08-24-2010, 03:08 PM | #1 |
Happy Camper
612
Rep 7,869
Drives: C63 AMG & 280 SL on Weekends :
Garage List 1969 Restored Merce ... [7.50]
2011 M3 Coupe TRADED [7.34] 1987 BMW 535is [1.00] Cars from the Past [6.50] The ///M3 Engine S65 [9.59] |
N54 Tune Comparison Chart includes Z435i (Detailed)
I found this in the 3 Series Forum here, it also applies to the Z4 35i ... I thought it might be of interest to some of the Z4 35i members here ....
Thanks to AltecBX Member of this Forum for posting the original Chart. Disclaimer: Anything aftermarket can void your warranty. Read your new vehicle warranty carefully before deciding to start upgrading your vehicle. You are protected under the Magnusson Moss Warranty act which states that a dealer must prove that a specific modification is causing an issue before refusing warranty service. This means that they cannot outright void the warranty because you have an aftermarket mod but must prove that for instance a blow off valve is causing engine problems. N54 Tune Comparison Chart (Detailed) Click here To view the entire chart you need to go here ........ Here is the 3 Series Original Post
Cheers, Rolf-Dieter
Life will take us to some interesting places, fortunately The ///M3 will too with a many of us know this very well, now my C6.3 AMG with 487 HP does it too ---> Click here for some good stuff I found |
08-24-2010, 05:04 PM | #3 |
Rep 446
Drives: '09 Z4 s35i & '03 Z4 3.0i
It only shows Dinan Stage I, Stage II requires the oil cooler and gives 78 HP and 125 ftlb's of torque. The Dinan also has "Warranty" equal to BMW, free updates and it doesn't matter if BMW finds it because they install it.
Note: All the e89's with a sport package should have the oil cooler already installed.
Member ZSCCA 2009 Z4 s35i with Dinan Stage II software, Sport and Exec packages, 19" 296 rims , a stubby and mud flaps
'03 Z4 3.0i Sterling Grey (Hers) '01 Z3 3.0i Sapphire Black, M sport package (Mine) |
08-24-2010, 06:11 PM | #4 | |
89
Rep 1,838
that's correct info.
09-01-2010, 08:31 PM | #6 | |
60
Rep 2,087
I always wonder about those charts. One issue Dinan has with typical dyno testing is a lack of air movement through the front end. Most dyno shops have a small fan that cannot approximate the air movement at 70+ mph, and therefore the engine cuts horsepower.
"Political correctness is a doctrine fostered by a delusional liberal minority and rabidly promoted by an unscrupulous mainstream media which holds forth the proposition that it is entirely possible to pick up a turd by the clean end".-- Unknown
