FS: QUAIFE LSD for 335i and vishnu XEDE computer
07-25-2010, 01:34 AM | #1 |
Rep 15
hi guys sadly ive had to trade down to an X5 from my E92 335i due to growing numbers of children - however it presents an opportunity for anyone that wants to add some pep to their 335i and/or embarrass M3s!
1. Vishnu XEDE computer and harness for 335i also suits 535i and 135i $400 this allows user changeable and selectable maps, overboost protection, is fully integrated into the BMW functions such as low boost until oil up to temperature, boost blending on gear shift and is invisible to BMW service! can be flashed with Manual, Auto or DSG maps free from Vishnu - more details at www.vishnutuning.com - installs in 15 mins! 2. QUAIFE limited slip differential for E92 335I. The ultimate performance upgrade for your 335i. Bought from Birds - the UKs premier BMW tuning company. full information at: http://www.birdsauto.com/quaife/default.aspx?make=BMW Check out the transformation it makes to handling at: Removed from a car now sold after only 10,000kms this can be yours. Had to sell my 335 as wife had a baby, my loss your gain! |
07-26-2010, 02:35 AM | #2 |
259
Rep 1,165
Drives: f83 / E93 335 / E70 X5 40d
How did you get the diff out?
I thought that if it had a welded ring gear, you would need to take the whole car in to have the ring gear modified. |
07-26-2010, 06:04 PM | #3 |
Rep 15
ummm my model was prior to welded ring gear, in any event it was performed by QUAIFE in the UK. what i am selling is a complete diff incl housing - you simply swap it out and away you go - only with more traction!
perhaps a picture will better illustrate... |
07-26-2010, 08:06 PM | #4 |
BLACK is BEST
11
Rep 151
LSD Diff
Check birds site. Maybe you can answer this.
Was you car a auto or manual. Is there a difference between E90 to E92 Will this diff fit a 2007 E90 335i sedan auto. Will I need extra parts to fit. Straight swap? Thanks. |
07-27-2010, 03:08 AM | #5 |
Rep 15
hello,
the diff will fit straight in - in place of your existing diff. takes someone who has experience with BMWs about 30 mins. Its from an auto. there is no diff ratio difference between a sedan and a coupe. My car was build December 2007 so should be no issues whatsoever. |
07-27-2010, 05:52 PM | #6 | |
259
Rep 1,165
I can't send you a PM, so please send me an email at: jp@advance.on.net and I will contact you. Thanks, Jp. |
07-28-2010, 01:06 AM | #8 |
BLACK is BEST
11
Rep 151
LSD
Still interested.
How much do want for it? Do you still have receipt for it. Would like to cross reference part numbers to double check compatability with my car. Thanks. |
07-29-2010, 07:49 PM | #9 |
Rep 15
i'm looking for $2.5K - it cost me $5k incl freight when i bought it.
It was without doubt the most noticeable performance and handling improvement ive made to any car - and it did not compromse ride/ handling or economy in any way unile changing suspension. I will dig around for the receipt but worst case ill reconnect with birds in UK and verify whatever information you're after. |
07-29-2010, 09:36 PM | #10 |
86
Rep 1,993
Quaife LSD is the best mod you can do, hands down!
Vishnu PROcede V5 | VK Motorworks FMIC | AR Design OCC | Forge DV's | Bilstein PSS9 | M3 Lower Control Arms & Caster Rods | Quaife LSD | HiTech Exhaust | BMW Performance Illuminated Door Sills | BMW Performance Gear Selector & Boot | BMW Performance E-Brake Cover
08-05-2010, 07:44 AM | #14 |
259
Rep 1,165
I would love to get it, but the ratio is all wrong for my gearbox.
Perhaps I could buy it and then get a new Crown & Pinion from diffsonline... |
08-31-2010, 07:24 AM | #17 |
36
Rep 738
Drives: G30 530i
how is the Vishnu Rev 3v1 different to PROcede Rev. II CANbus PnP which is the only one i can see listed on the Vishnu website?
