V4 PROceede downloading / decompressing files Plz help:
09-11-2010, 11:54 AM | #1 |
I AM the 12th. Emom
48
Rep 1,007
unable to open zipped files after download! Beta release 8-17 maps / firmware p
and PROcede user software v4.10 autotuning after trying to extract in posted link i get following error: "cannot complete the compressed (zipped) folders extraction wizzard the compressed folder is empty. before you can extract files you must copy files to this compressed folder" properties show this file as 5.72 kb?? this happens with Both files..
e92, 335i SG/ Coral. 6m, LSD,
09-11-2010, 12:11 PM | #2 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Did you try compressed downloading the files to your computer first? Once on your computer, you should just be able to select them. Winzip (or whatever extraction program u have) should open the folder. Then just drag the contents to your desktop. That's really about it.
Shiv |
09-11-2010, 12:32 PM | #4 |
The Stig
31
Rep 1,232
09-11-2010, 12:46 PM | #6 |
I AM the 12th. Emom
48
Rep 1,007
i have several times errors-- does not appear to be a valid file archive
other error...please insert the last disk of the multi part volume to continue...
09-11-2010, 12:58 PM | #8 |
I AM the 12th. Emom
48
Rep 1,007
UPDATE:
there seems to be some problem using FIREFOX to down load.. I AM able to sucessfully download / extract when using IE ... so its something to do with my browser.. thanks Bolty that was my only next option! ok so just to confirm.. all I need to go from my V3 rev.2 to the latest/ greatest v4.1 are these 2 downloaded zip files.. 1. PROceed user software v4.10 AutoTuning 2. __BETA release 8-17 maps with firmware 28.
09-11-2010, 01:36 PM | #9 | |
1737
Rep 17,960
Drives: A Lot
shiv |
09-11-2010, 01:42 PM | #11 |
1737
Rep 17,960
Drives: A Lot
Yes correct. But according to the OP, he already has a Rev.2. But is still running v3. The only thing else he may need are the CANbus wires in the harness. But I'm pretty sure all of the harnesses on the road have that already.
Shiv |
09-11-2010, 01:45 PM | #12 |
I AM the 12th. Emom
48
Rep 1,007
theres a v4 hardware?
now the final problem... connectivity to the PROceed!! I cant seem to get it to go "online" computer says the cable is com 5 so i enter that under com setup.. (does not remember the com settings) fails to connect
09-11-2010, 01:49 PM | #13 | |
1737
Rep 17,960
Drives: A Lot
As for communication, are you sure the ignition power is fully on (not just accessory power)? Shiv |
09-11-2010, 02:03 PM | #14 | |
I AM the 12th. Emom
48
Rep 1,007
power IS fully on , (motor running) using com 5 (com 4 is taken) the com setup box is always empty when I switch to try different coms..
09-11-2010, 02:25 PM | #15 |
I AM the 12th. Emom
48
Rep 1,007
ok FINALLY after deciding i want to run the cable to the glovebox i found the cable at the serial end has become DISCONNECTED!!!! aghhhhhh
so anyway now all is working!! sorry for waisting your time...
09-11-2010, 02:33 PM | #16 |
1737
Rep 17,960
Drives: A Lot
09-11-2010, 02:45 PM | #17 |
C7Z - Darkside
50
Rep 226
I posted in the other thread, but I'll mention it here because it JUST happened to me: Make sure you update your settings after downloading the new firmware / maps to baseline settings. My V3 -> V4 settings had 100% Meth /Nos Progressive turned ON (should be off if not running Meth) and boosting to 18lb of boost. Obviously, you don't want that.
Put your settings to a baseline like the picture on Shiv's thread on the Vishnu Tuning board to start to be safe. Enjoy autotuning! |
09-11-2010, 04:19 PM | #18 |
I AM the 12th. Emom
48
Rep 1,007
thanks Draven... so far all ok here all default values!!
NOW finally, should i reset all the adaptation settings before going on first drive?
09-11-2010, 04:22 PM | #19 |
1737
Rep 17,960
Drives: A Lot
You don't have to change all the default values. Once you load up the map with the software, they will already be there. The default values are loaded in the map, not the software. Just make sure you give the software a few seconds to read the map from the procede before opening up the user adjustable page. You will see it go from 0 to 100% in the status bar. If you don't let it do that, the user software won't fully read the map on the procede and show the wrong settings.
09-11-2010, 05:07 PM | #20 | |
C7Z - Darkside
50
Rep 226
That said, I just dialed them down using the picture you have on the Vishnu forum and couldn't be happier with the car's/tune's performance now. |
