Quick! Need a DP install answer
10-29-2010, 07:29 PM | #1 |
I sweat pheromones
203
Rep 2,103
OMG. Never again...
I'm installing downpipes and made the mistake of not marking the O2 sensors before removing stock pipes. Now, I'm installing the new DP and am concerned that I'm mixing up the O2 sensors. According to one of the forum DIY's, you do not need to mark them before removal. They state that the shorter-rear downpipe uses the GREY O2 sensor and that the longer-front downpipe uses the BLACK O2 sensor. However, based on the lengths of the rear O2 sensors, I believe it's the exact opposite. So, there's the problem. Does anything go wrong if I place the BLACK O2 sensor on the short-rear dp? Does it even matter? I have a hunch that if I use rear BLACK O2 on the short-rear dp, I'll need to use the front BLACK O2 on the the same rear dp. Is this correct? I would hate to put it all back together again only to have a problem. This has taken long enough as is and don't want to do it again! Please help! |
10-29-2010, 07:32 PM | #2 |
146
Rep 1,922
Drives: E90 335i, E70 X5
uh oh, Mr. running into another problem now..... hope the car is up and running by tonite
-eric
E90 335i TiAg *STOCK* see my garage for mod list.. E70 X5 SGM *try to stay stock* :/ |
10-29-2010, 07:34 PM | #3 |
441
Rep 18,331
10-29-2010, 07:54 PM | #5 |
I sweat pheromones
203
Rep 2,103
That's the DIY I used. However, I believe my O2 sensors are color coded the opposite. Is that possible?
What does the 2 sensors do for each cat? I assume it measures the air before and after the cat to determine its effectiveness. So, if it reads poor, does it affect engine performance at all? I'm going to use a BMS dp fix AND a Procede. Therefore, I'm not worried about the CEL. I just don't want any performance or engine problems. Thoughts? |
10-29-2010, 07:58 PM | #6 | |
441
Rep 18,331
10-29-2010, 08:23 PM | #7 | |
I sweat pheromones
203
Rep 2,103
That DIY was well written which is why I didn't think to mark the sensors. However, I'm almost positive the colors are opposite. Either way, I will use your advise of using the same color front and rear sensor on the same dp. Fingers crossed! |
10-29-2010, 08:40 PM | #9 |
146
Rep 1,922
keep us updated Dan, if everything runs fine (finger crossed), you should take it out for some driving =)
-eric
10-30-2010, 03:48 AM | #11 |
151
Rep 1,677
You don't need the DP fix with the Procede, it has that built-in. I don't know if both would work at the same time. Let me know if you decide to sell the DP fix.
10-30-2010, 04:00 AM | #12 |
Zoom Zoom This
12
Rep 694
Dang, I hope you got it sorted out. i hate when I take something apart and miss how it was originally. I followed a diy here when I did mine so look em up and youll find it ... If you didnt already.. Gl bro
10-30-2010, 11:25 AM | #13 |
I sweat pheromones
203
Rep 2,103
Thanks for all the support. When you spend much longer with an install, it is never good. For those that have installed their own downpipes, you know how 'fun' it is laying on your back, arms sore, hands cramped and debris occasionally falling in your mouth. To top it off, I did this with a horrible cough.
Everyone was right about the colored O2 sensors. I WAS WRONG. I blame my flawed thinking on frustration. But that's not all folks! There were two additional issues with these Raceland downpipes. The first problem was the metal flange that connects to the turbo. As seen in the picture, it was not perfectly round. I fumbled with this damn pipe for an extra hour 'til I decided to take it down and inspect if for defects. Once I noticed it, I carefully rounded it out with a ball-peen hammer. The other issue was one of the O2 bungs was not cut out correctly. You can see the good bung and the bad bung. It's wasn't that actual bung but the pipe inside. I used a dremel and several bits to eventually widen & round the opening. Again, this was another issue I didn't find until later causing additional time and unnecessary frustration. I know this is the where everyone jumps in and says, "See, that's what you get with cheap downpipes." Maybe your right. Maybe this is an isolated case. Either way, I strongly suggest you inspect your downpipes PRIOR to installation. The additional frustrations with the install nearly made me give up. I was so close to quitting & sending a PM to Dr.phuOnger. Instead, I took a much needed break, had dinner and returned 2 hours later. I finally finished late at night. What a fun-filled experience! I hope this is the last frustrating DIY I encounter. I figure after this and my suspension, most everything else will be easier... well at least easier in that you don't need to tweak your body in awkward positions forever. I will copy this post to the Raceland downpipe thread so others do not experience my frustrations. I do not suggest Raceland downpipes are bad. I don't think I'd go that far. My learning is that I should always inspect the product (Raceland or other) PRIOR to installation. I suggest you do the same. Pics: |
10-30-2010, 11:27 AM | #14 |
I sweat pheromones
203
Rep 2,103
Nah, I'll use to the DP fix for service visits when the Procede will be removed yet the downpipes will remain making the dp fix necessary.
10-30-2010, 11:32 AM | #15 |
123
Rep 4,249
Glad to hear you worked it all out. I'm just getting too old for this level mod these days - I can empathize with your pain and frustration, but I can also appreciate how good it feels when you finally conquer it. Great job working out the defects on the pipes - again more work but also increased satisfaction, I'm sure. All that said, what's your sentiment right now - will you take this on again or farm it out next time? :-)
10-30-2010, 11:40 AM | #16 | |
I sweat pheromones
203
Rep 2,103
I perform DIY's for two reasons... a) Save money & b) Personal satisfaction. Yesterday, I spent WAY TOO MUCH TIME on this install. We all know the equation that time=money. In that sense, I didn't save a dime. Also, although I eventually succeeded, I didn't find the experience satisfying. That said, I WILL install my own IC and I WILL install most every other mod myself. However, if these downpipes were to come back out, I'd probably pay someone to do it. |
10-30-2010, 11:46 AM | #17 | |
441
Rep 18,331
10-30-2010, 02:11 PM | #18 |
I sweat pheromones
203
Rep 2,103
Oh, I almost forgot. There was a silver lining to this whole ordeal. I found my boost leak! It was the connection to the IC. That'll make a huge difference at Infineon next week. If I had someone else perform the install for me, I would have never known.
10-30-2010, 05:56 PM | #20 | |
I sweat pheromones
203
Rep 2,103
I just noticed your signature. Maybe I should've had you do the install! And to answer your question, probably ETS. Simple and no cutting. Last edited by dbjb; 10-30-2010 at 07:33 PM.. |
10-30-2010, 07:20 PM | #21 |
70
Rep 1,565
Is this the latest batch of DPs from Raceland?
If so, I would tell them your complaints and issues..I know these are cheap pipes, but there is no excuse for such poor QC, even at that price.
2020 M340i: Dravit Grey Mettalic. Loaded.
10-30-2010, 07:34 PM | #22 | |
I sweat pheromones
203
Rep 2,103
