12543 - Code
10-19-2010, 03:04 PM | #1 |
Rep 17
12543 - Code
Newbie post here - I got a half engine light and code 12543 (Exhaust Fume - Low Pressure Side Turbo) after hiting a lip in the road that that was being resurfaced while at 25-30 mph and in a non-boost situation. I'm stock except for the Procede. Is this a matter of something coming loose that can be fixed by me or a serious, remove-the-Procede & take to dealer ASAP situation. The bump on these low profie tires was jarring. The light came on immediately after when I got back on the throttle (slightly).
Any advice for a newbie? |
10-19-2010, 03:46 PM | #2 |
40
Rep 522
How does the car drive now? Does it feel down on power? It could be a loose coupling on either side of the intercooler.
http://www.realoem.com/bmw/showparts...78&hg=17&fg=05 |
10-19-2010, 03:53 PM | #3 |
Rep 17
No Boost
The car runs, but the code is staying in the Procede (won't reset & is cutting the boost -2.5) so I'm getting no boost (good thing I imagine - thx Procede).
The Half Engine Light is a constant annoyance as well is my lost power. I'm out of town now, I want to know if there's a specific connection that I should be looking for to reconnect or if she ought to be brought to the dealer (minus Procede). I'm not blamming the Procede - it seems to be working like a charm and I miss my POWER that it provided. |
10-21-2010, 03:27 AM | #4 |
40
Rep 522
You most likely have a big boost leak then. Have a look at other posts for code 30FF (hex equivalent) and see what people suggest.
Personally I would recommend that you have a look at all the pipe work to/from the intercooler + the charge pipe (where the diverter valves pop out of) and see if anything is loose. When I had this issue the hose coupling from the low pressure side to the intercooler had come off and the car would go into limp mode as soon as I squezed the throttle. Fix is very simple, but it requires the under tray to come off. Have a look at the pics in this post to see the hose coupling. This has most likely come off on yours. It just needs to be popped back in again and make sure the clip is in it's locked position. http://www.e90post.com/forums/showthread.php?t=373990 |
10-21-2010, 11:18 AM | #5 |
Rep 17
335rocks - thx dude. I thought my request for advice was falling on deaf ears. Unless you post I smoked an AMG, Vantange..... or my tune is better than your tune post - you don't seem to get much help from the community as a newb.
I'll pull the tray and look to see where she pulled a hose. It had to be that jarring bump I hit not knowing that it would be as severe as it turned out to be. I had put the tune on about a month ago and changed the plugs recently, so I was worried I messed something up. Man, these cars are sensitive, but at least they react quickly and don't blow themselves up when something goes haywire. I hit the bump and then just got back on the throttle and "Ding" (half engine light). Cheers |
10-21-2010, 11:21 AM | #6 |
1748
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Good advice here. And I agree 100%
10-22-2010, 11:26 AM | #9 |
Rep 17
Still need help
Guys,
There was no obvious disconnect at the intercooler, but I unclipped both sides and slide them back in and I'm still getting the hal engine light. Pls Help. It's not overly noisy (like air is getting out of the system) and I'm getting no turbo whine, cause I don't think they're even engaging. Next steps? Remove the Procede and she how she runs? What other connecstion should I be looking at there's not a lot of room in there. Help! |
10-22-2010, 11:40 AM | #10 | |
1748
Rep 17,960
Drives: A Lot
No problem with removing the Procede as the next step. The only possible point of confusion is if the leak doesn't occur until higher boost and running stock 5-8psi works fine. But theres a better chance of the leak still being there in which case you'll know for sure and will need to inspect the piping again. Shiv |
10-22-2010, 11:58 AM | #11 |
Rep 17
Shiv,
I talked to Robert. I"ve left it in Valet mode since the event, so it's even happening at stock boost levels around 2500 RPM. I'm removing the Procede and taking it to a dealer for someone whose better with wrenches to track down. They replaced these turbos on this car (I bought it used 5,000miles ago) less than 10,000 miles ago. I don't fell air coming out of any of the connections and re-did the intercooler connections, so I give up. Thx anyways. |
10-22-2010, 12:27 PM | #12 | |
1748
Rep 17,960
Drives: A Lot
10-22-2010, 12:31 PM | #13 |
Rep 17
Update - Procede is out. Head out for a drive, 2500 RPM, "Ding!" - Half Engine Light.
I have seperation anxiety already. I miss my Proceded 335i. It just wasn't them same without the boost, and it's disheartening that as soon as you get in the throttle that damn half engine light comes on. It's like the day after your girlfriend dumps you at the prom (not that's really happened or anything - really). |
10-23-2010, 11:08 AM | #14 |
Rep 17
Guys - it turned out to be a bad end of a vaccum hose. Snip, attach, and voila.
Dealer got it in a lunch on Friday, but it took several calls to get an update. At lease I got it back before the weekend. I'm glad she's back in the boost. Thx for the folks that helped out trying to help me diagnose the problem. Turns out that I didn't have the tools nor skill to figure this problem out. It is a bummer that such s small problem can hobble the car. |
