Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > STi Brembos on a 335i?
      08-23-2010, 12:15 PM   #1
iBoost335STi
Drives: 2007 335i
I have the front gold brembos off my 07 subaru and i was wondering if anyone knew if i could transfer them over to my 07 335i that i will be picking up wednesday.. not looking to swap rotors just yet.
Thank you, Paul.
-430AWHP Fully Built, Big Turbo & Meth...RIP Subie
-E90 335i
      08-23-2010, 12:37 PM   #2
Mr. 5
Modder Raider
Mr. 5's Avatar
Scotland
753
Drives: M3
2007 e90 335i  [8.00]
If anything, they might fit on the rear.
Most likely not the front. The 335 rotors are pretty big in the front.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD
Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM
      08-23-2010, 02:59 PM   #3
kevin@bavarianx
Drives: E36 M3
You will need someone to machine you custom brackets to fit the calipers. STi Brembos are pretty small compared to the 335 brakes.
      08-23-2010, 10:22 PM   #4
iBoost335STi
Drives: 2007 335i
are 335 breaks 4 piston? would 135 breaks fit easier?
-E90 335i
      08-23-2010, 11:59 PM   #5
kevin@bavarianx
Drives: E36 M3
the 135 brakes would be an easier swap as they are 6 piston front and 2 piston rear. The 335 brakes should be a 1 piston i believe.
      08-26-2010, 03:50 PM   #6
biz77
174
Drives: 2021 X3 M40i
From one Subaru guy to another, why would you want to? Your Brembos can easily be sold to a WRX or Legacy GT owner. STi Brembos are ~ 1" smaller than the 335 front brakes. Stopping power is NOT dependent on the number of pistons in the caliper, but rather the piston area, pad sweep area and Mu (coef. of friction) of the pads being used. That said, monobloc calipers typically flex much less than a sliding caliper and as a result offer better pedal feel and modulation. Overall, neither a 135i or STi brembo would be an upgrade in stopping power to the front brakes on a 335.
      08-26-2010, 04:20 PM   #7
e90pilot
Freight Dawg
e90pilot's Avatar
Drives: E90 325i
Correct, all the non-M 3s are single piston floating caliper. 135s run a smaller diameter rotor but have solid calipers. Biz77 is also correct. If you were to go with 135 brakes you would need to upgrade the rotor and pad so something more aggressive. The slots on the BMW performance rotor help dissapate heat better as well. I've seen race cars with very little breaking area on the rotor. Although they are ligher, they operate at much higher speeds. The reason they can get away with small pad area is the fact that they don't really care how quiet or dusty they are. They also don't need them to work when they're cold. So they use really high heat capacity rotors and pads which work great at high temps but work poorly when they're cold and make a lot of noise. Not really a quality you want on a street car.
335s already have great stopping power thats repeatable on the track. Just the pedal feel is a little soft. You'll get about 60 hard applications before they fade completelely.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors
      08-26-2010, 05:08 PM   #8
Gavin@MMW
Gavin@MMW's Avatar
Drives: MMW Supercharged E90 328i
And you get 6 with a nonsport 328 lol
Im adding the OEM 335 brakes to the car over the 135 kit
      08-26-2010, 08:32 PM   #9
e90pilot
Freight Dawg
e90pilot's Avatar
Drives: E90 325i
LOL! My 325 zsp didn't do too bad on the track. I did 5 20min sessions at Thunderhill and the pedal was soft but I still had good braking action. At least it's not a 370Z. Their sport package has HUGE brakes and they're AWFUL. The fade with just 2 hard applications. Car and Driver crashed one because it wouldn't stop.
I would go for the monoblock instead of the floating caliper, but that's just me.
--Marcelo
      08-27-2010, 09:31 AM   #10
335isGuy
32
Drives: 2018 Bmw 340xi Msport
You can also add a soild Pin in the floating caliper to give it less flex. A nice set of SS lines, pads and fuild. Done setup.
      08-27-2010, 04:13 PM   #11
iBoost335STi
Drives: 2007 335i
much appreciated guys
-E90 335i
      08-27-2010, 04:51 PM   #12
mike-y
just another bmw douche bag
Drives: 1.9L of fury
if you are only getting 6 hard stops before fade, you need to change your brake fluid and pads.
      08-27-2010, 06:05 PM   #13
Gavin@MMW
Gavin@MMW's Avatar
You are very right, but id rather upgrade because it looks better and performs better all around
      08-28-2010, 02:20 AM   #14
hun77777
hun77777's Avatar
Drives: SG E92
you probably made the one of the most insightful 1st post on e90post.com compare to most of people usually start with "hey where's the cheapest XXX i can get from?"
SGE92TT......................... 12.331 Sec @ 117.89 Mph............................POWERED BY
l BMS DCI l HELIX IC l FORGE DVs l RR OCC & CP & SCOOPS l AR 3" DPs l AE QUADs l BLISTEIN PSS10 l P3 VENT GUAGE l VISHNU PROCEDE V5 AUTOTUNE l Lots of Window Stickers
