Turbo cool down question
01-12-2007, 08:46 PM | #1 |
179
Rep 3,125
I saw a question in the Bimmerforums that was kinda interesting.
"I have to let me 05 STi to cool down before shutting it off, but it is oil cooled. If I'm not mistaken the 335i is liquid and oil cooled like the new STi. So do I have to let it cool down or is it ok to shut it off right away." Now I was wondering the same thing because when I run my car hard. I usually will let it sit for about 3-4 mins before i turn it off. I guess im just old school like that, since the car doesnt have a turbo timer.
Previous - E90 335i, E82 135i, E89 Z4 3.5SI, Range Rover S/C, Ultra White RCF, Maserati Granturismo
Current Lexus: SMG LC500 performance package Porsche:1973 911E Ferrari 575 SA, 458 Italia |
01-12-2007, 10:36 PM | #2 |
41
Rep 3,200
Why do you need to let the car cool after you're done driving? Its not going to get any hotter while its off and its not going to get much cooler if it isn't moving...
Edit: Nvm, just looked it up. Its a turbo thing.
328xi Coupe, Montego Blue on Black with Alum, Step, Sport, Premium, CA, PDC, Cold Weather (Damn Pennsylvania winters)
Current Mods: Heavy right foot - Planned Mods: Lightweight right foot |
01-12-2007, 10:46 PM | #3 |
179
Rep 3,125
Oh.. I guess you dont know how turbos and the oil that cools them down work.
The oil that sits in the turbos when you immediately shut down the car is very hot. By the oil circulating in the turbos at a lower temp, this prevents cracks in the turbines. Which keep your turbo alive longer. Thus why people get turbo timers, or sit by their car while its stationary after a spirited drive. Now my question is that I heard the 335i has a built in turbo timer or circulates cool oil through the turbos when the car is shut down. Wanted to know if that was true or not. So I dont have to get a turbo timer.
01-12-2007, 11:00 PM | #4 |
335
Rep 7,719
Turbo timer is mostly a show mod in my eyes. Modern turbo'd cars are a lot more efficient at cooling down than older ones. I have a turbo timer in My Evo, and most of the time, I don't even use it.
The oil will not cool that much off within 30 seconds to a minute of idling (Avg time people program their turbo timer for). It just makes you look "cool" when you get out of the car while it still runs and have the car turn off a bit later. If I go on a track, and push my car hard, I will let the car sit while it's on for a good 5-10mins, but this is pushing it VERY HARD, not normal everyday driving where you encounter redlights and/or stay at a consistent low rpm like on the highway. I used to be paranoid too, when I got my Evo and let the car run for several mins after a normal drive to school, run errands, etc. until I found out that it's not really necessary. |
01-12-2007, 11:04 PM | #5 |
179
Rep 3,125
Naw thats what I was asking. "Spirited" driving, as in tracking it or drag striping the car.
I dont let my car sit when i get to work or whatever. But I do let it sit after I drive it very hard.
01-12-2007, 11:08 PM | #6 |
11
Rep 812
The coolant (water) pump is electrically driven and will run after the car is shut off. Both oil and coolant go through the turbos and thus the coolant still takes heat out of the turbos even after the car is shut off. So, in effect, there is already a "turbo timer" that works without having to keep the engine running.
01-12-2007, 11:12 PM | #7 | |
179
Rep 3,125
Nice thanks a lot jmonier for clearing that up.
01-12-2007, 11:16 PM | #8 |
10
Rep 170
You can hear the pumps continuing to run after shut down (as long as the car was brought to normal operating temps for a period of time).
You can only hear them if you're in the garage or someplace relatively quiet but they run for anywhere from 30 seconds to a minute in my experience. |
01-13-2007, 12:39 AM | #9 |
Your resident 4um troll
123
Rep 2,020
i have a question for you, whats the diffrence between a bunch of oil running through your turbo at 200 degrees and a bunch of oil sitting in your turbo at 200 degrees?
i meen i understand the oil sitting in your turbo is going to get hotter if the turbo is hotter than the oil, but if its circulating its not going to take long for most of the oil to get up to the same temp as your turbo... with the car not moving foward the oils not going to be cooled very much, so id guess after the oil is circulated enough to be the same temp as the turbo, its not going to help anymore
RAWRrrrr
01-13-2007, 12:57 AM | #10 |
71
Rep 613
save your money!
http://autospeed.drive.com.au/A_0145/cms/article.html
"You're Mad If You Don't Have a Turbo-Timer Fitted to Your Turbocar..." Basically, a turbo timer just an elaborate egg timer with an output relay - and a lucrative price. The idea of these timers is to keep the engine running for a pre-determined length of time after the ignition switch has been turned off. This enables the turbo to cool down more gradually and prevent oil choking up within its core. This makes sound engineering sense, but the concept of not being on turbo boost just before you switch off seems more logical. Take the effort to drive the car gently before shutting off, and maybe let it run for another 30 seconds while you put your sunnies back in the glove-box and put the steering wheel lock on. It'll save you money, possible difficulties with alarm interfaces and, above all, it won't give car thieves an easily-accessible bypass to your vehicle's ignition system. |
01-13-2007, 12:18 PM | #11 | |
Eight Bimmers and counting
35
Rep 761
I CAN'T WAIT TO SEE / HEAR / TRY ALL THIS! My car should have arrived in NY two days ago, and I'm hoping to take delivery in the next 4 or 5 days.
2014 F10 M5
Previously... Threes: '08 E90 M3, '07 E92 335i, Fives: '11 F10 550i, '02 E39 M5, '00 E39 540i/6, '97 E39 528i, '92 E34 525i Others: VW, MBz, Peugeot, Toyota, Olds |
01-13-2007, 01:26 PM | #12 |
Rep 123
turbo shutdown
Turbo's get there power from the exhaust heat. This is very hot. Easily greater than 1500F. When you suddenly turn off an engine with a turbo (especially if you have been driving it hard) all this heat has to be dissipated. You can easily fry your oil. Letting it idle circulates the oil ( and water in a bmw). With low boost this heat is quickly lost. Your oil, engine and turbo will last much longer if you practice letting the turbo run at idle for a short period of time before turning the engine off. When I was really into this stuff we would let things idle till we could no longer see the exhaust housings glowing red. Unfortunately that is not easy to check on an automobile.
01-13-2007, 02:58 PM | #13 | |
123
Rep 2,020
RAWRrrrr
01-14-2007, 07:19 AM | #14 | |
8
Rep 188
Apparently he was flogging his car (stage3 s4) quite hard for some time, and at a point, had to use the bathroom urgently. As he drove into the highway's restroom to relieve himself, his gf switch the ignition off without hesitation. They came back on a tow truck. That doesnt warrant a turbo timer, but it sure is food for thought. |
01-14-2007, 09:38 AM | #15 | |
325
Rep 4,484
And more than likely he would of been leaving on a tow truck if she was to of left the car running too. The flogging of the car for some time and the fact is was the TT S4 was the issue. I've owned a half dozen turbocharged cars, the first back in the late 80's before most even had intercoolers, and WAY before all the electronic gizmos they have now, with less precise engine specs, not as good oil, etc etc. Sure letting the car "cool down" immediately after running it hard was wise and probably necessary. Now, I still wouldn't track the car or be flogging the hell out of it and come to an immediate stop and turn the car off. But I wouldn't do that with a naturally aspirated car either. Just be smart...if you are flogging the car hard and are almost at your destination, drive normally for the last mile or two to let the turbo(s) cool a bit. If you are at a track, drive it back to the pits slowly keeping out of boost. There are millions of turbocharged cars in the world, do you think everyone who has one that flogs the car...or drives on the autobahn for hundreds of miles at excessive speed, pulls off and lets there cars sit for 5+ minutes before turning them off?? Ask the techs at a dealer, "how often do turbocharged cars come in with turbo failures?" and then, "how many of them were caused because it was driven hard one day and not given an extended cool down period before turning the engine off?" |
01-14-2007, 11:05 AM | #16 | |
184
Rep 1,702
Drives: Audi TTRS, 335is
01-24-2007, 03:27 PM | #17 |
7
Rep 173
Good points have been made here. So we interrupt your normally scheduled programming for a cooking lesson. I season my wok after every use. I never wash it with detergent or use scouring pads in it. Just warm some water in it, wipe the water around while on the burner, rinse, dry and put it back on the burner and set on high. Then I put a little oil in it and coat the whole thing using paper towel. The oil will heat, smoke and then coke and harden. This is called seasoning. If you examine any good cook's wok, it'll have a hard, black coating in the bottom.
Essentially this process can happen in a turbo. Stationary oil in the turbo will overheat after the car is turned off through a process called heat soak. The oil will coke and harden. It is akin to clogged arteries. The turbo can turn as fast as 200,000 rpm; if the oil supply to the turbo’s bearings is impeded in any way, they'll be ruined real quick. Hence the old turbo timers and the electric coolant pump in the 335 to circulate coolant after the engine is shut off as well as the properties of the newer synthetic motor oils. Shawn Phoenix |
01-24-2007, 04:20 PM | #18 | |
The limit of adhesion is my home.
1702
Rep 3,778
2019 X3 xDrive30i Glacier Silver | Cognac w/ Fine Cove | MSport | Premium | Dynamic Handling PKG | Drive Assist | HK w/ Bavsound Upgrade |
02-17-2007, 06:12 PM | #19 |
148
Rep 880
I realize this is a kindof old thread... but I have a Q.
I don't hear the turbo/oil cooler running any more when I turn off my car? Even when the engine is at full temp (few ticks above 210). I just got the car a week ago ago and for the first few days I heard it running after I shut the car off... it was like a very faint pump sound, but the last 3 or 4 days I haven't heard it. Should I be worried and go get this checked out or does it just not come on all the time? Not sure if it matters, but it's sorta cold here now.... 20's at night and maybe low 40's during the day. |
02-17-2007, 06:22 PM | #20 | |
11
Rep 812
02-17-2007, 07:10 PM | #21 |
148
Rep 880
Yep, I just went out and started and then turned off car, then hit the rest button and I hear the pump come on and run. So the pump works... it just doesn't come on after the car goes off anymore.
I'll call my service dept and see what they say about this. I'll just idle it for a few minutes before shut off till I get an answer. |
