DIY - E92 Foglights
01-24-2007, 11:47 PM | #1 |
13
Rep 247
DIY - E92 Foglights
Not sure if this DIY was all ready done... if it has, I didnt find it, so here it goes. My goal is to replace my stock foglight bulbs with some bright white H8 bulbs I got from Hoen-USA.
Before (dirty cover, I know): After (yeah, yeah... the cover is still dirty): So first get below the front bumper and pretty much remove every screw in site (8mm socket). Mine might look a little different since I have the OEM aero kit on. Also note, 3 of the screws are holding a ruber piece on. Those are also removed. Make sure the wheel is turned all the way out and in the wheel well remove the nut (10mm). There are also 2 more 8mm screws further up in the wheel well, right behind that yellow reflector we all love so much. No picture of those... After all those screws are removed, you can pull the cover off, enough to get your hand in to replace the bulb. You can see the bulb in the second picture below. Notice there is a pin holding the bulb in. So you need to reach in and remove the connector BEFORE trying to remove the bulb. Pinching the bottom end of the plug will allow you to remove it. Once it's removed, you can turn the bulb to remove it and replace. Remember not to touch the bulb. Just reverse the process to get everything back together.
2007 335i Coupe Last edited by BayernMuenchen; 07-11-2007 at 03:50 PM.. |
01-28-2007, 11:31 AM | #3 |
Moderator
132
Rep 6,775
Drives: TiAg E92 335
Nice write-up! Thanks.
-Michael.
Berlina Black S2000 CR is now in the garage l 19" Rial Daytona Race l KW V2 l Eisenhaus Race Exhaust l |
01-28-2007, 01:47 PM | #4 |
STEVIL Empire
213
Rep 6,297
I know the Hoens are whiter, but do they give you enough illumination as fog lights?
2007 E92 328i 6MT-Space Gray/Black Dakota/Gray Poplar w/heated seats-PCD 4/27/07 (SOLD)
2009 E90 328i xDrive 6AT-Space Gray/Oyster Dakota/Dark Burl Walnut w/ZPP,ZCW,Xenons-ED 4/17/09 - Redelivery 5/30/09 (SOLD) 2014 E84 xDrive28i 8AT-Alpine White/Black Nevada/Silver Matte w/ZMV,ZLP,494 - DD 3/14/14 (SOLD) |
01-29-2007, 11:49 AM | #5 |
13
Rep 247
As far as illumination either way the fogs have a hard time aiding the all ready bright xeon's. But the hoen's appear to have the same brightness...
2007 335i Coupe |
01-29-2007, 12:12 PM | #6 |
Administrator
40701
Rep 21,238
Thanks for sharing. Adding to DIY Master List.
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
01-29-2007, 06:46 PM | #7 |
53
Rep 1,393
Drives: e92 335i
Thanks doing this thursday!!!
Retired: e46 cabrio, E36 Cabrio, 02' 525i, 325Ci 02'
Style 189 335i sport Wheels for sale PM Me BIG CHANGES COMING SOON- Can anyone help me make a sig pic? |
04-29-2007, 06:49 AM | #10 |
Rep 27
Even easier for 335i
Here's a pic of the right side fog on my 335i. Just remove the 4 screws of the oil cooler cover and reach in with your right hand twisted to replace the bulb.
04-29-2007, 11:07 AM | #11 |
69
Rep 3,404
05-03-2007, 09:25 PM | #12 |
Administrator
40701
Rep 21,238
05-03-2007, 09:52 PM | #13 |
292
Rep 2,414
Drives: E92 335i
05-24-2007, 01:47 AM | #15 |
Rep 21
Hey this is a little off but I just replaced the fogs in my 335i with a set of 3000k HID's. When the car is off they work fine but once the car is started they start to flicker and I get the foglight malfunction error. Do any of you know of a fix?
07-11-2007, 03:49 PM | #17 | ||
13
Rep 247
2007 335i Coupe |
07-12-2007, 12:26 PM | #18 |
56
Rep 1,047
When I changed my fog light bulbs I did not remove the plug from the bulb first..All I did was turn it counter clockwise remove the bulb with the plug and wire still attached and then swap out the bulb.
Still a great DIY. I will be removing my e92 kidney grills and painting them flat black hopefully this weekend and I will post a DIY with photos.
"If you're not intense..you're past tense"
"..Greed is good, greed works.." 07 E92 335i,Sport,I-drive,Cold Weather,Bluetooth,Beyern Mesh 19",M-Pedals,Rear Fogs,Gp Thunder,Carbon Roundels,Coming Soon JB2,Vorsteiner Decklid,OEM Aero LipRIP9/8/06-12/11/07 Gone but never forgotten |
09-24-2007, 07:51 PM | #19 |
Feeling Blue.
117
Rep 801
Drives: I12 i8,f10 M5,e89 IS,F1 6S35i
will the lumanics pure blue bulb work it says its 12v with 35w producing 120 watt.... i really want it since its 8000k
10-28-2007, 02:03 PM | #20 |
Rep 181
Drives: 2006 911 Carrera S
Great DIY, thanks! Worked just as you said, though I did it without removing the 10mm. 9 screws in all.
2011 X5d Platinum Grey/Oyster/Bamboo/+lots of stuff
2006 911 Carrera S - 6MT - Seal Grey/Black/Sport Seats/Sport Exhaust/Sport Chrono/Nav Gone: 2007 E92 335i - 6spd - MontegoBlue/Black 2003 E39 530i - Auto - Black Sapphire on Black Gone: 2001 325Ci - 5MT- TopazBlue/Black Trackday Count: 10 |
02-29-2008, 05:04 PM | #21 |
31
Rep 1,015
those fog lights were so freaking hard to install!!!!!!!!!! ahhhhhhh!!!!!!!
Mods: Painted Reflectors, GP Thunder Angels, Rear Fogs, 20% Tints, Front Aero Lip, Alarm, Black Layovers, Pearlescent Brake Handle, Debadge, ACS Roofspoiler, LED license plate, 6000k HID & HID Fogs, LED footwell mod Click to see my BMW plate collection |
03-08-2008, 03:03 PM | #22 |
Seaman
69
Rep 518
Very easy
Thanks for the visual. I only had to remove 3 x 8mm bolts front under the front part of the bumper (the 3 outer botls), and then the 2 x 8mm inner fender bolts. Pop the splash guard back and reach in there. Since I knew what to look for (from the picture above), it was very simple unplugging and changing the bulbs without having to look at it. Compared to changing a B7Audi A4 foglight bulb, it took about the same effort to change it but I had a lot more room to work with on the E92.
Only took me 10 min total for both sides |
