TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > water/oil mixed in catch can
      10-21-2010, 10:05 PM   #1
.e92hoang.
Drives: 335i coupe
anyone experiencing oil/water mixture in their catch can. sometimes found under oil cap too. maybe caused by the cold weather? i only noticed the mixture sometimes. the other week. i drove my car to reno from san jose, ca. Parked it over night, checked my catch can in the morning and found water/oil mixed. so i pulled the procede out. drove it back home the next night, checked the can and still water/oil mixed. the next day drove to work (10mins away) checked the can.. its NORMAL (no water/oil mix).. wth??? a week later which is yesterday, drove to work checked the catch can, still normal but under the oil cap.. i found a little oil/water mixture... any ideas whats going on? or is this normal?
mods:
injen intake
procede v4
oil catch can
      10-21-2010, 10:06 PM   #2
Express
Express's Avatar
Israel
369
Drives: 06 330i
2006 BMW 330i  [8.30]
drain the oil and check it.
      10-23-2010, 09:30 PM   #3
.e92hoang.
Drives: 335i coupe
no one experiencing the same problem?
      10-23-2010, 10:34 PM   #4
Mr. 5
Modder Raider
Mr. 5's Avatar
Scotland
753
Drives: M3
2007 e90 335i  [8.00]
No way man. No water should be in that catch can.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD
Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM
      10-24-2010, 09:58 AM   #5
vasillalov
Mad Linux Guru On The Loose
vasillalov's Avatar
1121
Drives: 2008 335i Sedan, 2023 M3
2023 BMW M3  [0.00]
2008 335i E90  [8.00]
If you are seeing water vapors in the PCV system then this means that either your oil cap is not tightened and it is leaking or the PCV system is not sealed properly. I would check all the connectors in the PCV system that you touched while installing the OCC.
Here is an example of the same problem on a my previous car:
http://forums.vwvortex.com/showthread.php?2526976
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
      10-24-2010, 11:57 AM   #6
Mr. 5
Modder Raider
Mr. 5's Avatar
Scotland
753
Drives: M3
That is no bueno!
e90 335i--SOLD
      10-24-2010, 11:14 PM   #7
.e92hoang.
Drives: 335i coupe
thanks for the inputs guys..
right when i found moisture in the catch can.. i checked all my lines right away.. all the lines were tightened and secured..
in the morning during cold starts.. the first 2 mins of idling. i can feel a little roughness.. maybe a slight misfire.. im not sure if thats normal, but i feel like my car has a power loss sometimes.. then again sometimes it drives normal...
should i strip everything and bring it in to the dealer?? im still under warranty.. if i bring it in.. what should i tell them?
      10-24-2010, 11:16 PM   #8
Express
Express's Avatar
Israel
369
Drives: 06 330i
politely ask for a new motor
      10-24-2010, 11:28 PM   #9
Iwantm3
Drives: 335i M sport
lol
      10-25-2010, 01:05 AM   #10
.e92hoang.
Drives: 335i coupe
wish it was that easy.. hahaha
      10-25-2010, 09:55 PM   #11
vasillalov
vasillalov's Avatar
1121
2023 BMW M3  [0.00]
Originally Posted by Mr. 5 View Post
That is no bueno!
That's my old car. Engine is still running like a champ!
Replace worn out and shrunk gaskets on the oil cap and it's fine!
      10-27-2010, 03:34 AM   #12
.e92hoang.
Drives: 335i coupe
that was it?
      12-06-2010, 12:44 PM   #13
rem3
Drives: 135I
SAME PROBLEM >>>
After cleaning without having started the engine.
nothing in the oil filter:
Water and oil temperature is good!
No oil in water....
135i ,23600 MILES
      12-06-2010, 01:19 PM   #14
itsbrokeagain
itsbrokeagain's Avatar
Drives: 1999 528iT, E53 X5, E46 325xi
That muck is the lack of oil temperature being hot enough to bake the moisture out of the oil.
There is a reason BMW opens the thermostat at 235...because after 212 water will boil off. Short distance driving without letting the oil warm up will cause it to get milky under the cap.
Let the car get hot more often, beat on it some to get the oil temps up and change it more frequently. If you dont drive the car much at all change the oil every 3-5k miles, because moisture in the oil will degrade its qualities quickly.
I have seen that so many times on E46s its not surprising at all lol..
      12-06-2010, 01:23 PM   #15
M3 Eater
M3 Eater's Avatar
Drives: 335i Sedan
2007 335i  [0.00]
Great lessons as always from CT
JB4 beta 15 ohms FSB,AEM inline filter/ CM 10, ETS fmic, ER custom made charge pipe,TSW Donnington 18's,Simitumo HTRZ3, Injen DCI, AR DPs, Forge DVs, AA SLD, Koni FSD, ZSP springs.
      12-06-2010, 01:51 PM   #16
vasillalov
vasillalov's Avatar
1121
2023 BMW M3  [0.00]
Exactly what I was saying in my previous post
      12-06-2010, 03:35 PM   #17
taylors335
taylors335's Avatar
Drives: Space Grey 08 335i
2008 335i  [7.00]
there should be no moisture in the engine at all if you have water in your oil you should do a compression check to make sure you do nit have a head gasket going out .
      12-07-2010, 04:32 AM   #18
.e92hoang.
Drives: 335i coupe
what about low on coolant and low engine oil?? my car is telling me to add more coolant and more oil..?is this normal too?
