335i power loss from carbon buildup, clean out not covered under warranty?
10-26-2010, 09:45 PM | #1 |
Rep 6
Hey guys, long-time lurker, but I made an account because I need a little help.
My 335i doesn't have the type of power down low that it should. It feels like turbo-lag and I thought it was a software issue. Today I got it checked out at a dealership, and they said they suspect it's carbon buildup on the intake valves. They said they can clean it out using a process involving blasting walnut pieces/dust at it. Apparently this is not covered under warranty and will run about $700. I decided to research this before giving them the go-ahead. I called a few other dealerships, one said they do this every now and then and use a liquid/chemical process that will run me about $350. Another was shocked and said of course it's covered under warranty. Another had no clue what I was talking about. Has any run into this issue? Was it covered under factory warranty? If not, how much should I pay to get this fixed? Any help greatly appreciated. |
10-26-2010, 09:54 PM | #3 |
ghey
483
Rep 2,041
Lexus has a TSB out for their DI engines for this exact issue; something along the lines of DI being so precise and efficient that not everything burns out of the cylinder and causes carbon buildup.
Two steps forward one step back?
21 G05 > 20 G05 > 17 G30 > 14 F30 > 08 E90
10-26-2010, 10:01 PM | #4 | |
483
Rep 10,309
Drives: A///MERICAN!!!
"nope, not a problem, that just means it's working too well" |
10-26-2010, 10:17 PM | #5 |
Rep 6
Thanks for the tip. I had heard about that. It seemed more like a preventative measure...I'm wondering if it's too far gone at this point as it's approaching 50K miles.
10-26-2010, 10:25 PM | #6 |
86
Rep 1,262
I just did a seafoam treatment at 45000 miles.
A metric shitton of crap came out the exhaust and i would dare say i gained enough power that it was noticeable on the buttdyno. Do it!
Josh-
10-26-2010, 10:31 PM | #7 |
109
Rep 1,830
The surprise isn't what Lexus said. The surprise is that Lexus even uses turbos. WHAT?
10-26-2010, 10:31 PM | #8 |
48
Rep 675
What do you mean it came out of the exhaust, can you elaborate on the procedure? What did you have done?
10-26-2010, 10:40 PM | #11 |
86
Rep 1,262
'Seafoam' is a solvent that you have sucked into the intake manifold through the DV vacuum line. This solvent will coat the inside your engine (including valves) and break down a significant amount of the carbon buildup on them. The carbon buildup then gets expelled out of the car through the exhaust system.
On a DI turbo engine, i'd say this wouldn't be a bad idea to do every 10K. Make sure that shortly after you do this (<300miles) you change the oil, cause a tiny bit of it will get in your sump and it will lower the viscosity of the oil. My car actually prompted a change after driving about 25 miles the next day.
Josh-
10-26-2010, 10:59 PM | #12 | |
48
Rep 675
10-26-2010, 11:27 PM | #13 |
86
Rep 1,262
the dealer will probably charge hundreds to do it, if they will at all.
If you're a bit mechanically inclined, and have an extra pair of feet at the pedals to keep the engine from stalling, you can do it in less than 1hour. The hardest part is getting the vacuum line off, but if you put a 2mm slit in the end of it, it'll pop right off. Here's the original thread on how to do it: http://www.e90post.com/forums/showth...hlight=seafoam
Josh-
10-26-2010, 11:59 PM | #14 | |
48
Rep 675
10-27-2010, 12:07 AM | #16 |
86
Rep 1,262
It looks intimidating at first, but it's not that bad actually. I actually took off the entire HVAC cowl, engine cover and air intake to get to the manifold nipple.
Meth is not unlike having a nitrous setup. It injects a water/methanol mixture into the engine. Its primary function is to make more power for a brief amount of time. As a side effect, the intake valves get hit with the mixture and this cleans them somewhat. However, meth will not clean the exhaust valves, and it's not something you'll benefit from if you're not already substantially modified. hope that helps!
Josh-
10-27-2010, 12:14 AM | #17 | |
48
Rep 675
10-27-2010, 12:50 AM | #18 |
14
Rep 1,044
that 350$ process is just a 10$ can of seafoam. ive seafoamed my car like 3x in 10k and it gets better each time. better idle and smoother pickup. i first did it as 45k so i bet it was super grimey in there. my plan now is to do it every oil change.
10-27-2010, 02:26 AM | #19 |
28
Rep 268
10-27-2010, 07:05 AM | #21 |
3572
Rep 10,352
This is common for DI engines due to the lack of port injection which allows gasoline to wash over the valves (reason for all those adds regarding gasoline detergents).
Of course the type of motor oil used could make the problem worse. |
10-27-2010, 07:25 AM | #22 |
Big Beaver Smile
2101
Rep 3,791
Go to the 3rd dealer who said "of course it's covered under warranty".
______________________________________________
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch |
