Intercooler piping connection question with ETS FMIC - does this look correct?
11-03-2010, 02:15 PM | #1 |
117
Rep 557
I was installing something else under the hood the other day and noticed this on the passenger side where the ETS intercooler silicone coupler meets the OEM piping:
As you can see there's a lip on the OEM pipe that's exposed and it seems like that lip should be underneath the coupler for a tight fit. When I installed the intercooler I'm pretty sure I got the coupler well over the OEM pipe and it was secure. I'm wondering did my coupler slip off or are the maybe two lips on the OEM pipe (or maybe one and it's just further from the end of the pipe)? If anyone can remember it'd be appreciated before I have to remove the intercooler to check. |
11-03-2010, 02:43 PM | #2 |
3398
Rep 6,589
Drives: BMW
hmm, I don't have the ETS IC but I would think the coupler should slide over that lip to ensure the most secure fit. Maybe someone who has installed will be able to chime in.
bump for ya. |
11-03-2010, 02:58 PM | #3 |
151
Rep 1,809
Now you see why an accordion hose is needed instead of a straight hose ? The engine shakes a lot during RPM changes and the intercooler is fixed on the car. The aftermarket IC manufacturers should at least make an accordion hose an option.
11-03-2010, 03:05 PM | #4 |
117
Rep 557
Well I'm not sure that it's not connected securely, that's why I'm asking. If the OEM pipe has a lip like the top drawing here it's a problem because it's barely attached. If it's like either of the bottom two it's fine. I just don't recall. If someone else with an ETS FMIC could check their upper passenger side that would be much appreciated.
11-03-2010, 03:13 PM | #5 |
76
Rep 1,155
You don't want the factory accordion hose, trust me. Not only is it a restriction, the bellows cause turbulence thats not needed.
How far is it installed on the intercooler? If installed too far it would be short on top. Another option is the coupler might have been cut short, we have never had this happen, but it could be a possibility. Let's check the following. 1.) How far the silicone is installed on the intercooler. 2.) Length of the silicone hose Once I have this information we can get it resolved. If the silicone is short, I will send you a new longer hose. If the silicone is to far on the intercooler.. that's an easy fix as well. Thanks, Michael |
11-03-2010, 03:24 PM | #6 | |
117
Rep 557
11-03-2010, 03:37 PM | #9 |
76
Rep 1,155
I found another interesting picture that shows one of the main restrictions in the intercooler system.
* This is the OEM pipe on the driver side. * This is the ETS pipe on the driver side. (No More Restriction) Thanks! Michael |
11-03-2010, 05:08 PM | #10 |
117
Rep 557
