Should I be worried? Custom software from BMWNA
10-21-2010, 04:07 PM | #1 |
19
Rep 267
Drives: 2007 E93 Alpine white with Red
So my car has been in and out of the shop for over a month. I had studdering, hesitations, losses of power and misfires leading to limp mode - always in one cylinder.
They did a software update, then hpfp, then low pressure fuel sensor, and are now replacing all 6 injectors. Apparently a BMWNA tech was in the shop and they are modifying a software update specifically for my car. I dont know whether to believe it and toss it up as BS, feel good about the fact that they are paying special attention to my vehicle (fat chance), or actually be worried that maybe they are putting some specific tune that is extremely good at sniffing out tunes... The misfires really only happened when I had my jb3 on map 3, more on map 5, and of course more on map 7. I could see them getting frustrated becuase I have all of these misfire codes and cant replicate the problem. Any thoughts?
2007 335I E93 sport package Alpine White. BMS DCI, PROcede V4, ACT street clutch, Michelin Pilot Sport A/S Plus and BT Tool. Pending install of Raceland Downpipes.
10-21-2010, 05:05 PM | #2 |
441
Rep 18,331
I have not heard of any CUSTOM program...Its either one version or another so as for them telling you this, I think it BS because they dont have the program to write software at the dealership...
10-21-2010, 05:11 PM | #3 |
19
Rep 267
It "apparently" wasn't from the dealership they were sending my data to BMW and they were going to send a modified software version back. I toally could see them just blowing smoke up my ass, but just in case, I hope it's not some special software that is meant for cars they suspect have a tune and are costing them money.
10-21-2010, 05:23 PM | #4 |
630
Rep 1,649
Uh, so the dealer and BMW are on a wild goose chase for miss fires you were having while the tune was on there but the car runs fine without the tune?
Crap like this is what makes it harder for the rest of us to get legit problems fixed. Own up to the fact that modifying the car caused the issue not something BMW did like bad waste gate designs or HPFP's. Last edited by therealm3; 10-21-2010 at 05:31 PM.. |
10-21-2010, 05:25 PM | #6 | |
60
Rep 2,014
10-21-2010, 05:43 PM | #7 | |
123
Rep 4,249
10-21-2010, 05:49 PM | #9 |
Friends don't let friends early apex!
41
Rep 110
Drives: "The Turbo Schnitzel"
/\ +1
07 Space Gray E92 335i "Turbo Schnitzel"
Wavetrack LSD, KW V3, M3 Aluminum Arms, E93 M3 Front Sway Bar, Dinan Toe Link, Catless DP's, AE Quad Exhaust, DCI, Vishnu PWM Meth, Vishnu V2.5 440whp/460wtq (stock cats) |
10-21-2010, 05:53 PM | #10 |
1274
Rep 4,703
Custom software is not gonna happen, they just said that to you to make you feel special and to make you feel that they are doing lots of work just for you. Total BS.
10-21-2010, 06:26 PM | #11 | |
23
Rep 1,179
10-21-2010, 09:38 PM | #12 | |
19
Rep 267
What logs should I have been running, with a BT or with my JB3?
10-21-2010, 09:41 PM | #13 | |
19
Rep 267
BTW dude you tell me to own up but everyone on this god damn forum does the same shit. I'm sure you've gone in for a HPFP and guess what, a tune can make it go out faster so own up to it and pay for it yourself? Ridiculous.
10-22-2010, 08:33 AM | #14 |
121
Rep 1,568
^ I see your point, but sending dealerships on a wild goosechase on errors you get when tuned can really confuse the techs. They are chasing something that they can't diagnose.
I guess you have two options to get this fixed. 1- Go in with the tune, and tell them to fix your errors, since you can show them 2- Deal with it until it starts throwing errors when stock, so they can figure it out. Your example above doesn't relate to what you are doing. If a HPFP fails with a tune, it will throw a code that points directly to a HPFP replacement and software update. It's also as known problem stock. Your general misfire/limp mode code could mean anything. If it throws a code / hesitates when stock, then you have a problem. |
10-22-2010, 09:29 AM | #15 | |
I even mod my cereal
246
Rep 3,441
Drives: 11 ZCP DCT M3 14 328d 21 GT4
did they call it "custom software" or "software update"?
You and I go to the same dealer and they did a "software update" on mine after a misfire on one of the cylinders. I still think they kept it an extra day because they want to look to see if I had a tune, which I diddn't. Quote:
2011 Mineral White M3 ZCP - Opticoat, Ventureshield, some CF, B&B exhaust, AFE Intake Vorsteiner VFF 101s Ohlins
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser |
10-22-2010, 09:42 AM | #16 |
Vengeance is mine, I shall repay
132
Rep 4,656
just do some logs like i did and try to find out where the root cause of the issues are coming from....through my logs we figured out my one step colder plugs are probably causing pre-detonation and creating timing dumps during and after shifts....and just follow what the informed members say....even tho some sound somewhat condescending...try and take it for what its worth.....jpslick,clap,dzenno....and then in your case terry of course... they all can read logs very well and help you out
Project: Vengeance[ACM's King of domestics, STOCK:501whp 489wtq | 2.9L whipple stock bottom end: 706whp 688wtq] Callies Compstar motor build:NEXT
10-22-2010, 04:56 PM | #17 | |
630
Rep 1,649
And I am pretty sure all three major tuners will tell you that a tune does not make the pump go out faster. I think its safe to say given the small user base of tuned cars, they fail more often on stock cars. Furthermore, I have no tune and if I did, I’d let them know. So save the attitude and false accusations. I understand your frustration with not having your car and shotty dealer service. Been there done that with my E46 325. 6 trips to the dealer for a surging idle, countless parts replaced, special DME reprogram from NJ, and months of down time all ended up in the head field service engineer for West US (or whatever the heck his title was) telling me its normal vehicle operation. Even the data log I brought in and gave to the service manager still did not matter. Again all this on a stock car. It sucks. I know. But in your case its really not their problem to try and get your car to run right on whatever map of the JB3 you are running. If you throw all these codes stock, then that’s a different story. |
10-22-2010, 05:01 PM | #18 |
Ski bum
317
Rep 6,198
There aren't enough tuned 335's out there to fail enough fuel pumps to get the warranty extended the way BMW did.
I agree with many here, the OP is being an ass by trying to get BMW to solve a problem caused by a JB.
1999 e46 328i Ti Silver / Black[retired] 2007 e90 335xi Jet Black / Black[retired] 2011 e70 X5 35d Vermillion Red / Cinnamon 2011 e92 M3 LeMans / Fox Red extended |
10-22-2010, 05:02 PM | #19 | |
630
Rep 1,649
I am not arguing that these motors can do more than stock without issue. Some are better at it than others, and if one has a slightly lesser build that can’t run the same map as another guy without throwing codes but works at stock levels, how is that BMW’s issue to fix under warranty? |
10-22-2010, 05:45 PM | #20 | |
23
Rep 1,179
what is "pre-detonation"??? or did you mean something else? no harm intended, just trying to understand what you saying here. |
10-22-2010, 06:01 PM | #21 |
246
Rep 3,441
therealm3,
If he took all the bigger mods off (think he did) and he just has software on the car I don't see the sotware causing this. Safe tuners like BMS, GAIC, and Vishnu make their software to perform within acceptable, safe parameters that will not cause issues like THIS when there aren't major mods present (which is the case now). It's not saying it's never happened with just software, but it's very unlikely. The 335 has shown that the fuel pump and injectors are major weakness on the car without even any mods present. I bet it would exhibit the same behavior with the JB3 off the car. It sounds to me that your experience with your 325 has caused you to be jaded, but getting worked up about people taking modded cars to the dealership for warranty work is wasted energy. People mod Accords for God's sake.... If you still feel that passionate about the subject maybe you can start an advocacy group that stops warranty work on modded cars. Good luck finding members to join your cause.....
10-22-2010, 06:48 PM | #22 |
630
Rep 1,649
Bigdaddy -
Reread this from the original post and you'll understand where those of us who don't agree with the way this is going down are coming from: "The misfires really only happened when I had my jb3 on map 3, more on map 5, and of course more on map 7. I could see them getting frustrated because I have all of these misfire codes and cant replicate the problem." I agree that the HPFP, wastegates, and injectors are a weak point of this car as evidenced by the number of problems that are out there on stock tune cars. And I agree that tons of people mod their cars and bring them in warranty work. Where I disagree with it all is when someone brings in a car that has a problem when its modded, takes it off, and then tells the dealer to fix the now non existent problem. It wastes everyone’s time. |
