Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Rear Passenger Wheel Gap Less Than Driver Side
      08-05-2010, 07:12 PM   #1
Kiyi
Drives: '07 E92 328i
Hi everyone,
The other day I was walking towards my car from the rear and noticed that the passenger rear was lower than the right. It looks like the rear driver side is almost 1-inch higher. I got home, measured again and it looked fine.
I noticed again this morning that it is off again...am I going crazy or do the e92's have some sort of auto levelling? The gas tank level didn't change much.
I searched but didn't find any definitive posts.
Thanks!
      08-05-2010, 07:53 PM   #2
2 3pair
2 3pair's Avatar
Drives: as often as possible
Were you parked on a flat surface? One side of my driveway makes the passenger wheel gap noticeable larger and the other side makes the drivers side noticeable larger.
      08-06-2010, 06:15 AM   #3
C.D.335xi
C.D.335xi's Avatar
22
Drives: 2013 X3
2014 Z4 35is  [0.00]
There's been a few threads on this. The suspension is set up so that when the driver is in the car his/her weight will level it out. That is why the driver's side sits a little higher when there is no one in the car.
2014 Z4 35is Deep Sea Blue - Sold
2009 E92 335i X-Drive 6MT - Sold
      08-06-2010, 07:26 AM   #4
Kiyi
hmm...i read those posts as well but why is it that sometimes it's completely level?
I was on relatively level ground...
      08-06-2010, 07:59 AM   #5
ALPINA2BMW
26
Drives: M2 Competition
I have the same problem with the AC Schnitzer Sport Suspension system fitted recently to my right-hand drive E92 where the front passenger side is 10mm higher than the driver's side; this is exactly the problem that I had before the installation with the stock sport suspension.
After querying this with AC Schnitzer, I have received the following response via email, "My best advice would be to enjoy the improvement in the car and to put this minor visual niggle out of your mind".
      08-07-2010, 08:27 AM   #6
2 3pair
2 3pair's Avatar
I just figure that sometimes you might think you're on level ground when you're really not. It might be even, but it's slightly slanted one direction. That's the only explanation I can think of for why the wheel gap would sometimes be on different sides of the car...
      08-07-2010, 09:35 PM   #7
335iDCT
11
Drives: 335i
The best approach will be corner weighting the vehicle; especially with coilover so that adjustments can be made.
