misaligned projector??
08-26-2010, 01:59 PM | #4 |
8
Rep 322
08-26-2010, 02:01 PM | #5 |
8
Rep 322
08-26-2010, 02:13 PM | #6 |
146
Rep 1,922
Drives: E90 335i, E70 X5
does it just happen recently? when u start up the car, can u see the self-leveling initiates and but driver side just doesn't move up and down? my happened last month and warranty it, dealer said it was a bad headlight.
-eric
E90 335i TiAg *STOCK* see my garage for mod list.. E70 X5 SGM *try to stay stock* :/ |
10-19-2010, 07:21 AM | #10 | |
I ask the questions you're afraid to ask.
44
Rep 2,489
No, no and NO! If a headlight suddenly goes out of alignment it means that there is something wrong. Adjusting the screw will not fix the underlying issue and will make correcting it that much harder. The OP probably hit a pothole and the headlight went into the "I'm broken, so I'll point down so I won't blind oncoming traffic" mode. The car needs to go to a dealer. As we suspected, the OP did have a bad headlight - probably caused by a pothole. Even if it just a "simple" adjustment then it still needs to go to a shop. Nobody can align a headlamp properly without proper equipment - the "25ft away from a garage door" method doesn't work correctly and you will blind oncoming traffic. |
10-19-2010, 07:35 AM | #11 |
Rep 65
I hit a pothole a few days ago and i punctured my tyre but worse off, my headlight moved to sit about 35 degrees upwards from it's original position. it almost looks as if it has been "bumped" out of it's casing.
would adjusting the headlight height via the screws help or would it be best to take it into the dealership? thanks! |
10-20-2010, 01:52 AM | #12 | |
8
Rep 322
10-20-2010, 04:09 AM | #13 |
1706
Rep 14,829
On two occasions last week, I encountered E92's where the right side light was pointing up. I figured the owners/leasees didn't even know. The one that was behind me was very annoying, kinda like those cars that have the bright blue replacement bulbs. It prompted me to look at my own car--doesn't seem to be like that as I looked from a distance, as well as shining the lamps on the garage door.
10-20-2010, 07:54 AM | #14 | |
44
Rep 2,489
10-20-2010, 08:16 AM | #15 | |
36
Rep 564
What "equipment" are you referring to? |
10-20-2010, 08:44 AM | #16 | |
44
Rep 2,489
This |
