Vishnu Procede, Macbook, and Windows 7
07-19-2010, 11:28 PM | #1 |
13
Rep 35
When I bought the car it had the procede installed. I'm going to run the software on a Macbook using Boot Camp. My question is should I install the 64 bit or 32 bit version of Windows 7? I can't find too much on the forums or any capability discussions. Anyone have any experience as to which one will work? Thanks.
07-19-2010, 11:59 PM | #2 |
108
Rep 1,973
Drives: 2009 e92 MR "Civic" ///M3
no point in running 64bit windows on a VM, where you're not likely to assign more than 2gigs of ram to it anyways. So that said, run 32bit windows 7, much more compatible with drivers.
|| DCT | ESS Tune | ACM Test-pipes | AA Green Filter | Swift Spec-R Springs | Stoptech ST-40 F || || My Youtube Channel ||
07-20-2010, 12:17 AM | #3 |
13
Rep 35
Yes I've got 4 gigs of RAM and my plan was to install the 64 bit Windows 7. My concern is the Vishnu software - any problems running 64 bit and Vishnu software?
07-20-2010, 12:46 AM | #4 |
Rep 177
You'll have no wories with running the Vishnu software with the 64 bit version of Windows 7. It's perfectly compatible.
If you have any increased difficulty with 32 bit vs 64 bit it will be related to installing the drivers for the USB to COM adapter that you'll need to connect to the PROcede to update maps, firmware and data log. I had problems connecting with the Prolific cable. The Radio Shack cable disconnected every 30 seconds on average. You may want to check out this thread as it discusses some of the USB power management issues in Windows 7 that's been helpful for some. Also some have had success running XP mode in Windows 7. XP Mode is a virtual machine that can be run in Windows 7 that allows easy integration with the host OS in a way that is mostly seamless. Here's the thread... http://www.e90post.com/forums/showthread.php?t=393711 Here's a link to the USB cable that worked for me and import36. I use Windows 7 64 bit and import36 uses Vista. http://www.usconverters.com/index.ph...roducts_id=290 I've had zero issues connecting and no problems with disconnects since going to this cable. Last edited by topspin; 07-20-2010 at 01:36 AM.. |
07-20-2010, 08:44 AM | #5 |
108
Rep 1,973
My version of autoreading sh*t wasn't working right.. ooops to my self.. me bad
07-20-2010, 08:45 AM | #6 |
The Stig
31
Rep 1,232
If the only reason you're installing boot camp is to use the procede, I'd strongly recommend you install XP instead....it is MUCH better at keeping the serial connection stable for some reason.
07-20-2010, 11:15 AM | #7 |
12
Rep 859
+1, mine works fine in Win7. I still plugin the laptop when updating firmware just to be safe, but that's it.
2007 335i SG Coupe
2009 128i AW |
07-20-2010, 11:21 AM | #8 |
136
Rep 1,954
Drives: 2020 X3M Competition
bootcamp is compatible with 32-bit vm's only... </thread>
2020 F97 X3M Competition (current) - 2018 F80 M3 Competition - 2015 F82 M4 - 2012 E82 135i - 2010 E92 335i - 2007 E92 335i
07-20-2010, 12:39 PM | #9 | |
Enthusiast
12
Rep 262
Thanks for the solution. I think this will resolve my Window 7/64 connection issue.
07-20-2010, 02:20 PM | #10 |
3398
Rep 6,589
Drives: BMW
I think this is a bit of misinformation, are you saying that my 64bit win 7 installation is not compatible with running Parallels? Would you like me to provide you with a screen shot of WIN7 64bit working in bootcamp and Parallels???
Maybe you are saying Parallels or Fusion only come in 32bit? Either way I am running exactly what you are saying isn't compatible. |
07-20-2010, 02:26 PM | #11 | |
12
Rep 859
2007 335i SG Coupe
2009 128i AW |
07-20-2010, 02:39 PM | #12 |
3398
Rep 6,589
Drives: BMW
That's fair, but he inferred that ALL. So I just wanted to clear up the incorrect information for the OP as well as anyone else that browses this thread.
08-11-2010, 09:26 AM | #13 | |
133
Rep 4,764
I ran the procede exe in compatability mode for XP (tired all SP's) and the random disconnects would still happen. When I would have the compatability checked of the procede exe it would aways say that it was not compatible with windows 7. I got so frustrated with the usb to serial disconnects happening at random times. The time needed to update the firmware could be 1-2 hours of sitting in the car to get through the whole thing without a disconnect. My old XP laptop had power issues that could not be resolved, so I finally went out and bought a $250 netbook with XP SP3 on it for all my car applications (Escort, Laser Interceptor, Procede, Bavarian Technique). None of my other car apps that went through USB had and issue, even when using the same USB to serial cable (I have multiple of the same exact one), so it is something in the procede software, and maybe it only happens on certain brand computers? I also downloaded and installed all of the available Windows 7 compatibility updates. |
08-11-2010, 12:13 PM | #14 | |
62
Rep 1,476
08-11-2010, 01:13 PM | #15 |
9
Rep 312
lol @ boot camp.. man thats soooo 1999. Parallels Desktop with a XP VM would be ur best bet. Just make sure you install the drivers for your USB to Serial adapter. BTW use the 32bit Version
08-11-2010, 01:23 PM | #16 |
3398
Rep 6,589
Drives: BMW
First, bootcamp was release in 2006 when the intel macs came about... Second, if you want to utilize the hardware to it's max, bootcamp is the ticket. Third, using 32bit version is only going to utilize just under 3 gigs of ram. If you have more, you can't take advantage. So hence the use of bootcamp. I can tell you from my current setup that bootcamp runs far superior to a VM even with my dual core 8gig MBP.
08-11-2010, 02:00 PM | #17 | |
9
Rep 312
08-11-2010, 02:22 PM | #18 |
3398
Rep 6,589
Drives: BMW
09-08-2010, 11:23 PM | #19 |
164
Rep 2,875
So Procede reader won't work on a MacBook Pro?
TIA
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
09-09-2010, 12:24 AM | #20 |
102
Rep 2,760
I have a Macbook Pro too, and I run 32 bit windows because I use it only for Proceed reader, no point using the 64 bit version; Remember the memory you are allocating to Windows is not available to your Mac. No free lunch. But if you are like me and I do everything else in the Mac OS 10, you are better off using the 32bit version.
E92 335 | Space Gray | Saddle Brown Dakota | Dark Burl Trim | ZPP | ZSP | AT | Idrive | 6FL | FBO | Dinan CAI | Quaife LSD | STG3 PROCede.
09-09-2010, 12:29 AM | #21 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
