Lowering springs only
09-07-2010, 11:09 AM | #1 |
31
Rep 309
Are there any lowering springs that work well with the OE Msport dampers without having to replace the whole suspension? I wnat it to firm up slightly after changing to non runflats but not get bone jarring?
335d Xdrive Msport Plus, ACS springs and lots of toys
Range Rover Evoque Dynamic Lux VW Touran 1.9Tdi, 18" wheels, superchipped and lowered! |
09-07-2010, 12:19 PM | #2 |
475
Rep 13,583
Drives: JB E92 335i
If your on a budget and simply want to purchase a set of lowering springs I would recommend that you check out the Eibach Pro Kit Springs to match your M-Sport Shocks. Eibach Pro Lowering Springs provide a slightly more aggressive and raked stance than your stock suspension while still maintaining a comfortable ride. They will also fit your BMW's stock shocks and are a great and affordable way to increase handling while giving your car a lower stance. On average Eibach Pro Lowering Springs will lower your vehicle 1.4" in the front and 1.0" inch in the rear, providing for a lower center of gravity and improved handling. Pro Springs feature more control than that of the OEM springs, but are still comfortable for daily use. I'll shoot you over a PM with more details!
- Alan |
09-07-2010, 12:58 PM | #3 |
375
Rep 17,017
Stiffer aftermarket springs are going to put more wear on your stock shocks than the OE springs so you will have to go into it expecting to replace the shocks sooner than with an OE setup.
With that said, the three most popular setups are the H&R Sports, Eibach Pro Kit and B&G Lowering Spring Set. The last two are the least aggressive of the three in terms of ride quality and stiffness. |
09-17-2010, 12:16 AM | #4 |
Rep 60
I put the Eibachs with stock shocks on my 335 and while I though the ride was nice originally, I feel like they are underdamped and need a better shock to go with them. The end result was a car that was bouncy over large bump, but fine with smaller bumps.
I'm planning to put Bilsteins on the car and expect the ride to be smoother over the larger bumps now but harsher with smaller bumps; overall I think the ride will be more comfortable and handling will significantly improve. |
09-17-2010, 12:09 PM | #5 |
142
Rep 2,900
I've been thinking about doing this as well in the near future.
I would recommend getting new shocks imo. |
09-17-2010, 12:13 PM | #6 |
DENY THE WORLD THAT SURROUNDS YOU
505
Rep 35,580
Drives: JB 33ZERO
H&R Sports - no questions asked!
Eurocharged V5 | ROW's / CC Delete | K&N's | H&R Springs | Single Fin G.B. Grill | Mode Carbon Diffuser | JBSpeed CF Spoiler | Arkym Style CF Splitter | CF Mirror Caps | 5% Tints | 12mm Spacers | |
09-17-2010, 12:56 PM | #7 |
253
Rep 7,089
Drives: '06 AW 330xi
Off the top of my head, running stock shocks with lowering springs will give you the following:
1) Rough ride 2) Accelerated shock wear Unless you plan on swapping out your shocks within the next year or two, I would hold off and save up for a spring AND shock combo or a coilover kit. Vendors don't tell you the risk of running on a setup like this....they post to sell. |
