 1,055
You could try loosening the cables a bit at the handle. I have my subframe out now and will have to keep an eye on this.
03-07-2019, 10:42 AM | #21 | ||
592
Rep 769
03-07-2019, 12:54 PM | #22 | |
503
Rep 1,055
My knuckles are are also laying with arms attached. I've been gentle on the dust shield by supporting the knuckle with a piece of 2x4.
