TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Wheel alignment & BMW Performance Suspension
      08-13-2010, 08:14 PM   #1
ABD
Drives: BMW E92 335i
Can I ask what should be the alignment settings on an e92 if it is fitted with the BMW Performance Suspension.
My car has the following setting at the moment. Are they correct?
Front:
Toe - neutral
Camber - neutral
Rear:
Toe - neutralCamber - negative 1.5 deg ( is this too much or should be 1 deg?)
What does BMW recommends? Some say all BMW cars in stock form comes with some Toe 'in' esepcially the rear. If that is the case, how much toe should be dialled?
Appreciate some guidance.
      08-16-2010, 02:22 PM   #2
kevin@bavarianx
Drives: E36 M3
Well for a street set up I would do
Front camber: -1.2
Toe: 0 or (.10 to .20 total) toe in for mostly highway driving
Rear camber is fine
Toe: .20 or 1/8" TOTAL toe in
      08-19-2010, 08:14 AM   #3
ABD
Thank you.
Is that the setting we get in our BMW when we first got our cars. I asked around and some say there is no toe at all in the stock setting while that are some that say it has(such as your description).
Am terribly confused.
      08-19-2010, 11:31 AM   #4
kevin@bavarianx
Drives: E36 M3
I like to add a little toe ;D for those corners
