AR Downpipes installation problem URGENT
07-21-2010, 04:35 AM | #1 |
79
Rep 1,617
Hi folks,
right now my shop is installing AR Design catted downpipes, but apparently they don't fit. The O2 sensor bungs are located in a wrong spot according to the shop This shop already installed dps (catted and catless) on a fellow forum member's car, so I guess they know what they're doing. Here are pics I received from the shop. Any advice??
Performance Seats, Exhaust, Splitters, Pedals, Steering Wheel / RB Turbos / M3 CF Roof / Brembo GT BBK 355/345 / Rollcage / Forge FMIC / Quaife LSD / Öhlins Road & Track / M3 Suspension Parts / Solid Subframe Bushings / Vorshlag Camberplates / Megan Racing Toe Links / LeatherZ Gauges / Extended M3 DCT Paddles / ER Sports OC / AR OC / Aux Radiator / AR DPs / Alpina TCU / COBB Pro-Tune
07-21-2010, 05:34 AM | #2 |
422
Rep 4,499
Give AR Design a call, they shuold be able to help.
Have BT Tool professional, will scan and clear codes on your BMW. And now I am able to code my 2011 335is and M4
Link to my M4 euro delivery! http://f80.bimmerpost.com/forums/sho....php?t=1006526 |
07-21-2010, 06:13 AM | #3 |
290
Rep 28,154
is this a left hand drive car or a right hand? who damaged the o2 sensors with a wrench or other tool? that one is definitely kinked from something
07-21-2010, 06:28 AM | #4 |
79
Rep 1,617
The car is left hand drive.
The shop is the only one who worked on this part of the car, except for a turbo replacement last year at the dealership. I hope that o2 sim isn't seriously damaged. I will give AR's phone number to the shop, but I'm in Europe and it's still early morning in the US. Any more input?
07-21-2010, 06:33 AM | #5 | |
290
Rep 28,154
i have installed more ar dp's then i can count, and never had a single fitment issue, the sensors are close to each other by nature of the cramped space between the turbo's anyway, but i never had the bung's welded in the wrong spot. as far as the sensor in the picture, someone really dented that thing good, i have seen it before, i can only assume its from the tech really pushing on the wrench to loosen the front o2 sensor, and when it breaks free, it hits the back 02 sensor hard enough to dent it. it may not be damaged internally, but considering the upper 2 o2 sensors help the car control fueling, it may be wise to just replace it now while everything is out in the open |
07-21-2010, 06:49 AM | #6 |
79
Rep 1,617
Yes, the shop told me the o2 sensors would hit each other and that they would need to relocate (weld) the bungs. What could be the problem?
What advice can I give them by phone? Thanks already for your help. Greatly appreciated
07-21-2010, 06:52 AM | #7 |
290
Rep 28,154
the way that the dp's are mounted now "loosely" on the turbo clamps, the can be rotated until there is clearance between the 2 sensors. now of course thats assuming the dp's were made correctly, it looks like it will work, but i would have to see the bottom of the dp where it meet's the exhaust too. the turbo clamps arent fully closed, so either the shop left them loose for adjustments, or they dont have them on properly, and they are as tight as they can get.
07-21-2010, 07:48 AM | #8 |
79
Rep 1,617
I forwarded your answers to the shop, and they replied that they tried everything but they can't rotate the downpipes enough to get the o2 sensors out of each other's way. They even tried to make a few millimeters space by denting the sensor
07-21-2010, 07:50 AM | #9 |
290
Rep 28,154
i hope they are going to replace the dented sensor free of charge. no offense, but i would get your car out of there asap!!!
07-21-2010, 08:21 AM | #10 |
159
Rep 5,689
+1
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(1addicts.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
07-21-2010, 08:21 AM | #11 |
79
Rep 1,617
I'll take a look at the car this evening, even if the work may only be completed tomorrow. They also install the AR Oil cooler and the Procede.
The shop is quite reputable. And since they've already done the same job on another car I thought everything would work out flawlessly
07-21-2010, 08:30 AM | #13 | |
290
Rep 28,154
07-21-2010, 09:19 AM | #15 |
2JZ
63
Rep 819
wtf? dude you must let them replace ur o2 sensor! they fucked up. samething happened to me few months ago, my shop kinked my front o2 by dropping the downpipe. but we are all close buddys so no biggie, ended up they paid $3xx(yeah canada sux) for the sensor for me and i paid 30 bux for beer lol.
anyway back to topic, theres NO WAY that AR will not fit. but theres is a little difference fitment between 07s and 09s, dont know about other yrs, 07s have more clearance than 09s thats all, however they all FIT GOOD. so my only guess is your shop sucks. let them replace the sensor and find another shop. btw: do u have an XI by any chance?
E92 335i Fully Loaded | Procede Rev2 | ETS FMIC | AR Catless DP | AFE DCI | AA BOV | KW V2 | iForged Essen | VRS CF Trunk | M-Tech Sideskirts | M-Tech Rear | Ericsson Front GONE!
07-21-2010, 09:22 AM | #16 |
263
Rep 2,559
Surprising that the DPs don't fit as the same shop installed my first catless AR design DPs a bit more than a year ago without any problems. Granted it was a tight fit but it worked.
I would be equally surprised though if there was a design issue with the DPs as there are hundreds who have them installed without any problems. Crossing fingers you'll get it sorted...! Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
07-21-2010, 09:50 AM | #17 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
Those are not SIMs (simulators). Those are the real oxygen sensors!
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
07-21-2010, 10:06 AM | #18 |
127
Rep 4,732
07-21-2010, 10:21 AM | #19 |
297
Rep 4,408
07-21-2010, 11:19 AM | #21 | |
1121
Rep 5,396
There is only 1 O2 Simulator that you need to install and it is installed in the ECU compartment, not on the downpipes. Yes, BMS still sells them and they work fantastic! I have one and it works like a charm on my fully catless exhaust system. http://www.burgertuning.com/dpfix.html OP, This looks rather weird! Best thing to do is to give Andrew a call and most probable he will be able to sort out the issue real quick. Their downpipes are top-notch and the fitment is great!
07-21-2010, 11:54 AM | #22 | |
127
Rep 4,732
