BMW just called me about a recall. Please read.
10-04-2010, 01:26 PM | #1 |
398
Rep 4,084
This morning I recieved a phone call from my dealership. Apparently there is some sore of "recall" on some of the ignition related components on N54s. I put the word recall in quotations because it doesn't seem like they are making it an official recall the way they did with the V8s and V12s.The girl was very nice and explained to me that it can sometime take a bit longer for the car to turn over. It sounded like she was talking about HPFP long cranks. She said that it would just require a reprograming and would take about an hour and a half. So, i made an appointment for Saturday morning.
Now, I've heard about people getting a HPFP failure, and being told that the car needed a reprogramming AFTER they went in. I can't say I've heard of anyone being contacted by their dealership to get this taken care of. Does anyone know about this?
7/18/09- I pick up my baby- 2009 E92 335i Xdrive, Space Gray over Coral Red. Premium Pkg, Cold Weather Pkg, M-Sport Pkg, 193Ms, Gloss Black grills, Custom Gloss Black Mirrors, Performance shift and E-brake boot, M3 spoiler, Euro fog switch, gloss black interior tim, Coco-Mats (red/black), H&R coilovers, 19'' Alufelgen SF-71s......
10-04-2010, 01:57 PM | #2 |
70
Rep 1,565
Sounds like the dealer is being proactive to get paid for their labor and work...they probably really don't care about your HPFP. Sounds like a sales revenue generator. I assume you bought the car from them and they have your info? They are probably just going through the DB of owners they sold this model to and trying to drum up business.
2020 M340i: Dravit Grey Mettalic. Loaded.
10-04-2010, 02:12 PM | #3 |
40
Rep 2,431
If it's not a warranty issue which requires a failed HPFP, they won't get paid by BMW so it doesn't make sense they are just "trying to drum up business".
10-04-2010, 02:15 PM | #4 |
253
Rep 7,089
Drives: '06 AW 330xi
Not everything revolves around a failing HPFP....many things are covered under warranty. In fact everything is included in the new car warranty. So if there is in fact a fault with any of the components of your vehicle, then it's covered unless YOU altered it and your modifications caused the fault. Did you even know you had a warranty or what it is?
10-04-2010, 02:34 PM | #8 | |
I ask the questions you're afraid to ask.
44
Rep 2,489
However, while the symptoms may go away for a while, it won't fix an already failing pump - it may just keep a good pump from failing. Reports are mixed. Some say that there is less turbo lag after this update - some say there is more. This is not a recall. |
10-05-2010, 07:33 AM | #9 | |
398
Rep 4,084
10-05-2010, 10:21 AM | #10 | |
70
Rep 1,565
Haha....yeah ok, you have no clue what you are talking about obviously.
10-05-2010, 01:07 PM | #12 |
56
Rep 1,232
It's an open campaign for the DME programming for the HPFP priming primarily. It's based on model years and production dates. However when I took my car in Monday for a half power light, vaccum tank/hose issue and asked about it I had to basically beg them to check on it as the key fob did not register any need but I fall well within the production dates. I think the TSB is 13-10-09 or 13-09-10. Good luck when I get mine back, if they updated, I'll post the feeling/lag et al as I have original software from 1/08 build.
10-05-2010, 02:58 PM | #13 |
7
Rep 137
Mine was updated last week. Car appears to drive better but they also replaced the exhaust flap cause it was loose and causing a rattling. So it could be either, or all in my head.
10-05-2010, 03:18 PM | #14 |
1435
Rep 4,724
Yep. Software update. Nothing to fear.
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
10-06-2010, 12:38 AM | #15 |
398
Rep 4,084
10-07-2010, 10:56 AM | #16 |
56
Rep 1,232
As promised posting up the results of the software update. Got car back last night, they had it for 3 days, one to fix the vacuum tank which caused the engine malfunction light and the other two to get the ok from BMWNA to recode and the update. Car dirves a lot differently, like I said earlier I have a 01/08 build with the original loaded software, never had an HPFP issue so no need for any other versions, car starts same as it did before, right away, feels a lot smoother though when driving. Before it was abit of a beast to drive smoothly on light throttle and when you pushed it was instant on. Now a lot more linear feel, the perception is you are not moving anywhere near as fast but when you look down at the speedo your going along just as fast. Side effects they reset everything, all the preferences were reset so I had to go thru the stalk(no nav/idrive) and reset all those, bluetooth calls are very low or quiet for some reason, not sure why and if anyone has an answer offer that up. Basically nothing to fear, car is fine, no increased lag. I only have about 40 miles on the car so let me thrash it a bit and get it to adapt.
