Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Power to the the Pump?
      10-24-2010, 05:51 PM   #1
Jonny550
Jonny550's Avatar
241
Drives: 2012 550i Xdrive
Just a couple questions about wiring my DO kit to the car.
I was wondering if i could splice the wire in the cig lighter and power the pump that way or just tap a fuse?
Plus should i install a couple inline fuses into the main power line of the pump?.
Thanks for all the help guys,Jon
[SIGPIC][/SIGPIC]
      10-24-2010, 06:05 PM   #2
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
I did 50 amp fuse under hood (red) to meth switch, to pump.
      10-24-2010, 06:06 PM   #3
scalbert
scalbert's Avatar
153
Drives: '13 S4, '15 Q7
DO?
I understand a methanol pump but DO? In my world, DO is disolved oxygen.
      10-24-2010, 06:10 PM   #4
Jonny550
Jonny550's Avatar
241
Originally Posted by scalbert View Post
DO?
Devils own methanol injection
[SIGPIC][/SIGPIC]
      10-24-2010, 06:10 PM   #5
Jonny550
Jonny550's Avatar
241
isnt that fuse always on, I need something for key on power.
[SIGPIC][/SIGPIC]
      10-24-2010, 06:11 PM   #6
scalbert
scalbert's Avatar
153
And would it have taken too much of your time to type it out for clarity?
As for powering a pump, take a direct line and fuse it. Better safe than sorry.
      10-24-2010, 06:45 PM   #7
I think it goes to sleep when the ecu goes to sleep. However, the pump is only on when you see boost. So its not on till you actually get in boost. So technically its never on until the car is started and going 8-10 PSI (whatever setting you have).
Regardless, Ive been doing it seamlessly for 1.5 Years, not trying to reinvent the wheel here.
Clap135 runs it the same way last I checked too. I mean there are wrong ways, and there are some good ways, and there are some hard ways, you decide which road you want to take.
      10-24-2010, 06:47 PM   #8
Jonny550
Jonny550's Avatar
241
did you use a tap a fuse or just wrapped the wire around the prong and stuck the fuse back in?
[SIGPIC][/SIGPIC]
      10-24-2010, 06:49 PM   #9
See edit, you respond way too fast, I cant even do my ninja edits.
I did it the ghetto rigged way... Wrapped wire.
      10-24-2010, 06:51 PM   #10
      10-24-2010, 07:10 PM   #11
Clap135
Clap135's Avatar
102
Drives: 2009 N54
You can use the battery post for power in the engine bay.
Jp has it a little backwards.
Pump to battery ground
Pump positive to boost switch
Boost switch to battery post (battery post screws into firewall/fender, very easy access, just pop off the plastic cover) Whatever fuse came with your kit goes between the boost switch and the battery post.
      10-24-2010, 07:49 PM   #12
Jonny550
Jonny550's Avatar
241
Fug it no failsafe for me
[SIGPIC][/SIGPIC]
      10-24-2010, 08:09 PM   #13
cn555ic
cn555ic's Avatar
Drives: 335i
Wow really after reading about failsafes and then you decide not to install one! Bad idea man
      10-24-2010, 08:16 PM   #14
Jonny550
Jonny550's Avatar
241
i just cant get it straight with failsafes and the Jb3, Why cant the Labonte failsafe work on the Jb3 is becuase it cant read if their is a overflow so if that happens i cant do anything about it.
Or give $400 for a CMGS and FS when i could have gave $160 if i had a procede.
I rather not run one.
[SIGPIC][/SIGPIC]
      10-24-2010, 08:35 PM   #15
cn555ic
cn555ic's Avatar
Drives: 335i
500( plus trade in of your JB3 tune for a Procede) +160 Lebonte failsafe= 660
400= just CMGS and FS
for 260~ bucks more you can have it all! A Procede and a lebonte failsafe meth system with progressive meth mapping
      10-24-2010, 08:44 PM   #16
Jonny550
Jonny550's Avatar
241
What u mean trade in my Jb3? like sell it then buy a procede because as far as i know vishnu only offers a dicount to you they dont want your Jb3.
[SIGPIC][/SIGPIC]
      10-24-2010, 10:37 PM   #17
More or less same, just different power source.
I agree, anyone moving forward with meth should look into failsafes.
