2010 2011 BMW 5 Series Forum F10 DIY Oil Change F10 5-series (N55 motor) |
07-20-2010, 08:39 PM | #1 |
116
Rep 1,346
Drives: 2011 E92 335 M-Sport
1100 miles, time for a oil change.
Parts:
Make sure oil is at operating temp before doing this. 1. On a level surface, engage parking brake and chock rear wheels 2. Lift front of car, I used two floor jacks with plastic pads to keep from damaging plastic jack points on the F10. 3. Use jacks stands in case floor jacks malfunction (this is VERY IMPORTANT) Never get under a car without proper safety backup. 4. Remove small bolt that holds trap door in place, remove trap door. 5. Using 17mm socket and wrench loosen drain plug. (Bolt faces down, so no mess with angle draining) 6. Lower car back down to ensure even oil draining. This will take a while, I made a sandwich during the time. 7. Remove oil filter, I did it by hand but if your kung fu grip isn't strong enough buy the filter wrench. With needle nose pliers remove green gasket and large black gasket on oil filter housing. Pull oil filter out. Install new filter, the writing was facing out or down. Put new gaskets on the filter housing. I soaked the new filter in a little oil and rubbed some oil on the new gaskets. I sucked out all the residual oil in the filter seat with a turkey baster. Screw filter back into the base. Match the green alignment marks (thanks for that Dingolfing!) 8. Jack Car back up, place jacks stands in position again, make sure the rear chocks haven't moved around. Put copper crush washer onto new bolt, put a little oil on the threads of the bolt, and tighten bolt back by hand at first then use the 17mm socket and torque the bolt back to 25-30lbs/ft, don't over tighten. 9. Put trap door back in place (or leave open to check for leaks later, I skipped this as I am confident in my DIY skills, if you're not, triple check everything). 10. Place car back on level ground, and fill with 7 qts of oil. I list the 3 grades and brands above because they are the most common in N. America and can be found easily, don't send me PM's about how great Amsoil or Redline is, most people don't want to deal with the hassle of getting that stuff. 11. Drive car around until oil level appears on IDrive (this took forever, and pissed me off. My kingdom for a dipstick!!!) 12. Bask in your glory by consuming beer or adult beverage of choice. Castrol Syntec European Formula 0W30 chock rear wheels I used two floor jacks with plastic pads to keep from damaging plastic jack points on the F103. Use jacks stands in case floor jacks malfunction (this is VERY IMPORTANT) Never get under a car without proper safety backup. Remove small bolt that holds trap door in place, remove trap door. 5. Using 17mm socket and wrench loosen drain plug. (Bolt faces down, so no mess with angle draining) I sucked out all the residual oil in the filter seat with a turkey baster. Match the green alignment marks (thanks for that Dingolfing!) Early and often for the first year. I own this car, it's not rented.: Planned schedule: Total Vehicle Mileage 1. 1,200 Miles (Owner) 2. 7,500 miles (Owner) 3. 15,000 miles (Dealer) 4. 22,500 miles (Owner) 5. 30,000 miles (Dealer) Last edited by gatoman39; 02-03-2011 at 06:23 PM.. |
07-20-2010, 10:36 PM | #2 |
Administrator
40755
Rep 21,239
Our first DIY! And a great one at that. Thank you for sharing.
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
07-22-2010, 12:02 PM | #6 | |
116
Rep 1,346
Old School BMW Maintenance Schedule: Break-in Service for New Cars Traditionally, BMW performed a break-in service at 1,200 miles on new cars, which included changing the engine oil and filter, manual gearbox oil or automatic transmission fluid, and differential oil. With the advent of Free Scheduled Maintenance, BMW stopped performing break-in services except on M cars. I have seen that the engine and driveline oils in new modern BMWs are literally full of metal at 1,200 miles – as has always been the case with any new car. For this reason, I recommend a 1,200-mile break-in service. |
07-22-2010, 01:58 PM | #7 | |
699
Rep 1,447
07-22-2010, 02:14 PM | #9 |
3052
Rep 4,388
Drives: 2022 F97 X3M Comp LCI
fuel additive manufactured from the netherlands. add it to the fuel tank after every oil change. it'll clean the injectors and the entire fuel system. adds an extra 15+ whp. use heineken lite if you're not tuned.
btw, great diy. car looks great!
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
07-22-2010, 02:35 PM | #10 |
116
Rep 1,346
07-22-2010, 02:47 PM | #12 |
24
Rep 413
A $65,000.00 car and a $35 jack. I see you've been shopping at Harbor Freight again............ I'm just bustin ya. Obviously I've been grabbin stuff from there too, or I won't know that "U.S. General" means Made in China. Good write up. Nice to know there are other BMW drivers out there that will get their hands dirty
07-22-2010, 03:07 PM | #13 |
1304
Rep 6,309
no way...
Op, well done and nice and clear diy.
F30.F11.E86.E90.E90.E36 |
07-22-2010, 03:10 PM | #14 |
415
Rep 2,475
Great write-up, thanks for sharing! I've follow Mike Miller's guide for my E90 as well.
The last step is the best.
2020 /// M2 Competition
Past: 2016 435i ZHP Edition | 2013 335i | 2011 135i | 2008 328i | 2006 325i |
07-22-2010, 03:12 PM | #15 |
M POWER
Rep 86
Yes! All M's and Alpina vehicles come with a 1200 mile break in oil change. Which includes a transmission (only on manual vehicles) and diff oil change.
07-22-2010, 03:18 PM | #16 | |
116
Rep 1,346
Dumped factory fill at 1200 miles Mobil 1 5W-30 10 months and 5600 miles later... Last edited by gatoman39; 07-22-2010 at 03:26 PM.. |
07-22-2010, 03:22 PM | #17 |
Rep 28
Yes, prior to taking delivery of my '11 535 I had a 2008 M5 on a two year lease and as part of the maintenence program they did the break in service at 1200 miles.
07-22-2010, 03:48 PM | #18 |
961
Rep 11,722
Thanks for the write-up.
I appreciate those engineers that design small simplistic items such as the trap door on the shield; Rather than taking the whole shield out to gain access to the Oil pan nut. |
07-22-2010, 04:36 PM | #19 | |
Rep 26
Driving: 11 F10 528i Memorium:07 E92 328i, 04 E46 325ci, 87 E30 325e, 76 E6 2002ti |
07-22-2010, 04:45 PM | #20 |
116
Rep 1,346
No, I surely did not see any metal, not that I was looking. I believe the metal and basic elements may be suspended in the oil, or in a form that is not clear to the naked eye. As you can see from the Used Oil Analysis, there are a lot of individual metals and elements they can test for. From what I could tell the oil looked clean and thin, not that you can tell much by simply looking at it.
