Do your wipers flutter and bounce when..
09-27-2010, 12:56 PM | #1 |
95
Rep 334
they reach their lowest (rest) position? Mine do and I find it really annoying. Anyone know how to stop this? It seems that the wipers really don't make contact with the window (especially the passenger one) near their ends.
Steve Foster '11 E92 335i Grey/Black Manual |
09-27-2010, 01:13 PM | #2 |
50
Rep 825
Drives: a car.
Mine do not behave that way. its a clean sweep start to finish too.
09-27-2010, 01:15 PM | #3 |
126
Rep 1,984
Drives: F15 35i
Have you applied Rain-X? I found that after I did that the first few rains they "bounced" at the end like yours do, then it went away.
See my full mod list in my garage
09-27-2010, 01:42 PM | #4 |
[]D []-[] []_[] []< []\[] []_[] ']['
27
Rep 418
Drives: 335i Convertible/Le Mans Blue/
No bounce here
2010 E93 335i M LeMans Blue
2001 E 46 330ci Coupe/silver/black/Sunroof 1999 BMW R1200C Cruiser-Ivory & Blue |
09-27-2010, 02:08 PM | #8 | |
1646
Rep 4,877
If it's when they are off, they might not have put them on in the right position, so that they are turned up more, and are catching wind. They usually fit on a spline on the wiper shaft, and if were put on a tooth or so out, then they would sit higher.... |
09-27-2010, 02:14 PM | #9 |
Big Beaver Smile
2101
Rep 3,791
No, mine do not. Clean your blades and windshield really well then see what happens.
______________________________________________
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch |
09-27-2010, 02:56 PM | #10 | |
53
Rep 582
...YES! Mine do this very same thing and its very very annoying. I've changed the wiper blades (not just inserts), polished the glass with a porter cable buffer and Zaino glass polish, I've cleaned the blades edge with alcohol pads and wiped them completely clean. While this solves it temporarily... one day in the rain and it comes back. Either there's a lot of pollution in the air around the Bay or there's something wrong with the bmw wipers. There has to be someone else with this issue and some sort of fix-it.
NCC BMWCCA Member
09-27-2010, 05:44 PM | #11 |
1705
Rep 14,829
Mine do too, and the wiper inserts are brand new. Maybe my windshield is too old? It is pock-marked, but short of never driving, that seems to be par for the course with bmw glass.
09-27-2010, 09:08 PM | #12 |
Big Beaver Smile
2101
Rep 3,791
If you clean brand new fresh out of the box blades, you'll notice a whole lotta black coming off of them. That's the first thing I do when I get new ones, adn I clean them regularly, and I don't have the "skipping problem" at all
09-28-2010, 05:44 AM | #15 |
205
Rep 3,523
Drives: 2015 F23 M235i/2008,E90,335xi
wipers
my flutter a bit when it's raining and I'm at 120 mph +.
09-28-2010, 06:44 AM | #16 |
European Editor
10589
Rep 22,992
Have you tried CLAYING your windshield to remove old bug guts, then rainx the windshield. That should do the trick. Also how hard is the rubber on the blades? Do you live in a sunny climate? Maybe the UV rays have hardend the rubber - hence the skipping.
09-28-2010, 07:36 AM | #17 |
Rep 107
Mine will only bounce when there is little rain water on my windshield. If it is raining pretty good outside it will just glide across.
2007 E92 328xi: Jet Black/ Black/ Aluminum|6MT/|Active Cruise|Xenons|Bluetooth|IPod|
Chuck Norris once kicked a horse in the chin. Its descendants are now known as giraffes. |
09-28-2010, 07:38 AM | #18 |
95
Rep 334
Thanks for the replies...
I see I'm not alone on this and that I didn't explain
the situation clearly. If you just use the wipers to wash the windows all is fine. But in a steady rain, when the wipers are working continuously, that's when they start bouncing toward the bottom of their travel. They also get noisy at that time and sound like you're hitting a cardboard box with your hand every time the wipers go down. Hope you guys who don't have this issue keep it that way! Steve Foster '11 E92 335i grey/black/mt |
09-28-2010, 07:50 AM | #19 |
10
Rep 271
I clean my blades with rubbing alcohol on a cotton swab. Also just complain to your dealer as they are covered under your maintainence so replacement is free.
09-28-2010, 11:01 AM | #20 |
Rep 53
I found that my wipers bounce AFTER I put othe rainx. They were fine before but I heard a lot of good things about rainx so i decided to give it a try. Applied it exactly as instructed and now whenever it rains my wipers bounce and sound horrible. Dealer even gave me new wipers and same thing. It seems like before the wipers just glided over the glass without a sound but now it seems the rainx is almost causing too much friction. I don't think it is the blades at all. I guess I will try using a clay bar to get everything off the glass
09-28-2010, 02:08 PM | #21 | |
Hates Speed Limits
111
Rep 2,589
09-28-2010, 02:56 PM | #22 | |
212
Rep 1,071
