Windows roll back down on their own
09-26-2010, 12:02 AM | #1 |
Winning at Life ;)
10
Rep 87
Drives: Loaded 335i E93
When I use the "all up" switch to bring them up, often (20%?) one or both of the front windows will roll back down after nearly reaching the top. This happens with top up or down. It's very annoying and embarassing.
Anyone seen or heard of this before? There a fix? The dealership is baffled.
09-26-2010, 03:21 PM | #2 |
923
Rep 15,818
It's a known issue
has to do with you being on an unbalanced road/surface That's what they told me my SmartTop fixed this before :P funny how an aftermarket mod fixes it heh
09-26-2010, 06:02 PM | #3 | |
I ask the questions you're afraid to ask.
44
Rep 2,489
If the windows sometimes reverse on their own then the issue most likely is the anti-pinch requiring adjustment. You can adjust it by manually running your windows up and down a few times so the system can learn where the proper position is. It is also possible that some debris is causing the system to reverse - just like your garage door reverses when it thinks that there is something blocking the way. BTW Smartop probably deactivates anti-pinch so - while it may "resolve" that problem, may be dangerous. |
09-27-2010, 01:10 AM | #4 | |
923
Rep 15,818
When I first got the car, I was so annoyed by it, that I forced them to check it a thousand times. They ended up changing almost everything from the window, to the mechanics inside, to the seals in the roof (or whatever they're called that the window latches onto) they couldn't get rid of it they though I was BSing, but when I had video proof along with taking the Service manager on a test drive and showing him first hand, they really had no choice. but even after all that it still continued to happen. I searched online (here and elsewhere) and it's a common problem on the e93 and some other convertibles too (I remember my boxster used to do it, but Porsche was able to repair it and it didn't happen again) And you're wrong on the SmartTop part; the reason it fixes the issue seems very simple: on the e93, the large one window button will open all the windows with one click, but you need to hold it to close. the SmartTop has a feature where you can close all windows with one click. That is (from what makes sense to me) what fixed the issue. I even showed my SmartTop to my dealer and they loved the idea and were baffled that it fixed my window issue while all their work and effort failed.
09-27-2010, 06:51 AM | #5 |
163
Rep 2,979
Drives: 07 SBM E92 335i 6MT
Mine does this....
1. It has only done it when it's raining/wet. 2. I have always been on a flat surface when it has happened... 3. I'm not concerned about this as much as I am the damn streaks that are happening when I roll my windows up
In the process of restoring an 07 335i
09-27-2010, 06:51 AM | #6 | |
[]D []-[] []_[] []< []\[] []_[] ']['
27
Rep 418
Drives: 335i Convertible/Le Mans Blue/
What's that? Do you mean the car isn't level?
2010 E93 335i M LeMans Blue
2001 E 46 330ci Coupe/silver/black/Sunroof 1999 BMW R1200C Cruiser-Ivory & Blue |
09-27-2010, 07:20 AM | #7 | |
44
Rep 2,489
Both of his "you're wrong" statements don't actually say anything different but that's OK. It is pretty well documented that the anti-pinch is the issue - at least for coupes, sedans and wagons. The only reason for the windows to reverse is if the anti-pinch thought there was something blocking the window from going up. Ahhh well. |
09-27-2010, 07:33 AM | #8 |
27
Rep 418
Oh...ok...in that case...Persian you are correct! I especially think you were correct to show the dealership your SmartTop which bypasses the safety features of the vehicle.
09-27-2010, 07:55 AM | #10 |
795
Rep 979
pardon me if I sound dumb, but what the hell is smartTop?
2008 E60 550 ? Alpine White // RPI
2011 E90 M3 Competition // Alpine White // ESS // RPI // 20" BBS LM's, blah blah 2021 G80 M3 Competition // Brooklyn Grey // KW Suspension // 12mm Spacers all around // Resonator Delete |
09-27-2010, 08:08 AM | #11 |
Rep 329
I had this problem on my 2007 E93 335 and have it again on my 2011 E93 335is. It's a bit annoying, but since its a known issue w/o a specific fix I've never brought it up to my dealer. I haven't been able to discern any specific condition or action that causes it.
SmartTOP is a after market add-on for convertibles that gives you additional control/features. http://www.pcars.com/porsche_parts/s...le/p_4057.html A Last edited by andrewket; 09-27-2010 at 08:15 AM.. |
09-27-2010, 12:18 PM | #13 |
34
Rep 324
I have a similar issue w/my '09 M-Sport couple. However, for me it seems to only happen when I hit auto-up and then turn the ignition off before the window(s) finish rolling all the way up. I do this everyday pulling into my spot at work. About 5% of the time, the window will immediately reverse direction as soon as I turn the ignition off.
I had them look at it when I took it in for my first service and miraculously they were able to reproduce it (I thought for sure they would claim it was unreproducible). They told me they weren't sure what the problem was and rebooted/recycled/reset whatever the computer. Unfortunately this did not solve the problem - fortunately it is not the end of the world. On the other hand, every once in a while my sunroof will refuse to close. It will get 99% closed, and then reverse direction. I've sat there playing with it for 30 min before trying to get it to close. Then, after some arbitrary amount of time, it would work. They told me they also reset that system too but I'm afraid to use it now for fear that I won't be able to get it closed. LAME.
R135 │ 2009 335i E92 6MT / LeMans Blue / Black Dakota / Gray Poplar └┼┼┤ │ Premium / M-Sport / Nav / HD / PDC .246 │ Heated Seats / iPod+USB / Smartphone Integration |
09-27-2010, 12:27 PM | #14 |
46
Rep 967
This is why BMW needs to include the sunroof manual close tool in the tool kits. I find it ridiculous that I had to buy it to fill a blank spot in the car. You can manually close the sunroof with it in case something like this ever happens.
| PROcede Rev3 | Vishnu Meth | DCI | BMW Perf. Exhaust | AR Coated/Catless | CP-E FMIC | Quaife | |
09-27-2010, 12:36 PM | #15 |
34
Rep 324
Yeah they explained that to me. They also showed me how to manually reset it if it happens again. Apparently you hold the button "up" (towards the sky, as if you're going to tilt it open) for 30 seconds or so and then it will start opening. Keep holding it until it completes the entire cycle including tilt and all. When it's done it's reset. LAME.
09-27-2010, 02:26 PM | #16 | |
923
Rep 15,818
Well they also knew about my FMIC, Catless DPs, BOV, DCI, JB3 later too. Which safety feature though? Being able to close the windows with one touch of a button? Being able to open/close the top with 1 touch of the button? Other convertibles can do it, so how does that make it unsafe? If you mean driving at 20mph and doing it... well yeah, that's just being retarded. 5mph I beg to differ though. You know me too well
09-27-2010, 02:35 PM | #17 | |
46
Rep 967
09-27-2010, 03:51 PM | #18 |
795
Rep 979
so no ones going to say what a smartTop is? Simple question
09-27-2010, 03:59 PM | #20 |
795
Rep 979
