Angel eye installation without taking off wheel
07-29-2010, 08:05 PM | #2 |
Speed Demon
205
Rep 3,690
Super easy. Just requires smaller hands and some patience.
There's no reason to remove the wheel, or to not do it from the engine bay, either. Both AE's have a cap behind where the AE sits. 1. Unscrew the cap (it's about 1/4th turn) 2. Take it the cap 3. Reach your hand in the hole and twist the bulb (also about 1/4th turn) 4. Pull that out (the cable isn't long, so don't expect to be able to pull it out really far). 5. Pull the tab on the one side of the bulb, then the other, and remove the bulb. 6. Put the new bulb in (they only go in one way, so don't worry about putting it in wrong). 7. Reinsert it into the hole and line it up to the housing (this is by feel) 8. Tighten again with 1/4th turn 9. Replace the cap Rinse and repeat for the other side. First time might take you 10-15 minutes to do this, depending on the size of your hands. Subsequent attempts will take less time (I can swap mine in under 5 pretty easily now).
Current: '21 M5C, '15 X6 50i Previous: '18 M550i, '16 550i, '11 335is, '09 E93 M3 DCT, '10 E90 335d, '07 E90 328i |
07-29-2010, 09:57 PM | #4 |
Speed Demon
205
Rep 3,690
What year is your E90?
07-29-2010, 11:00 PM | #5 |
46
Rep 1,681
I thought it was supposed to be an even bigger PITA than removing the wheel?
2006 JB 330i/ZPP/ZSP/I-Drive/Heated Seats/L7/Blacklines/19" Gunmetal V710's on Vredestein Ultrac Sessantas/BMS PBX/Red MFD Scoops/Matte black grilles/Matte black Amber Gone 2.0s/BSW center midrange speaker/35% tint/Black and white roundels
07-29-2010, 11:16 PM | #6 | |
Speed Demon
205
Rep 3,690
You don't even have to remove the wheel to do the Fogs (but you do need to get into the wheel well).
07-30-2010, 02:45 AM | #7 |
195
Rep 1,985
You can do it without remove the wheel but it's going to be a PITA. With the wheel removed you'll have much more free room too work with and also avoid stripping those torx screws.
07-30-2010, 05:55 AM | #8 |
205
Rep 3,523
Drives: 2015 F23 M235i/2008,E90,335xi
took me 20-25 min / side last time. no big deal, unless you are flat rating your work for $$$.
08-05-2010, 07:42 PM | #13 |
Speed Demon
205
Rep 3,690
I agree. It's ridiculous to say that taking off the wheel is easier. By the time you get the car jacked up and take the wheel off, I'll have both AEs swapped out...
08-05-2010, 08:08 PM | #14 |
Roll Tide
591
Rep 2,345
Really stupid question about AE that I don't want to start a new thread about, but... when you buy angel eye bulbs online, does it come with 4 or 2? It seems like you'd need 4 at a time.
08-05-2010, 08:22 PM | #16 |
46
Rep 1,681
2. BMW only has one bulb on each side to power both rings. Don't worry I had the same question back in the day.
08-05-2010, 08:59 PM | #17 |
85
Rep 2,097
if u have small enough hands it really isn't that hard w/o taking off the wheel. The first one took me about 30 min bc I didn't know what I was doing at first. The second one took me 5 min.
08-05-2010, 09:21 PM | #18 |
46
Rep 1,681
So how does everyone do it? Rotate the wheel all the way in and then just dig in?
08-05-2010, 09:25 PM | #19 |
195
Rep 1,985
08-05-2010, 11:18 PM | #22 |
Speed Demon
205
Rep 3,690
Fogs don't require the bumper to come off, but you DO need to rotate the wheel and be ready to take off some bolts to get where they are.
