Downpipe bolts rusting - problem?
11-02-2010, 09:12 AM | #1 |
Keepin' America Free
72
Rep 1,260
Hey guys,
I am installing my catback exhaust this weekend. I have heard from 2 friends that the downpipe bolts can be a problem, that they can rust and may need to be replaced. Anyone have any input on this? Will some WD40 or something suffice as enough to remove and reuse the downpipe bolts? OR will the be so rusted that I will need new ones? TIA. -Shields EDIT: I tried searching but only found people asking about using new DP's since the bolts are attached to the stock DP's. I will be using the stock ones still.
F10 535i | Retired: E60 ///M5 | E92 335i
"If everything seems under control, you're not going fast enough" -Mario Andretti |
11-02-2010, 09:13 AM | #2 | |
290
Rep 28,154
the stock dp's are studs, they break pretty easy, i would try to heat them if possible, or start spraying them with pb blaster every day until you do the exhaust, if they break, the studs will have to be drilled, or punched out of the dp. |
11-02-2010, 11:18 AM | #3 |
93
Rep 1,794
PB blaster is a must. I've attempted exhaust installs before and they never turned out good because of rusted bolts snapping in half. It is easier if you have access to a lift and the proper tools.
And you will want new studs. |
11-02-2010, 11:32 AM | #4 |
72
Rep 1,260
OK cool thanks guy. Yea I was definitely gonna PBblast 'em and hope for the best. Im trying to figure out my best options for finding a lift or jacking the car up. My biggest problem right now is what to do with the stock exhaust when I get it off. I have no way of moving it to somewhere I can leave it haha.
11-02-2010, 11:33 AM | #5 |
72
Rep 1,260
11-02-2010, 12:34 PM | #6 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
Also, I recommend coating the bolts with some anti seize paste. It will prevent rusting.
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
11-02-2010, 12:56 PM | #7 |
36
Rep 1,467
I personally would get stainless bolts, then after installing, spray paint over the threads with 2000f paint.
DPs get silly hot, and a lot of typical anti-rust measures aren't an option. -scheherazade |
11-02-2010, 01:24 PM | #8 |
72
Rep 1,260
Thanks guys
11-02-2010, 02:48 PM | #9 | |
297
Rep 4,408
ar
-Critter
11-02-2010, 02:55 PM | #10 |
1121
Rep 5,396
No offense, but what the hell does that mean? Just trying to understand, that's all...
11-02-2010, 03:05 PM | #11 |
290
Rep 28,154
11-02-2010, 03:21 PM | #12 |
1121
Rep 5,396
Thanks Kevin! I appreciate it.
11-02-2010, 05:03 PM | #13 |
297
Rep 4,408
-Critter
11-06-2010, 09:09 PM | #14 |
422
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
One of the studs on my stock DPs broke. What's the best way to get it out? I'll be replacing them with AR catless DPs soon but in the meantime, is it OK that I'm running my catback exhaust attached by using just one bolt for that midpipe? It is leaking slightly.
11-06-2010, 10:01 PM | #15 |
114
Rep 2,428
Pound it out is essentially the way to get it out...but be careful to not pound too hard with it attached to the turbo. Perhaps use some type of small puller or thredpress?
11-06-2010, 10:26 PM | #17 | |
422
Rep 8,003
After it is pressed out, can regular bolts be used in its place in case I decide to go back to the stock DPs? |
11-06-2010, 10:30 PM | #18 | |
55
Rep 1,495
11-06-2010, 11:00 PM | #19 | |
422
Rep 8,003
11-06-2010, 11:15 PM | #20 |
114
Rep 2,428
Regular bolts are normal for aftermarket DP/Exhaust installs, and you'll be fine with 1 bolt for a couple weeks, just be aware of it and maybe roll the windows down when at a stop or something.
11-07-2010, 12:13 AM | #21 |
55
Rep 1,495
