20' wheels on 335i coupe
12-28-2006, 04:10 AM | #1 |
14
Rep 252
I have just installed KW V2's on my 335i and my 20 inch wheels are coming in early next week. Fronts are 20x9's, 245/30/20 with a 35mm offset and 20x10, 285/25/20 33 offset for the rear. Am I going to rub? The V'2 are obviously adjustable but I want to keep the car slammed with out having to roll the rear fenders. Anyone?
12-28-2006, 04:39 PM | #3 |
156
Rep 10,411
You will rub without fender rolling.
2010 AW e90 328i: 6 speed, Black Leather, Dark Wood trim, ZPP, ZCW, ZVP,ZSP, Nav, Xenon
BMW Performance CF Rear spolier and Gloss black grills 2008 Candy White MKV GTI 2.0T 6 Speed Manul Gone 2008 AW X3 3.0si: 6 speed Returned 2006 AW e90 330i: 6 speed Dinan Stage 1 Returned |
12-28-2006, 05:09 PM | #4 | |
1569
Rep 29,202
12-29-2006, 12:28 AM | #5 | |
14
Rep 252
12-29-2006, 12:29 AM | #6 | |
14
Rep 252
12-29-2006, 06:14 PM | #7 |
156
Rep 10,411
with the rear offset on the coupe with a 20X10 on a lowered car I am pretty sure you will.
12-29-2006, 10:44 PM | #8 |
Moderator
132
Rep 6,775
Drives: TiAg E92 335
Fender rolling is not the end of the world if you have to do it. I did it on my current car, and its very easy to do. You can knock out each fender in under 20 minutes with taking your time and going nice and slow. Its a good investment when you no longer have to worry about shredding tires or pulling out your fenders from rubbing. Just something for you to think about.
-Michael.
Berlina Black S2000 CR is now in the garage l 19" Rial Daytona Race l KW V2 l Eisenhaus Race Exhaust l |
12-30-2006, 07:29 AM | #9 | |
Car Junkie
21
Rep 1,279
Drives: 335is / R8
I have 265/30's 19x9.5 30et not lowered, and I rub a little on deep corner bumps. I agree that a 20x10 285/25 with a 33et will rub if slammed w/o rolled fenders. |
12-31-2006, 02:23 PM | #10 |
23
Rep 143
i have a similar setup, iforged 20x10 with 33mm offsets, rear tires 285/25/20 contact sport 2's, and i have had a lot of rubbing, even with negative camber -1.75, also you cannot roll the rear quarter-panels, i have had them cut and hammered up and still they are rubbing. i have had it tested with the fenders rolled and it tucks in, but still rubs. it bothers the crap out of me. i sent them back to iforged and they are milling another 5mm from the mounting pad on all 4 wheels, hopefully this will make them fit, also with 30 front and 25 series tires on the rear, i hit the tiniest pothole and already bent 2 of my wheels which are being fixed at the same time, i hate it because it's a pain, but the car looks beautiful with them, i cant even look at it with my stock wheels
here are pics, pre rolling and pre camber http://www.e90post.com/forums/showth...light=dreaming |
12-31-2006, 02:58 PM | #11 |
115
Rep 1,439
whoa, i think the front is where the trouble is...
im sure the back will fit with a rolled fenders and some negative camber... but 9 in the front with 245s? im runing a 8.5 and 235 on the front with a 32 offset, and tats pretty damn agressive... Basically you''re setup is more agressive than that of an M3, and the coupe offset is slightly less agressive than the m3. you can certainly make it work, but not with a lot of trouble. Don't think u won't have to run negative camber and roll the fenders, because u will. good luck, and i bet it will look great. In the future when ur running 20s ull want less agressive offsets and slightly stretched tires so u can slam the car yourre desired amount. |
