alignment on e90 using e87 specs
08-29-2010, 05:27 PM | #1 |
7
Rep 203
I have a standard e90 with 18 inch wheels, had alignment done, but I noticed the spec sheet with the camber, caster, toe etc, that they used E87 specs.
Is this ok ? I'm concerned the specs to which they calibrated are not correct. Please advise..... thanks.
Car handles so well, I always have to "stop short"
08-29-2010, 06:35 PM | #3 |
Freight Dawg
104
Rep 2,103
It might be the same... It also changes with sport/nonsport. Have that checked at the place you got the alignment. If it's wrong have them do it again.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors |
08-30-2010, 09:45 PM | #4 |
7
Rep 203
Took it back and asked them to check the alignment, it was off a slight bit, perhaps still within specs, but they did it again for free and the car is noticeably perfect.
