DIY: Air Filter Replacement - 325 (2.5litre)
09-06-2005, 11:02 AM | #1 |
64
Rep 239
For this the only tool you'll need is a T-25 Torx screwdriver.
Firstly, slacken all the screws shown in the first picture. Then lifting the air filter cover you will see that the pipe from just above the kidney grill joins this cover and is secured by two little tabs. By lifting the cover at an angle the tabs should release allowing you to remove the cover completely. Note that the screws do not unscrew fully and stay captive within the cover. You can now see the air filter element. I was surprised to find a cylindrical filter!! In order to remove the air filter element there is a small clip at the front (circled in picture 3 and close up in picture 4). You need to press the circular area on either side and slide the filter forward. It will then come up and away from its mount. There is an insert within the filter which is fixed and sealed in place. Put the new filter in the same way the original was removed, replace the cover making sure the tabs lock into the inlet pipe and the screws all line up. Retighten the screws and you're done!
Drives: BMW F80 M3 - Sahkir Orange
12-03-2005, 05:50 AM | #4 |
235
Rep 2,059
The round filter element looked aftermarketly cool though.
330i 6MT l 255 HP @ 5900 rpm 214 lb-ft Torque @ 3500 rpm l Alpine White l Beige l Aluminum l ZSP l 494 l PDC
"Freude am Fahren" = "Joy to Drive" |
12-04-2005, 03:48 AM | #6 | |
27
Rep 282
Quoted from bwm.com: No. of cylinders/valves per cyl. 6/4 Displacement acc. to ECE Reg. in ccm 2,497 Stroke/Bore in mm 78.8/82.0 Nominal power (kW) at 1/min 160/6,500 Max. torque (Nm) at 1/min 250/2,750-4,250 Guillaume |
12-04-2005, 08:14 AM | #7 | |
1311
Rep 10,185
its a 2.5L in the rest of the world, with the same power and torque |
12-04-2005, 12:11 PM | #8 |
27
Rep 282
Does anyone know what's the reason of that? Is it also a pollution matter? If I remember well, the S50 engines were'nt allowed in the US because of that...
Guillaume |
12-31-2005, 12:38 PM | #9 |
Daddu
Rep 8
Can someone post a DIY on removal of the USA 3.0 liter 325i air filter. This is the flat, trapezoidal one.
325i; European Delivery; Alpine White; Beige Leatherette; Poplar Wood Trim; Heated Seats; Debadged; Visor Warning Label Removed;
12-31-2005, 02:27 PM | #10 |
97
Rep 399
Drives: 2023 BMW i4 eDrive40
US Air Filter
I took my air filter apart to see how hard it would be. Be sure to have a 10 mm socket, a T25 torque bit and flat blade screw driver.
1) Loosen the steel clamp on the output side of the filter housing using the screw driver. Jpg #1 2) Disconnect the connect from the air mass flow meter. JPG 2 3) Disconnect the filter housing from the suction hood intake duct. JPG 3 4) Remove the filter housing from the engine compartment using a 10mm socket two places. Be careful of the air mass flow meter as it is very expensive. JPG 4 5) Remove the screws using the T25 torque bit. JPG 5. 6) Remove air filter and install new filter. 7) Reassemble the air filter housing. 8) Reinstall in engine compartment. Last edited by WallyF; 12-31-2005 at 02:49 PM.. Reason: Adding 5th picture and additional instructions |
12-31-2005, 02:59 PM | #11 |
Rep 178
Thanks WallyF for sharing the info. It looks like some work just to change an air filter. I wish BMW would have made it a little easier...
E90 330i / SG / Biege / Burl / ZPP / Heated Seats / Steptronic / CA / PDC / ACC / iDrive / Sirius-prep |
12-31-2005, 03:21 PM | #12 |
97
Rep 399
BeemMeUp,
It takes about 15 minutes to change out the air filter. I figure I will do it between 25,000 and 30,000 miles myself. The dealer will change it out at Inspection #2. I figure that will be at the end of the 4th year or 50,000 miles. Have a Happy New Year!! Wallyf :rocks: |
02-21-2011, 02:34 PM | #15 |
Rep 5
That's a pretty good walk-through. Cut up your steps a little bit more. Still, it's good to know this stuff. I'd like to start doing more basic stuff on my car, without taking it to my dad or the dealer.
__________________ Used Car Guy Indianapolis car loan Spawn of the Devil funny facebook status Last edited by MainDeck; 04-22-2012 at 07:49 PM.. |
02-26-2011, 01:32 PM | #16 |
12
Rep 56
Thanks for the guide. Helped me perform my tune up.
2014 435i x-drive/ EBII /M-Sport/Premium/Dynamic/Driving assist Package.
2013 X3/ M-Sport/ Premium/ Technology/ Former Owner: 330i RIP. |
03-25-2011, 01:24 AM | #19 |
Rep 28
I just bought my first bimmer last week, a 2008 328i (black/black, premium, sport). I worked on it for the first time yesterday and installed a matte black grille, and a K&N air filter. I'll post to another thread about my anguish with the grille, but the air filter replacement was surprisingly easy. I took my time, and stopped to snap a bunch of pics along the way, and it took just under 30 minutes. I'll post again with some detailed photos and instructions.
Take it from a newbie, as long as you're careful, you've got almost no reason to be nervous about changing the air filter yourself. Thanks for the original post, WallyF. It helped a ton! Last edited by billywu04; 03-25-2011 at 01:27 AM.. Reason: update text |
04-12-2011, 03:17 PM | #20 |
Rep 10
I put my K&N air filter the engine sound and performance have huge difference. The car runs better and the engine is louder like an sport car supposed to be. It was a great investment!!
04-21-2011, 05:38 AM | #21 |
17
Rep 238
dont belive in louder or better performance is exactly the same no diferences
HOTROD182 says I made a bunch of runs switching the K&N in and out, noticed no difference whatsoever. Infact, my best trap was with the stock air filter. My 12.13 at the drag strip was with a totally stock air filter as well. But let me know if you want to buy my near new K&N, still in the orig box. I only used it a few hours. But in all fairness, its not really the fault of the K&N. There have been numerous dyno tests showing almost no difference between running a filter and no filter at all. __________________ 1987 Grand National 2011 Alpine 335d M-Sport 12.9 @ 108.3mph 2008 Black 335i Sedan. 11.81 @ 119.2mph, 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph 60-130mph: 6.95 seconds. |
04-21-2011, 05:42 AM | #22 |
17
Rep 238
hi again
one thing is true the car will be more procteted with k§N Filter The filter is so much better but dont buy if you think will improve performance the only thing it will do its protecting dust from getting in your motor and that is the most important thing |
