has anyone removed the e92 lower front mesh?
01-28-2007, 05:13 PM | #1 |
Motorsports Photography Guru
33
Rep 236
has anyone done this? i just tried it but i had no success. i saw a post on how to remove the e90 ones. they said to just pull on the mesh and it will come out. that was not the case for the e92. the bumper has clips the slide into slots on the mesh. i was able to push the mesh towards the car to unsnap them but couldn't get it out from behind the bumper. do you need to remove the bumper to get them out? any help would be much appreciated. i want to paint them black or buy some 328 black mesh. thanks.
-Chris |
01-28-2007, 06:38 PM | #2 |
STEVIL Empire
218
Rep 6,297
Hey Chris,
Can't help you with the removal since I don't have my E92 yet, but I think you would be able to find an E92 328i owner that would love to swap their black mesh for yours. No need to paint yours or buy the black ones if you could pull off a switch.
2007 E92 328i 6MT-Space Gray/Black Dakota/Gray Poplar w/heated seats-PCD 4/27/07 (SOLD)
2009 E90 328i xDrive 6AT-Space Gray/Oyster Dakota/Dark Burl Walnut w/ZPP,ZCW,Xenons-ED 4/17/09 - Redelivery 5/30/09 (SOLD) 2014 E84 xDrive28i 8AT-Alpine White/Black Nevada/Silver Matte w/ZMV,ZLP,494 - DD 3/14/14 (SOLD) |
01-28-2007, 08:03 PM | #3 |
50
Rep 390
I removed my center mesh by pushing it in as you described. You can bend/twist it enought to get it out of the hole. Tape up the inside edges of the bumper so you do scratch it on the way out.
I didn't take out the left or right so I'm not sure if the same would be true for those. Good luck. |
01-28-2007, 08:19 PM | #4 | |
33
Rep 236
-Chris |
01-29-2007, 05:57 AM | #5 | |
517
Rep 18,858
01-29-2007, 11:03 AM | #6 |
Year One of the 1
Rep 93
why are you swapping to the black one? i have the ugly color black mesh, i like the sliver one personally, maybe we can swap. let me know what you think.
02-01-2007, 04:01 PM | #7 |
33
Rep 236
i went through the fender well to try and get out the side pieces. bmw really did a good job at making this a major pita to remove. there is so much extra plastic unseen plastic around the mesh that you can't just pull it out. to make it more difficult, the mesh is clipped to the bumper, and to the ducts that flow air into the wheel well. if you can jack the car up and shine some light in there i am sure you can see how to remove the air duct so you can get the mesh out. for me, it just wasn't worth it. the damn mesh is staying silver! haha.
-Chris |
02-01-2007, 04:07 PM | #8 |
125
Rep 4,172
I got my mesh out but I had to jack up the car. I just removed the plastic shroud underneath the car then popped the mesh out (it has a ton of clips though, so as you mention without light/room it'd be a major pain).
02-01-2007, 04:17 PM | #9 |
STEVIL Empire
218
Rep 6,297
Glad to hear it's put in so well. I would be concerned if it was too easy to remove.
02-01-2007, 05:00 PM | #10 | |
33
Rep 236
-Chris |
02-01-2007, 05:38 PM | #11 |
125
Rep 4,172
Hey Chris; when you get the shroud off you need to pull the duct away from the bumper a bit and create an opening big enough to unclip the mesh then pull it through. I could have unclipped it and pushed it out but I didn't want to scratch the paint, so I pulled it down through the opening. It was sort of a pain but on my car at least I didn't need to remove the ducts.
02-12-2007, 05:46 PM | #12 |
125
Rep 4,172
Bah, update on mine - I finally got around to removing them fully and painting; problem is I broke one of the tabs. Boooo... the side mesh is in really, really well (as you know). I am going to wait to put my spring wheels on and just do it when the car is on a lift. Pain in the butt, looks like crap with my black grilles.
06-05-2007, 10:19 AM | #14 |
396
Rep 3,893
i purchased black mesh from BMW. but not too sure where to start. any body has pictures??
06-13-2007, 06:40 AM | #15 | |
112
Rep 1,040
Drives: 2007 335i Convertible
06-13-2007, 08:20 AM | #16 |
15
Rep 311
Sucks to hear it's such a PITA. I was also hoping to swap mine out for black since my E93 is black, but sounds like it's not worth the trouble without a lift.
06-13-2007, 03:38 PM | #18 |
193
Rep 2,443
06-13-2007, 03:44 PM | #19 |
56
Rep 1,047
Ordered mine today from Rallye BMW in Westbury NY. Should get them on friday I was told they will be $56 dollars including sales tax.
"If you're not intense..you're past tense"
"..Greed is good, greed works.." 07 E92 335i,Sport,I-drive,Cold Weather,Bluetooth,Beyern Mesh 19",M-Pedals,Rear Fogs,Gp Thunder,Carbon Roundels,Coming Soon JB2,Vorsteiner Decklid,OEM Aero LipRIP9/8/06-12/11/07 Gone but never forgotten |
06-23-2007, 11:25 PM | #20 |
11
Rep 204
my center mesh was damaged by a copper pipe, I removed the mesh and installed a new one, took like an hour.
I ordered a new one from BMW. locate where the clip are from the new mesh, with a L allen wrench which i taped up to prevent scratches, unclip the clips using the wrench and pushing it inward. taped up the area and swapped in the new mesh and using the L wrench to pull the mesh at the clip points until it clip into place.
E92 335i Graphite/ Grey poplar trim/ Black Dakota/ Sports/ Premium/ Auto/ Paddle/ Heated seats/ Nav/ Sat. Radio/ CA/ 19" V710/ Painted reflectors/ Rear fog light
