Some G4 dynos, logs, and videos!!
10-21-2010, 12:17 PM | #1 | |
Joint Chiefs of Staff
4918
Rep 115,980
Just got some dyno charts and logs from BMS I wanted to share with you guys. The car has downpipes, IC, DCI, JB3-G4, and 92 octane. Here are their notes in no particular order:
Mike |
10-21-2010, 12:44 PM | #3 |
ElevenPointFive
326
Rep 2,450
Thanks for posting Mike.
Is the ignition drop off on the graphs shown above related to the vanos event as it seems to occur around the 4200 rpm mark?
2008 E90 335xi - N54 Daily Driver
MHD Stage 2+ ~ CPE DPs ~ BMS Intake ~ AMS FMIC |
10-21-2010, 02:44 PM | #5 | |
4918
Rep 115,980
Mike |
10-21-2010, 05:34 PM | #8 | |
184
Rep 2,841
Do you not recall saying that? |
10-21-2010, 05:43 PM | #10 | |
4918
Rep 115,980
Mike |
10-21-2010, 06:04 PM | #11 | |
184
Rep 2,841
Also helps bypass it if you ease into the throttle rather than hammering it. So I guess the theory is that increased octane helped eliminate that as a knock event? |
10-21-2010, 06:20 PM | #12 | |
4918
Rep 115,980
Mike |
10-21-2010, 06:41 PM | #14 | |
184
Rep 2,841
That's been my experience on Procede too. 13ish psi on stockish modifications returns very stock-like timing curves. Going beyond this on pump starts to induce mid-rpm dips which I don't like to see. Nice Sandals! |
10-23-2010, 08:05 AM | #16 |
70
Rep 1,565
Mmm...I thought that is the VANOS crossover and it kicking in?
2020 M340i: Dravit Grey Mettalic. Loaded.
10-31-2010, 09:50 PM | #17 |
4918
Rep 115,980
Just heard BMS got the oil temp protection added. Runs stock tuning, around 5-6psi, until 140 degrees then ramps up to full strength by 160 degrees. At 270 degrees ramps down to stock @ 280 degrees. Oil temp is viewable in interface but isn't a charting option yet. There is also an option to bypass it for you "drive it like it's leased" types.
Mike |
10-31-2010, 09:58 PM | #18 |
102
Rep 3,460
i vote dtc map switching next.....lol
good feature, I actually like that you guys went lower, sometimes its annoying to have to wait till 170, esp when staging. Probably safer at 170, but less pratical at times. |
11-01-2010, 11:52 AM | #19 | |
4918
Rep 115,980
Mike |
