camber plate with C/O
08-02-2010, 05:58 PM | #1 |
11
Rep 190
I 've just have my coilover installed along with the camber plates, but I'm getting all kinds of noises. Other than road noises, I'm also getting 'cracking' noise from body twisting; especially when going very slowly over a speedy bump or curb. Seems like the noise is transmitted from the strut tower to the strut bar, then to the strut bars' attach point right below the windshield.
Has anyone with camber plates having the same issue? Are these normal noises that I should be getting from camber plates? The spring rate is ~340 lb/in, is it too stiff that causing the body twisting? I'm worrying about the C/O with camber plates causing too much stress to the strut tower and eventually cracking it. Pls help....... |
08-02-2010, 06:35 PM | #2 | |
99
Rep 1,050
08-02-2010, 06:52 PM | #3 |
11
Rep 190
08-02-2010, 10:54 PM | #5 |
The Law.
301
Rep 14,283
I have ground control race plates and the noise at low speeds or going over imperfections is definitely there, but thats just the nature of the beast. Due to the separate solid spring and strut bearings, there will be noise. With any metal to metal contact, noise is inevitable.
08-02-2010, 11:13 PM | #6 |
99
Rep 1,050
OP mentions a "cracking noise". That's not normal unless what's cracking to him is clunking to you and I. The metal to metal connection will make, what I call, a clunking noise.
08-03-2010, 02:47 AM | #7 |
11
Rep 190
08-03-2010, 03:05 AM | #8 | |
11
Rep 190
BTW, anyone has the part no. of the bar? |
08-03-2010, 09:15 AM | #9 |
99
Rep 1,050
If there are adjusters at the top of the coilover they could be rubbing on the underside of the strut tower bar. Konis create this issue. Easy to chack if there is rubbing.
If this is the case, I would just remove the stock strut bars. |
08-03-2010, 09:30 AM | #10 |
11
Rep 190
There is definitely clearance between the adjuster and the bar. I know if I remove the strut bars, the noice should go away for sure. But I want to keep these bars to retain the reinforcement they provide.
08-03-2010, 10:11 AM | #11 |
99
Rep 1,050
Confused. If there is clearance between the top of the CO and the strut bar the noise isn't because of that potential contact. If you know the noise is from the strut bar you're saying they are making noise somewhere else. Good luck
08-07-2010, 12:21 AM | #12 |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
Camber plates shouldn't be noisy at all.
Yes, you do feeling the jarring, but there shouldn't be any metallic like sound. Do you hear it from both struts? While turning left or right? On compression or rebound of the suspension? Did you check your anti roll bar endlinks to make sure they are secure? Maybe some installed photos, close ups if you can get them, may help me see obvious problems. |
08-07-2010, 09:30 PM | #13 | |
11
Rep 190
08-07-2010, 10:43 PM | #15 |
24
Rep 1,190
replace the stock strut bar with the m3 strut bar and then you won't have to worry about any clearance issues.
2011 VW GTI 4dr-6mt-Sunroof-Nav-Xenons
OLD: 08 335i AW/CR/Poplar 6mt-ZSP-ZPP-ZCW-iPod-iDrive-PDC-Style 230s w/FK 452-Dinan LSD |
08-07-2010, 10:54 PM | #16 | |
3847
Rep 54,376
Drives: F80 M3
The M3 strut tower brace is a good upgrade, it is stiffer and allows easy access to your adjusters and it looks cool. Let's find the source of your noise first before the upgrade. |
08-07-2010, 11:03 PM | #17 | |
99
Rep 1,050
08-08-2010, 11:33 AM | #18 |
11
Rep 190
08-09-2010, 09:29 AM | #19 | |
11
Rep 190
Photo of coilover with camber plate attached. |
08-09-2010, 09:45 AM | #20 |
24
Rep 1,190
When turning? My guess goes towards endlink not being tight or broken.
