Procede + 12223 code question
10-26-2010, 09:08 PM | #1 |
9
Rep 184
I have a failing HPFP. This week it has gotten really bad and it finally threw a check engine light..
I pulled the codes with my Procede and the only one that is there is 12223 indicating a bad HPFP. Is it safe to remove the Procede and take it to the dealer without clearing the codes? Or are there hidden "tuner" codes that i need to clear? Please advise.
2009 e92 335i 6spd :: Black Sapphire Metallic :: Coral Red :: Work Gnosis GS4 Wheels (20x8.5+32/20x9.5+35) :: Bronze Rays Lug Nuts :: AngeliBright v3 :: PROcede v4 :: Injen DCI :: Clutch Stop :: B&G S2 Sport Springs :: Matte Black Kidney Grilles :: Tinted Taillights :: Escort Passport 9500ix :: Samsung S1 160GB HDD
10-26-2010, 09:10 PM | #2 |
52
Rep 428
If that is the only code that you are reading with the Procede, it's all good. Just remove the Procede and take it to the dealership. No hidden tuner code can hide from the Procede's code reading feature
09-19-2011, 03:47 AM | #3 |
184
Rep 2,320
dont want to start new topic so writing here got this code 12223 Fuel Pressure at Injection Release (to start a car took 5 seconds after pressing start/stop button long crank) but after car heated i turned it off and on and starts normal. Should i worry or go to a dealer? car has only 22000 km on
p.s almost forgot this :could be a issue cos i let trunk OPEN 6 hours an there was a lamp in it so could be a batteries also, will se if its just a coincidence.
E92 335i Black Saphire 6MT PROcede V5, BMS DCI, Big Tom IC, AR CL-DP's 3", AR Design OC, Forge DV's, OEM M3 side skirts, BMW Performance Wheels 19 inch 269 Black Gloss+Continental ContiSportContact 5P (400hp and 550nm) https://www.youtube.com/user/aistis7..._as=subscriber
09-19-2011, 03:50 AM | #4 |
79
Rep 1,617
Yes dealer it. Code + long crank = HPFP on its way out.
Performance Seats, Exhaust, Splitters, Pedals, Steering Wheel / RB Turbos / M3 CF Roof / Brembo GT BBK 355/345 / Rollcage / Forge FMIC / Quaife LSD / Öhlins Road & Track / M3 Suspension Parts / Solid Subframe Bushings / Vorshlag Camberplates / Megan Racing Toe Links / LeatherZ Gauges / Extended M3 DCT Paddles / ER Sports OC / AR OC / Aux Radiator / AR DPs / Alpina TCU / COBB Pro-Tune
