F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > LSD in new 3?
ARMA SPEED
      08-17-2010, 01:58 AM   #1
k726
Member
Drives: 2011 335is
LSD in new 3?
I know LSDs were reserved for Ms but have noticed the new 5 has an ELSD and the 6 will too. Will the new 3?
      08-17-2010, 02:03 AM   #2
marcel b
marcel b's Avatar
132
Drives: F31 340i
ELSD is an electronic diff, meaning the brakes are used to limit the spinning of the inside wheel. This has nothing to do with a real LSD. March 2008+ 3series already got this, one series as well what I know. So nothing new.
      08-17-2010, 02:06 AM   #3
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
Drives: 06 330i 6MT
The 3er has unofficially had the eLSD since sometime in 08.
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit
M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear
      08-17-2010, 02:14 AM   #4
k726
Member
Drives: 2011 335is
Just wondering because I did not see it listed under specs on BMWNA. Sorry!
      08-17-2010, 11:47 AM   #5
noro
noro's Avatar
Armenia
90
Drives: '91 M3, '04 E46 ZHP, '72 2002
BMW also has the torque vectoring rear end, but currently only for X6M and X5M cars. I would love to have this piece if it does not add too much weight.
zhpregistry.net - ZHP stats and free classifieds.
      08-17-2010, 04:19 PM   #6
Brey335i
112
Drives: e46 ///M3
So what did it have before that?
      08-18-2010, 12:06 AM   #7
noro
noro's Avatar
Armenia
90
The whole evolution with this is actually pretty interesting. Back on early E46s the basic DSC feature would modulate rear brakes in addition to cutting away engine power when instability was detected. You had a choice between this fully intrusive mode, or no traction control at all. On later models they decided to take the system a notch higher and the 1st generation of e-diff was born. Only it wasn't called e-diff... in fact it didn't really have a name... or if it did, it probably was some lame ass abbreviation of 3 letters. In any case, stage 1 deactivation of the DSC allowed the engine power to be fed to the rear wheels regardless of traction conditions but the rear brakes where used to slow down the spinning wheels so that the torque would transfer over to the other wheels. The end results was a very fun to drive car in snow. On E9x they went with a more advances system in which the "activation of ATC", meaning deactivation of all full control of the computer over the engine and wheels meant that the spin threshold before the system kicks in was increased. The end results was that the car would allow a bit wheel spin before the engine power would cut out, in addition the steering angle was factored in when applying individual brakes to the rear wheels. The end result of that system was better snow traction, but the fun factor was gone because the car became more obedient and did everything in its power to go where the front wheels are pointing. E-diff, brings back the concept of later model E46s in which you have a mode for simply preventing the 2 rear wheels from spinning at very different speeds (aka classic LSD), but the engine power is continued to be fed. In case of e-diff, based on feedback of others, the precision and smoothness of the system is greatly improved over the E46s.
I had a pleasure of owning E46s and E92 over Boston winters and the ability to fling that E46s around is a considerable grade higher than the E92. Thankfully I have E46 back in my stable and can't wait for this winter!
      08-18-2010, 12:31 AM   #8
k726
Member
Drives: 2011 335is
Nice post. So basically the upgrade was really a downgrade in terms of performance, but a positive move towards safety?
      08-18-2010, 12:07 PM   #9
swifty
314
Drives: F80, Levante & Tesla 100D
k, i'm a little confused.
so are you saying for winter use in the e92, I have to press the dsc button once to activate the e-lsd (brake one wheel so power can be sent to opposite wheel)? ... or I just don't press anything cuz e-lsd is always on.
thanks.
      08-18-2010, 05:47 PM   #10
k726
Member
Drives: 2011 335is
e-lsd is always active through the DME. The open diff is what allows the E-LSD to distribute power to a different wheel. Having DTC enabled will first check for wheelspin... when there is too much wheelspin the DME will limit engine power in an attempt to stabilize the overspinning wheel. It will also apply brakes in the rear to compensate for the overspin before limiting engine power. Sorry a bit sloppy but understandable.
      08-19-2010, 10:49 AM   #11
swifty
314
hey to the OP, i apologize for hijacking this thread. Just curious about the e-lsd because I thought only the 1 series had it. I always felt that my e39 and e46 drove better in the snow than my e60 or e92. I assumed the difference was because of the extra torque in the new cars, especially in the e92.
nway, i pressed DTC last night and it said "Dtc Activated, Dsc limited." Is this the best way to drive in the snow or should I not press anything?
Thanks for all the help. Learned quite a bit.
      08-19-2010, 10:51 AM   #12
DJKhan85
DJKhan85's Avatar
Trinidad_and_tobago
24
Drives: 2011 4dr 6mt Golf GTI
Check out this video. It goes into detail about the different modes. It doesn't specifically pertain to our cars but it gets the point across. If you are driving in the snow and need to get started, then press the dtc button one(activates DTC). Once you get going switch it back to full DSC mode.
2011 VW GTI 4dr-6mt-Sunroof-Nav-Xenons
OLD:
08 335i AW/CR/Poplar 6mt-ZSP-ZPP-ZCW-iPod-iDrive-PDC-Style 230s w/FK 452-Dinan LSD
      09-05-2010, 10:41 PM   #13
Artz 330
196
Drives: Z4M, 335i, 135i
2006 330i  [0.00]
DSC + XI = Beast, even with Stability control completly off the Xdrive is sweet, the back end you can do a controled drift while the front pulls you out. I loved my moms E90 330XI in the snow.
      09-05-2010, 11:26 PM   #14
woodpecka
woodpecka's Avatar
68
Drives: E91
Very nice video. We all know that DCT is good but this proove it.
I look forward to next winter to try the X-Drive!
      10-28-2010, 09:11 AM   #15
FLA 335
24
Drives: 2009 335i (SOLD) !!!!!
this is amazing... too bad i live in florida... i would like to try this as well!!
2009 BMW 335i Sedan / Auto / Paddles / Sport / BMW Assist / Heated seats / JB Matte Black Grill / Tischer First Aid Kit w\Triangle / Tischer Hood Pad / "Custom" rear fog switch <---- SOLD!!!!
f30post
