The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Modifed n55 exhaust
      09-20-2010, 08:04 PM   #1
Calvin@Vishnu
Calvin@Vishnu's Avatar
52
Drives: 2010 335i
Modifed n55 exhaust
A few days ago, we whipped up a quick 'n dirty exhaust for our n55 135. Nothing earth-shattering and completely conventional. In fact, it's conceptually identical to what we made years ago and still have on our n54 335.
We replaced the factory midpipe and installed a fully divorced dual 2.5" pipes. This removed the stock resonator and 2-to-1 merge:
And we also removed the factory single entry muffler and replaced it with dual 2.5" staight-thru Magnaflow exhausts. The piping was made of mild steel. And crush bent. Mandrel bending would be preferable but, for now, this will work just fine. It should be noted that crush bent exhausts are really quite fine in systems that don't require sharp bends. In the case of our car, the pipes are reasonably straight (no acute angles):
The factory downpipe:
It splits off into 2 outlets so that BMW could still use the same exhaust components they used for the twin turbo n54. We retained this component since it houses the single catalytic converter. We were tempted to go fully catless for testing purposes. But that will have to wait for the time being.
The factory 135 muffler:
Single Entry, dual outlet. The left outlet is open/closed by the vacuum operated actuator. The internal layout of the muffler housing is pretty convoluted. No doubt designed for sound muffling and not for minimum restriction.
Replaced by this:
We decided to go with dual/parallel mufflers since we would essentially be cutting exhaust flow velocity/volume in half. Which basically makes the mufflers more effective both in terms of sound reduction and exhaust flow.
View from the back:
We added some simple 2.75" SS tips and oriented that with a nice gangsta lean. Enough to look a little different while not screaming LOOK AT ME.
Sound:
Very quiet! Using two mufflers instead of one makes HUGE difference. The exhaust growl is a bit deeper in note. Not much louder though. Which is unfortuante since we were hoping for a more inspiring sound!
Power:
It helps! Haven't re-dyno'd the car yet. With the factory muffler, we were seeing 275whp with the factory tune and 335whp with the Procede. I certainly hope we've picked up another 10whp. Should know soon enough
      09-20-2010, 08:14 PM   #2
cn555ic
cn555ic's Avatar
Drives: 335i
So thats the hookup that Shiv has from the East Coast!! Now we know where to bring our modified cars!! lol
      09-20-2010, 08:14 PM   #3
ak335
ak335's Avatar
117
Drives: Cayman S
Not feelin the postion of the tips :/
      09-20-2010, 08:41 PM   #4
FBOOST
FBOOST's Avatar
Drives: E90 335i LCI
+1
crush bends
      09-20-2010, 08:57 PM   #5
Calvin@Vishnu
52
Drives: 2010 335i
lol.. not quite. The car is front the East Coast. All the exhaust work was done here in CA. Only took a couple of hours. And should give us a definitive idea of how much power we can expect out of a catback in an n55.
Also, by no means am I suggesting that you guys should install crush bent piping in your BMW. We just did it for quick and dirty testing purposes. Cutting mandrel bends and piecing together a production quality exhaust wasn't possible (or needed) given our time constraints
      09-20-2010, 09:13 PM   #6
SfValley335i
Afghanistan
164
Drives: Current:135i Sold:335i sedan
I hope the two mufflers were welded together... or else I think they would bang against each other...
      09-20-2010, 09:16 PM   #7
Calvin@Vishnu
52
Drives: 2010 335i
Yep. They are welded together. And all original hanger points were used. The whole exhaust barely moves 1/4" when pushed/pulled. It's not going to vibrate or rub against anything.
      09-20-2010, 10:00 PM   #8
MikeDNJBMW
16
Drives: 2011 e90 335 ix, 08 335i e92 6
2012 bmw x5d  [0.00]
dude...looks pretty damn good! i like how its angled
but most important VIDEOS!!!!!!!!! :0)
      09-20-2010, 10:13 PM   #9
forza1976
forza1976's Avatar
Drives: BMW
2022 BMW M3X  [10.00]
Calvin, you guys gonna order up AR's new downpipe? Would be a great addition to that setup.
      09-20-2010, 10:47 PM   #10
chancejat
chancejat's Avatar
Drives: bmw
love the tips.....
      09-20-2010, 11:29 PM   #11
adrian@vishnu
Australia
39
Drives: 135i
Nice work Calvin!!
That car ripped without the exhaust... Will be interesting to see how it goes now. I was really impressed how well the N55 can go with just a Procede. I have a N54 135I 6MT with Procede, DCI and decat pipes, but the 135I N55 just with Procede seems to have the measure of my N54 with more mods. I think we will see some really nice results from the N55 platform, and we already have it in a few months at the same level the N54 took years to get to.
Adrian
      09-21-2010, 09:43 AM   #12
ES BMW
Drives: '12 E92 M3 ZCP 6MT
Did you cut open the muffler to view the layout? I think we would all enjoy seeing that...
'12 E92 M3 | 6MT | ZCP
      09-21-2010, 03:53 PM   #13
3pete3the5greekI
The GrEeK
3pete3the5greekI's Avatar
Drives: F30 335xi M EBII
i have a muffler delete on my car and it sounds like sex!!!
3P3T5Gi
2007 e90 335i (batmobile) ~ bye bye
2011 e90 335i M-Sport (Stella) ~ BYe Bye
2013 F30 335xi M-Sport EBII
      09-21-2010, 07:19 PM   #14
Brey335i
112
Drives: e46 ///M3
+ 1 on not really feeling the "gangsta lean"
      09-21-2010, 07:25 PM   #15
Clap135
Clap135's Avatar
102
Drives: 2009 N54
All the money you guys make and you go with a hack job? WHy?
Arnt the n54 midpipes identical to the n55?
      09-21-2010, 07:41 PM   #16
OpenFlash
Drives: A Lot
I didn't want to use the typical off-the-shelf 135 54 midpipes that merged both pipes into 1 outlet. I wanted to try something new and stay fully divorced all the to the tips. The other option was to do a single 3.5" exhaust all the way from the turbo outlet to a single tip (with single muffler). But that would have required cat removal and the installation of an aftermarket cat which I don't have too much faith in.
Regarding this design, if the results are good, we will go into production with it. But with SS (not aluminized steel) and mandrel bends (not crush). But first things first. The angled tip was mainly done so that we could use a more gradual pipe bend exiting the muffler body. I think it looks nice but will probably go with something more traditional looking for production.
-shiv
      09-21-2010, 07:55 PM   #17
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
Holy shit shiv tore the crap out of those rfts. Pic #5
E90 LCI N54 6AT
