The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Catless DPs - hardware and gaskets... reusable?
      10-29-2010, 03:23 PM   #1
IlChengis
once Treppiede
IlChengis's Avatar
Italy
63
Drives: 2012 E92 M3
Guys,
I just bought a set of 'gently used' 3" catless downpipes.
I was reading up on ARDesign's website and it appears that their bomb-proof gaskets are reusable. What about their hardware though?
Has anyone had trouble/leaks reusing these gaskets and/or hardware?
Last but not least... is the original OEM hardware at the Turbos reused when installing aftermarket downpipes? No gasket up there?
Thanks for clarifying, I did search but most threads that match my queries were non relevant or incomplete.
-Walter
2013 E92 M3 | 6MT | AlpWhite | SilverNovillo | CarbonTrim | ZCP | PremiumPkg | Alarm
2009 E92 335i | 6MT | AlpWhite | CoralRed | AlumTrim | M-Sport | Nav | Logic7 | Alarm (sold to a friend - still in the family)
      10-29-2010, 03:25 PM   #2
vasillalov
Mad Linux Guru On The Loose
vasillalov's Avatar
1121
Drives: 2008 335i Sedan, 2023 M3
2023 BMW M3  [0.00]
2008 335i E90  [8.00]
There is a gasket on each turbo flange. It is highly recommended that you replace those because they are crush gaskets, meaning, they will assume the shape of the downpipe one the bracket is tightened. If you put new downpipes, then you'll need new gaskets. BMW states that the two turbo ring gaskets must be replaced every time the downpipes are removed.
The rest of the hardware such as bolts and nuts should be reusable. The gaskets should always be replaced, unless otherwise specified.
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
      10-29-2010, 03:30 PM   #3
Kevin@AKMotorwerk
Kevin@AKMotorwerk's Avatar
Drives: THE GUY YOU LOVE TO HATE
Originally Posted by IlChengis View Post
Guys,
-Walter
as long as no one has ever beat up your turbo flange gaskets, you should be fine reusing them, they "should" be replaced per bmw, but i have never seen a case where they were bad, unless someone really had a hard time installing dp's and beat them all up. you can reuse the clamp and bolt, although most times i clean the bolt threads really good before reusing them
the dp to exhaust gaskets from bmw are useless, only one time use, the ar bombproof ones are reusable and so is the hardware
      10-29-2010, 03:31 PM   #4
IlChengis
once Treppiede
IlChengis's Avatar
Italy
63
Drives: 2012 E92 M3
Thanks for the clarifications Vasil and Kevin, much appreciated.
-Walter
      10-29-2010, 04:25 PM   #5
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
i always have a spare set. you never know. Change them twice this year.....
      10-29-2010, 04:45 PM   #6
dbjb
I sweat pheromones
dbjb's Avatar
203
Drives: e92 335i, retired SLK55
There's only one set of gaskets you'll need to buy. There are no gaskets up top.
You will, however, need to buy bolts/nuts for the flange connection to the midpipe. The oem bolts are permanently connected to the oem DP.
      10-29-2010, 08:37 PM   #7
scalbert
scalbert's Avatar
153
Drives: '13 S4, '15 Q7
Walter, you will be fine reusing the stock gaskets and hardware.
      10-30-2010, 08:29 AM   #8
Kelvin1000
Drives: 2019 BMW M2 Competition MT Hoc
I have the bulletproof AR unused for sale... CHEAP
      10-30-2010, 02:36 PM   #9
IlChengis
once Treppiede
IlChengis's Avatar
Italy
63
Drives: 2012 E92 M3
Thanks for the clarifications guys. I just wish they all matched.
Thanks bro, but I was looking for the bombproof ones.
-Walter
      10-30-2010, 03:36 PM   #10
Mike@N54Tuning.com
Joint Chiefs of Staff
4918
Drives: 2007 335i, 2015 M3
I always replace gaskets.. Its cheap and the safe bet.
Mike
      11-01-2010, 09:16 PM   #11
IlChengis
once Treppiede
IlChengis's Avatar
Italy
63
Drives: 2012 E92 M3
Thanks guys, I wound up buying Kelvin's brand new gaskets and hardware.
Regards,
-Walter
      11-02-2010, 09:23 AM   #12
mineo77
mineo77's Avatar
Drives: 2010 135i,1989 PRO3,2001 530i
2010 135i coupe  [7.56]
gaskets are not so bombproof so I would replace as well
      11-02-2010, 10:34 AM   #13
lyndon_h
lyndon_h's Avatar
40
Drives: e90
Mike
+1. No need in taking a risk when the effort and price to change them out is so low.
      03-19-2011, 10:16 PM   #14
M3 Eater
M3 Eater's Avatar
Drives: 335i Sedan
2007 335i  [0.00]
turbo ring gaskets.... I hear a whistling in the engine bay, sounds like a boost leak. Could it be that these gaskets have finally given up? Also I am having trouble reaching boost target in low gears but reach it fine in 5th and 6th. Anyone familiar with these symptoms?
I just upgraded my fmic, I have been over every connection several times, and I just am 2-3 psi shy of target in 3rd and 4th gear accd to jb4. Also wastegate activity is higher than I would like to see it at WOT as well. I am getting very discouraged with this car. I upgraded the fmic so I could reach target easier, and now it seems like I have messed it up???
JB4 beta 15 ohms FSB,AEM inline filter/ CM 10, ETS fmic, ER custom made charge pipe,TSW Donnington 18's,Simitumo HTRZ3, Injen DCI, AR DPs, Forge DVs, AA SLD, Koni FSD, ZSP springs.
      03-19-2011, 10:48 PM   #15
mycoupe
55
Drives: 07 335i coupe 6spd
      03-19-2011, 11:10 PM   #16
wren57
Roll Tide
wren57's Avatar
591
Drives: 335i
Gaskets between the turbos and DPs? I didn't notice any when doing the swap 3 nights ago. Neither did my buddy who was helping me. We just reused the stock vbands too. I assume that's ok?
We also reused the stock gaskets between the DPs and midpipes. I'm going to go back and replace these as I can tell they're leaking... make a crappy noise, especially on cold start.
Fix your broken/stripped cowl bolts with this elegant brass solution!
http://www.e90post.com/forums/showthread.php?p=20230306
