BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > Sponsor M3 Project Cars Showcase
EXXEL Distributions
      10-21-2010, 05:14 AM   #1
Tonester
Drives: LSB M3
RENN-Spec | ESS VT2-500 Review/Tips/Photos
Follow us on Facebook for the latest updates!! www.facebook.com/rennspec
VT2-500 Install/Review
I'd like to start off saying that ESS puts together an amazing SC kits that are nothing but top notch quality, I've installed a variety of ESS SC kits and each and every one of them have been 110% complete quality.
Next up is one of the most important pieces to the puzzle. The tune -its flawless. Unlike the competitors in the FI industry the ESS tune is THE best, its extremely smooth and clean. It has no cold start idle issues, nor does it pop/miss/backfire when being held at any RPM… try that with a competitors and it won't hold steady with out popping/missing. The tune is one of the reasons I chose ESS, I've tried/tested out a few other SC kits and was unhappy with the drivability of the tune. Seeing that the tune was "unstable"/choppy just free revving and driving on the street, I could not have that type of inconsistency while on the track at 100% duty. Oh yea… ESS runs "MAF-less/Alpha-n" tune on all their kit for the S54 engine.
The power output is again very smooth/linear driving around town, the drivability of the car is still just like how it was from the factory with the exception of the added power. Under 3000rpm you can feel a difference, the car moves and covers ground quickly. Over 4000rpm is when the car turns into a monster!! as the boost climbs the car pulls to redline very hard and very fast. Its hard to keep the power down even in second gear at higher rpm's I get wheel spin.
**Brake ducts were rerouted b/c of the intercooler piping, they're sticking out b/c the new route is much shorter so the photos are before I trimmed them down.**
***TIPS***- Since I've done a few ESS installs I changed up a few minor things to clean up my personal install that I would recommend to everyone.
1. Power steering hose, instead of running the elbow/extension hose that ESS supplies you can get a brand new OEM hose from a regular E46 and it'll be of the shape you need and it'll be one continuous hose. it comes from BMW with a mesh covering to protect the hose which is a big plus when you squeeze it in those tight areas for the SC install. Another plus is that you'll have 2 less connection points/hose clamps to use, which means you reduce the chance of leakage at that connection. Part #: 32416750155 ~$40 (photo #3/ the braided hose that is tucked under the oil cooler lines)
2. The plastic 90 degree elbow that is supposed to be used for the power steering, you can now use for the crankcase hose. When I routed mine as one hose it did not want to flex in that direction and cause the hose to bulge up, so instead I used the 90 degree elbow. (Photo #6, you can see the 90 degree fitting. I felt that this made the install look a better instead of a bulging hose thats rubbing against the nice manifold.)
3. Those with a early production vehicle or those who have converted to the aluminum bumper support will have to cut a piece of the bumper support to clear the intercooler. I would suggest you test fit your bumper prior to cutting anything from your bumper, I only needed to cut off the tabs that hold the grill and adjust the intercooler mounting to get everything to clear.
Final words.... again! As if I haven't expressed it enough… you can't beat the ESS tune. I can honestly say there is no other competitor has a better tune. I love my kit and can't wait to upgrade to the VT2-550, I can't imagine having more power and putting it down so smooth!!! Anyone that is buying this kit will be extremely satisfied!
We are an Authorized ESS Tuning Dealer/Installation Center, please feel free to contact us if you have any questions.
**Excuse me if there are any grammar error/typos... its late and I know you guys have been waiting for this post**
ENJOY!!
FINALLY PHOTOS!!!!!
Replacement crank pulley from ESS.
Photo taken before the engine bay was degresed/cleaned.
After cleaning, Bracket installed, Power steering hose "upgrade"
Checking intercooler clearance with the OEM bumper support.
Vortech blower mounted!
Crank pulley mounted and belts all tensioned up.
Manifold mounted! Injectors waiting to go in.
Test fitting the bumper with the splitter installed to check piping clearance.
Another shot
A shot of the fitment in between the bumper/IC
A great shot that shows the "factory" finish on the manifold, it matched the OEM engine cover pretty well.
A couple of photo of my car at a recent event…
Mine + Our Z4MC track car
Our booth shared with Akrapovic and Brembo!
      10-21-2010, 05:47 AM   #2
flipm3
E46 + E90 + F80
192
Drives: E46 + E90 + F80
2009 BMW M3  [0.00]
2002 BMW M3  [0.00]
WOOOOT!!! I've been waiting to read your review for quite some time!
Congrats on getting everything installed and setup!! I can't imagine what this kit feels like in the E46! Car looks great!
Do you still plan on running your square 265 setup with the much added power or do you plan on changing up your wheel/tire setup?
I can't wait to hear track impressions!
F80 M3 DCT|Alpine White . Black Leather | My Build Thread
E90 M3 DCT|Melbourne Red . Speed Cloth | My Build Thread
E46 M3 6MT|Jet Black . Black Nappa Leather | My Build Thread
      10-21-2010, 10:01 AM   #3
Nate@IND
BimmerPost Supporting Vendor
Nate@IND's Avatar
2866
Drives: BMW
Good review of the kit
IND DISTRIBUTION | 866-963-4520 • FACEBOOKINSTAGRAMFLICKR
      10-21-2010, 10:18 AM   #4
NYCMCBM3
NYCMCBM3's Avatar
167
Drives: 2012 MCB E92 M3
i never knew they had a kit for the E46, looks good
2012 MCB///M3
      10-21-2010, 03:12 PM   #5
Tonester
Drives: LSB M3
Keeping the 265's for now, going to adjust suspension/alignment/aero to increase grip while still keeping the car agile and have good rotation.
Hitting the track this weekend for shakedowns!
      10-21-2010, 04:05 PM   #6
flipm3
E46 + E90 + F80
192
2009 BMW M3  [0.00]
2002 BMW M3  [0.00]
Originally Posted by Tonester View Post
Keeping the 265's for now, going to adjust suspension/alignment/aero to increase grip while still keeping the car agile and good rotation.
nice!!! i can't wait to hear your results! good luck!
      10-21-2010, 04:14 PM   #7
biglare
Bulldog
biglare's Avatar
Drives: BMW & Porsche
Great review!
Enjoy the added power!
Prev: Individual F80 M3 - Fjord Blue/Silverstone(interior) | Fashion Grey(exterior)
GTS
      10-21-2010, 04:47 PM   #8
sjl888
sjl888's Avatar
22
Drives: 2016 F80 AY
great review! love you car
F80 AY
      10-21-2010, 05:03 PM   #9
jeff@autocouture
jeff@autocouture's Avatar
966
Drives: 2002 E53 X5 4.6is
sick
      10-21-2010, 05:36 PM   #10
Alekshop
Alekshop's Avatar
Drives: E30 M3 l E46 M3 l GT4 l 991 RS
Pretty cool e46 ... good job guys !
      10-26-2010, 07:37 AM   #11
PIMP "E"
PIMP "E"'s Avatar
Drives: AW 2011 M3
2011 M3  [0.00]
whats up with the spoiler, is it a drift car or something?
MONEY IS THE SAIL TO MY BOAT
      10-26-2010, 04:05 PM   #12
Tonester
Drives: LSB M3
Its our Time Attack/Track car.
      10-30-2010, 05:07 AM   #13
0-60Motorsports
0-60Motorsports's Avatar
Bahrain
792
Drives: BMW M3 JB 04 Coupe
Looking great bro!
Current Mods:
2004 E46 M3cs JB/CSL
2010 E70 X5M AW/BLACK
2011 VW Golf R DSG White/Black
IG: @060Motorsports
      10-30-2010, 12:48 PM   #14
e92_m3
194
Drives: 2009 e92 m3
Great write-up man! Gotta love the takata green TE37's. They look great on LS blue.
Any vids of the SC in action?
      11-01-2010, 08:46 PM   #15
bavarian19
bavarian19's Avatar
Drives: Car
      11-01-2010, 09:54 PM   #16
m33
m33's Avatar
Drives: E92 VT650 MCB Individual
Great review !
      11-02-2010, 01:24 AM   #17
Tonester
Drives: LSB M3
Here is a video of it on the track... although you can't hear the SC since the gopro was mounted on the outside of the car it was all wind noise.
      11-10-2010, 01:14 AM   #18
e92_m3
194
Drives: 2009 e92 m3
So planted on the ground. Very FAST...
Thanks for posting man!
      11-13-2010, 03:53 PM   #19
IMG's Avatar
Drives: E36 M3 Track car,Ess E90 M3 DD
Great review,congrats !!!!!
      11-13-2010, 07:10 PM   #20
Tonester
Drives: LSB M3
We just took 1st place in Limited FR @ Super Lap Battle... and we also broke the lap Record for that class.. video coming soon!
Here is another video of it on the track/dyno tuning...
      11-17-2010, 04:43 PM   #21
dlbrooks18
dlbrooks18's Avatar
161
Drives: e90 335i
congratulations on your 1st place finish, car is a beast! I need you guys to do some tuning on my car, thinking of meth + nitrous setup
2008 E90 335
      11-17-2010, 05:50 PM   #22
Tonester
Drives: LSB M3
Whatever your needs are we can take care of it!
Heres the dyno sheet of the before/after meth tuning.
Tags
ess tuning, rennspec, supercharged, track car
Search this Thread:
Advanced Search
m3post
