335d owners with BT?
10-24-2010, 01:35 AM | #1 |
Rep 5
Hi,
I just wondering is there anyone having stock or modifed 335d and Bavarian Technic Diagnostic Tool? I would like to compare some parameters with my 335d. For example with my stock 335d: max. desired boost is 1,759 bar max. actual boost 2,01 bar max. engine torque 548 Nm @ 3081 rpm max. calculated engine torque 614 Nm @ 2272 rpm absolute pressure in DPF filter 1-1,2 bar soot mass is DPF filter ~27 g And these parameters after Evolve reflash: max. desired boost is 2,01 bar max. actual boost 2,15 bar max. engine torque 594 Nm @ 2255 rpm max. calculated engine torque 650 Nm @ 2255 rpm DPF filter parameters are the same So guys what do you think? For me it's strange why Evolve raises boost only 0,2 bar? Before reflash I had problems with jammed DPF filter, but after manual regeneration things get much better. If anyone have BT and 335d, could you please check absolute pressure and soot mass in your DPF filter? Also what should be stock 335d boost pressure? And what boost do you have after Evolve remap? Many thanks! |
10-26-2010, 07:59 AM | #3 |
486
Rep 1,614
Send a pm to Ron1n, he has a JBD. I don't know if he will have access to the info you're seeking.
A question for you: what oil are you using? I'm curious in the context of your problems with the DPF. |
10-01-2011, 08:48 PM | #5 | |
grand poobah
254
Rep 2,253
OP, there aren't many people in the US running reflashes on their d. You may want to try asking in the european subforum. Edit: I also just realized most of this thread is a year old. |
10-02-2011, 02:36 AM | #6 | |
810
Rep 3,974
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) |
10-02-2011, 02:52 PM | #8 |
Speed Demon
205
Rep 3,690
I can't get my BT to see actual values on anything to save my life. Don't know if I'm doing something wrong, or just not setting it up properly.
JBD doesn't touch boost, because it doesn't hook in to the boost sensor. Some other tunes do for the d, but not the JBD.
Current: '21 M5C, '15 X6 50i Previous: '18 M550i, '16 550i, '11 335is, '09 E93 M3 DCT, '10 E90 335d, '07 E90 328i |
10-02-2011, 03:17 PM | #9 | |
grand poobah
254
Rep 2,253
