2010 2011 BMW 5 Series Forum F10 F10 535d wheel lug nuts torque |
09-29-2010, 03:24 PM | #3 |
116
Rep 1,346
Drives: 2011 E92 335 M-Sport
I asked the service adviser who called the technicians who looked it up,and he said it's the same as E60 90 ft-lbs
09-29-2010, 04:23 PM | #4 |
224
Rep 3,016
Thanks guys, but there seems to be an element of confusion here.
Since posting the question I checked the instruction leaflet that was included in the BMW locking lug nut pack for my E92. It's a general leaflet catering for most models including 3 and 5 series and it's issued by BMW. It clearly states the following: 120+/-10 Nm for all versions in M12 140+/-10 Nm for all versions in M14 For reference 120 Nm = 88.5 Ft/Lbs, 140 Nm = 103 Ft/Lbs. Going by that, 90 Ft/Lbs doesn't reach the lower end of the tolerance band. I get a bit anal about things like torque settings and tyre pressures, so I'll call my local dealer in the morning and see what they come up with - I'll let you know. |
09-29-2010, 04:29 PM | #5 | |
116
Rep 1,346
09-30-2010, 10:01 AM | #6 | |
224
Rep 3,016
I torqued mine to 125 Nm, but I'm not completely happy so I'd be interested to hear what what your dealers say. |
09-30-2010, 10:26 AM | #7 |
6659
Rep 15,858
I'll stir it a bit... don't forget the issues of dry vs. wet or dry film lube.
Just a thought, have the latest M14 bolts changed from the thread pitch of earlier applications. That could answer the value issue. HighlandPete |
09-30-2010, 10:59 AM | #8 | |
116
Rep 1,346
1 service department: 90 ft/lbs 1 parts department: 90 ft/lbs 1 service department: waiting to hear...
09-30-2010, 05:02 PM | #9 | |
224
Rep 3,016
I don't know what the thread pitch of earlier M14 bolts was, but these are finer than those on the E92 M12's, which would indeed account for the lower setting. I just wish BMW would include this in the handbook. |
09-30-2010, 10:01 PM | #10 | |
116
Rep 1,346
He told me it's 140 Nm = 103 Ft/Lbs. Which is contradicting what I have heard at 3 other dealers. I emailed him back to double check. FYI this if for a 2011 535i Sport
10-01-2010, 11:56 AM | #11 |
116
Rep 1,346
OK so the service tech double checked and said 90 Ft/Lbs is the correct spec. I also contacted 2 independent tire shops, and they said the same, so that's what I'm going with.
10-01-2010, 12:54 PM | #12 |
224
Rep 3,016
Thanks for your help; until I hear anything else I'll stick with 125 Mn (92 Ft/Lb) and recheck regularly. I'd rather err on the side of under as opposed to over-torque.
10-01-2010, 02:30 PM | #14 |
116
Rep 1,346
Just as further reassurance, I took all the wheels off when set at factory spec with a breaker bar and they were very easy to remove. When put back on and set at 90, they are equally easy to remove. I set it to 103 ft/lbs just to check and they were much harder to remove versus when I first removed the wheels set from the factory. So I'm going with 90 ft/lbs. Hope this helps.
Lucwarm20123.50 |
11-16-2010, 03:12 PM | #15 |
224
Rep 3,016
Bolt torque update.
I spoke with the senior technician at my local dealer, who has kindly sent me a print-off from their maintenance computer. F10/F11 M14 Bolt torque - 140Nm = 103 Lb/Ft. |
11-16-2010, 06:00 PM | #16 |
116
Rep 1,346
The humanity! Now you got me all worried again.
