BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > 335i BOV "map sensor"?
      12-30-2006, 11:22 PM   #1
IMJUSS2NASTY
22
Drives: BMW 335I MONTEGO BLUE
Shiv said that the 335i uses a "Map sensor" rather then a "Maf". Is this true? If so, this means having a Bov shouldn't cause any problems. Can anyone confirm?
      12-30-2006, 11:23 PM   #2
NaViT
NaViT's Avatar
Drives: 04 M3/E92 335i
yes a blow off valve wont cause no problems... theres videos and threads about this in the forum... use the button
      12-30-2006, 11:24 PM   #3
IMJUSS2NASTY
22
Actually, I have done and research and alot of people are saying that the Bov will cause problems. I even PMed Calvin@Vishnu and he said don't do it.
      12-30-2006, 11:33 PM   #4
teknochild
Your resident 4um troll
teknochild's Avatar
123
Drives: 335 coupe
he might have meant dont do it w/ xede, i know one of them stated that it might cause problems with the unit, not very sure at all though
      12-30-2006, 11:41 PM   #5
NaViT
NaViT's Avatar
check these threads out and make your own decision...
http://www.e90post.com/forums/showth...light=335i+bov
http://www.e90post.com/forums/showth...hlight=335+bov
theres more you just have to look
      12-31-2006, 12:45 AM   #6
IMJUSS2NASTY
22
Thanks for all the links, however I have seen them all. Alot of the threads only tell you how the car would sound and others just claim that there will be no problems. I guess I'm just being Naïve but I need proven facts. Thanks for your help though. Anxiously waiting the arrival of my 335i. 37 days and counting.
      01-05-2007, 11:29 PM   #7
vAnt826
63
Drives: E92 M3
From what I have read on forums, this sounds like a good explanation.
On other turbocharged cars, most have BOVs that go back into the intake chamber. Some ECUs know this (with sensors) and expect that extra air, the 335i apparantly ignores it and has no sensors. The extra air that the car would get would be hot and uncompressed anyway so it won't matter much either way.
I'm not sure 100% I worded everything correctly, but I think it's close
      01-07-2007, 11:28 PM   #8
BoostedBMW
Moderator
BoostedBMW's Avatar
Drives: TiAg E92 335
2003 S2000  [0.00]
I can't see how a BOV would be a problem with a car with a MAP sensor. If the 335i had a MAF sensor then it would make sense to me. Cars like EVO's and STi's have problems with BOV's since the ECU with a mass air flow sensor is expecting that extra air when you let off the throttle, but cars with MAP sensors shouldn't care.
-Michael.
Berlina Black S2000 CR is now in the garage
l 19" Rial Daytona Race l KW V2 l Eisenhaus Race Exhaust l
      01-08-2007, 02:07 AM   #9
LateralG
Taiwan
11
Drives: M54E46
what does MAP sensor stand for? mess air pressure?
      01-08-2007, 05:42 AM   #10
Jay@ATP
Drives: 02 S2k, 06 EVO IX
manifold absolute pressure, I believe.
      01-08-2007, 04:55 PM   #11
IMJUSS2NASTY
22
Shiv told me that the 335i runs on a MAP sensor, however Calvin@Vishnu claims it's on a maf sensor. I definitely believe shiv over calvin but it gets confusing. Would it be wise to install a BOV? I love the sound of it. Turns chicks on......
      01-09-2007, 12:05 AM   #12
LateralG
Taiwan
11
Drives: M54E46
thanks
      01-09-2007, 03:34 AM   #13
E90RWC
What you know about the twins?
E90RWC's Avatar
20
Drives: bmw
BOV is a must on the 335i.
I will get one if everything works out fine.
      01-09-2007, 03:41 AM   #14
wj4
Drives: E90 manual 335i
I'm sorry, but this has to be one of the funniest comment ever. The 335i already comes with BOV
You guys will find that VTA BOV gets annoying after a while since everytime you release the gas pedal, it will sound.
The whole reason to upgrade the BOV in the first place is to hold boost better, even Shiv said that the stock holds boost with no problem, I see no reason to upgrade...unless you want that ricey sound.
      01-09-2007, 11:28 AM   #15
Jonn335
South Africa
Drives: F07 535 GT
the factory dump valves sound just the same as any other dump valve if you disconnect the outlet and plug the pipe it went into. I think the 335i engine uses a Mass Airflow Sensor AND a Manifold Absolute Pressure sensor, in fact i believe it has 2 of the latter, one before an done after the throttle butterfly. Lots of people have firred aftermarket Dump valves, and it doesnt seem to cause a problem, maby the super smart computer can still run the engine fine without the extra air from the dump valve going back through the intake system.
535GT
      01-09-2007, 12:54 PM   #16
ORL335i
ORL335i's Avatar
Drives: 335i Sedan
My turbo VW's had a diverter valve which needed to be upgraded as more than factory boost was applied, I went with Forge diverter valves and never had an issue.
Not sure what kind of sensors VW's had but people that installed BOV's had issues with check engine lights.
I hope I never hear a 335i with a BOV - so ricey.
2007 335i Arctic/ Terra 6 Speed Sport Premium Sedan
      01-09-2007, 02:20 PM   #17
Panoz
Panoz's Avatar
84
Drives: E92 Space Grey 335i ,Aero Kit
Dont use BOVs. This car must sound like a BMW and not like a cheap worthless honda!
Procede V4 , Catless DPs, Forge FMIC, Injen Intake, VK Oilcooler, Hartge Quads Exhaust, Modded CDV, Synapse BOV Kit, BMW Performance 335i SSK Kit, P3 vent boost gauge
Space Grey 335i -> See more pics HERE
      01-09-2007, 02:40 PM   #18
IMJUSS2NASTY
22
Sorry guys, but I love that sound, everytime I ride with a chick and they hear a turbo spooling witht he BOV, they LOVED it. Might sound ricey to ya, but I love that sound.
      01-09-2007, 08:20 PM   #19
Edman951
Edman951's Avatar
50
Drives: 2014 i3, Capparis White
The 335 has 2 map sensors.
1 before the trottle body the combines presssure sensor and temp sensor.
And 1 in the intake manifold.
Also since the sensors are located after the diverter valve, if we where running a MAF the sensor would read the flow after the BOV open and would fuel the motor according to the accurate air flow.
In this situation the MAF would be called a blow thru MAF.
See pics of the 335 air induction overview
Look at nubers 8 & 11.
I also added more info on th efactory BOV.
      01-09-2007, 09:08 PM   #20
BoostedBMW
Moderator
BoostedBMW's Avatar
2003 S2000  [0.00]
Ignorance is bliss. Too bad I see myself as a car enthusiast that enjoys driving and not a superficial showoff, having owned both honda's and BMW's I cannot help but have your statement rub me the wrong way. I'm willing to bet that my honda could run circles around you, but since it doesn't have that fancy badge on it, it must be worthless. I wish this forum was filled with more car enthusiasts instead of some people who look down upon other brands that don't have the same snob appeal.
-Michael.
      01-09-2007, 10:07 PM   #21
derrick
100
Drives: e92 m3, i03 i3s, f80
x2
      01-10-2007, 08:29 AM   #22
Panoz
Panoz's Avatar
84
You becoming too serious !!! Just kidding guys.
We have a BMW and we got to enjoy it sometimes.
I also have an Opel Corsa 1.2cc ...so what?
Give me a break...
Just for your info (cause you called me Ignorant)...I may be a BMW fan and had many BMW along the last 10-12 years ,but keep in mind that my second favorite car is 350Z (a Nissan!!) and my dream as a new driver was to own a CRX (and later an S2000).
On the way ,I may bought BMWs but the truth is that I respect Honda.
