premature tyre wear/camber
08-09-2010, 02:33 AM | #1 |
179
Rep 3,923
in the uk we have a huge problem with the inner rear tyres wearing prematurely and ruining the tyres. some say its down to the negative camber. does anyone have this problem in the usa and is it possible fitting bmw performance suspension would make this worse or perhaps help prevent it.
08-09-2010, 02:39 AM | #2 |
33
Rep 812
Get an alignment. Negative camber is not the sole factor in uneven wear of the tires. Toe is responsible for the dragging of the tires causing the wear. Getting an alignment with 0 toe or a little toe for the performance oriented drivers will solve the issue.
08-09-2010, 04:31 AM | #3 |
Rep 82
Are you running Bridgestone RFT? If so I believe its down to the tyre design them selves. I have the same problem with mine (all 4 tyres). Two different shops do wheel alignments and both came back specs with in factory settings. Tyre pressure have been 39psi up front and 40psi rear since day one, go figure?
08-09-2010, 05:00 AM | #4 | |
179
Rep 3,923
08-11-2010, 06:54 PM | #5 | |
LSD - No, you're not seeing things
72
Rep 3,302
It is also VERY common on VWs like the Passat and thats FWD fixed geo. They knock off the inner edge is a ridge like fashion so you get huge road noise like a motorcross tyre! If you look at the camber/toe you can see why. And its definately a toe issue IMO. |
