BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Koni Yellow rear adjustment?
      08-10-2010, 11:36 PM   #1
BRO
Oldie Newbie
Drives: E92 2007 Auto Sport Red
Anyone figured out how to get at the adjustment on the rear shock without tearing out the trunk liner every time? Make a long thin adjuster out of tubing and drill holes in the liner to run it thru?
      08-11-2010, 01:33 AM   #2
dbjb
I sweat pheromones
dbjb's Avatar
203
Drives: e92 335i, retired SLK55
I'm fairly certain you must compress the shock to adjust which is why you must remove it. It's not like the fronts.
      08-11-2010, 03:08 PM   #3
BRO
Oldie Newbie
Not the yellows. I have a knob for the adjuster on top of the shock. Just can't reach it.
      08-11-2010, 03:58 PM   #4
The HACK
The HACK's Avatar
1821
Someone on the ZPost forums did this...
http://www.zpost.com/forums/showpost...4&postcount=38
Very clean IMO. I think you'll need to cut the long Koni adjuster and hack a rod on the end to make adjustment.
I just cut a flap on my rear carpeting and lift up the flap when I need adjustment. I may go the way of Mr. Rick Hunter's method.
      08-11-2010, 05:26 PM   #5
Gavin@MMW
Gavin@MMW's Avatar
Drives: MMW Supercharged E90 328i
^ good idea, without that it must be taken off.
      08-12-2010, 11:01 PM   #6
BRO
Oldie Newbie
Perfect! With hole plug and everything. Now figuring out exactly where to drill the hole...
      08-12-2010, 11:26 PM   #7
Fraggy
Fraggy's Avatar
Drives: 2016 M3
They MUST be compressed to be adjusted. Its a pain in the ass to have to remove them to make that happen. Dont let that little knob looking thing confuse you.
2016 Alpine White M3 (gone)
2019 Alfa Romeo Guilia (Totaled)
2020 Car-less 😁 (no more)
2020 M340
      08-13-2010, 01:20 AM   #8
Wlew
Wlew's Avatar
Drives: 2011 E90 335i
Whats the negative affect of adjusting the front to a stiffer setting and not adjusting the rear? is this bad or what can happen as far as handling? or does it help at all? just wondering. I love how mine ride, but would like to see what a little stiffer will do...
2011 335i Sports Package | VRSF FMIC | Cobb AP3 | Dinan Exhaust | BMS Intake | VRSF CP | Lux H8 Angel Eyes | Mtec LED Fogs |
      08-13-2010, 01:27 PM   #9
mike-y
just another bmw douche bag
Drives: 1.9L of fury
It's not necessarily negative, it will affect the balance of the car during transition. typically, making the front stiffer will increase understeer (or decrease oversteer). It all depends on how balanced your car is before the adjustment. Changing spring rates will make more of a difference, but adjusting the dampening can help fine tune the balance.
      08-14-2010, 04:31 AM   #10
dbjb
I sweat pheromones
dbjb's Avatar
203
That adjuster tool is just for the fronts. The rears must be removed and compressed to adjust.
