Procede Autotune vs No Autotune
10-18-2010, 10:03 AM | #1 |
Vengeance is mine, I shall repay
132
Rep 4,656
New to the whole V4 thing here fellas, swapping the v4 and jb3 back and forth seeing whats best on these EPL turbo units of mine. I was wondering if anyone was feeling the same way I do about autotune. Its great for daily driving around when im not on the dragstrip or feel like driving aggressively and also keeps the engine somewhat safe. But outside of that when i want Max boost i find it somewhat hindering...my logs seemed fine without autotune on but autotune on would tune my normal 16-17psi down to 14-15.5 almost all the time...its on 93 pump from shell. I will post some logs after lunch today to show you what i mean.
Project: Vengeance[ACM's King of domestics, STOCK:501whp 489wtq | 2.9L whipple stock bottom end: 706whp 688wtq] Callies Compstar motor build:NEXT
10-18-2010, 10:29 AM | #2 |
5450
Rep 8,815
I noticed the same thing. With autotune on my boost usually lowers from its initial set target during the summer heat since i'm still on my stock fmic and dp's.
Now i have both my map 1 and 2 set exactly the same with the only difference being one is with autotune on and the other map with it off for the times where I want to have MAX power available.
10-18-2010, 10:39 AM | #3 |
3441
Rep 79,211
Change the aggression level if you feel its too conservative for your setup. Just be aware of the risks.
I'm getting aggression levels of .2 (not 2) at 17 PSI Max with this cold weather. Welcome to Meth. You have to remember autotune default settings are not set for MAX power, its set for a happy medium for daily driving. It's also set up for every customer vishnu has, around the world, it needs to be conservative and be able to cover a broad range of people in different elevations,weather, ETC The settings can be adjusted for a reason.... |
10-18-2010, 10:59 AM | #4 |
132
Rep 4,656
this log is with autotune OFF
10-18-2010, 11:07 AM | #5 |
132
Rep 4,656
one more with it off
10-18-2010, 11:11 AM | #7 |
132
Rep 4,656
lol....i gotta get these settings working right first...
10-18-2010, 11:14 AM | #9 |
441
Rep 18,331
10-18-2010, 11:14 AM | #10 |
133
Rep 4,764
What are your settings with auto-tune on? How much boost do you expect out of 93 octane without having timing events? What are all your mods, for those of us that don't know?
16-17 PSI with 93 octane only, looks the same to the motor whether you have upgraded turbos or not. You could set autotune to max PSI of around 15-16 for 93 octance only. Raise it to 17-18 with meth. I personally think that anything about about 17.5 you should be using meth and race gas. I set my max psi to 17 with 93 octane and meth. |
10-18-2010, 11:15 AM | #11 |
53
Rep 886
My autotune tunes boost to 17PSI on pump gas (stock turbos). I'm really happy with it.
Mods: RB turbos, JB4, BMS DCI, Scoops, Forge DVs, ar design catless DPs, Milltek exhaust system, Helix FMIC, Quaife LSD, VK MotorWerks OC Kit, Bilstein B16 PSS10
10-18-2010, 11:16 AM | #12 |
ElevenPointFive
326
Rep 2,450
I would not waste your time, with meth your results will be dramatically different and its where you really should focus your energy. You really should be running meth with upgraded turbos, you desperately need the octane.
2008 E90 335xi - N54 Daily Driver
MHD Stage 2+ ~ CPE DPs ~ BMS Intake ~ AMS FMIC |
10-18-2010, 11:17 AM | #13 | |
161
Rep 7,377
i have now UT45 and max boost 16 on map 1 with IC 50% . This is plenty of power for 93 octane. Run that map for many WOTs . log and see where you are at with the autotune settings. you can than get them much closer for quicker adaptation/autotuning when you switch maps. And yes hit JpSimon since he has the same turbos.
10-18-2010, 11:20 AM | #14 | |
132
Rep 4,656
true... i know im doing snow performance but thats all i really know...i just fund the car and watch...and then drive it like i stole it....
10-18-2010, 11:21 AM | #15 | |
132
Rep 4,656
10-18-2010, 11:22 AM | #16 | |
133
Rep 4,764
There is plenty of anecdotal evidence about where the limits of boost are before you are going into a high risk area for the engine internals without the proper octane levels to avoid knock or detonation. Keep on logging and get some meth flowing before running >16PSI (my two cents). |
10-18-2010, 11:29 AM | #17 | |
ElevenPointFive
326
Rep 2,450
10-18-2010, 12:00 PM | #18 | |
132
Rep 4,656
10-18-2010, 12:01 PM | #19 |
132
Rep 4,656
one more
10-18-2010, 12:33 PM | #20 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Changing the aggression targets will effectively make the tune run more or less boost. The question should be why you need to increase aggression target to run more boost. If the default aggression target results in a boost level of 15+psi in other cars and only 12psi in your car, why is that the case? What is making your car knock more frequently than others? That's the question that need to be answered and addressed before you start running more boost.
10-18-2010, 12:36 PM | #21 | |
133
Rep 4,764
Also, when you dyno'd you implied you were on 93 octane only and with autotune on the car went to 18.2 PSI (post from October 2nd). Why now will it just go to 14-15.5? Did someone add race gas while you were not looking?
Something does not add up, not saying you are not stating the facts, just the behavior seems strange. From the post on your dyno day: Quote:
BTW - 15.5 PSI on 93 octane sounds safe to me. I also don't like your logs when you bumped up the aggression level. |
10-18-2010, 12:38 PM | #22 | |
132
Rep 4,656
